Which log has no errors, the HA log or the ADB server add-on log?
neither, on adb log only say âalready connected to 192.168.1.42:5555â on every timeout reconnect, and on the HA log i donât show any issue, but when restart the addon, back to normal, for a while , i think happens when mi tv box goes to standby and after a time go to play again
Try this as a custom component and post the HA log. It wonât fix the issue, but it will log a lot of info.
ok, let me do it
Hi, here is the log , the issue started at 16:52 , this is my log https://we.tl/t-U4kK0ACWaW
Thanks for posting the log. Unfortunately, I donât know what the cause of the error is. Does it ever go back to a stable connection?
When itâs doing this, try using the androidtv.adb_command
service to send the command echo hello
and post the HA log results (just the relevant lines).
Random idea: try adding device_class: firetv
to your config and let me know if the error still occurs.
hi, just now see the reply , let me do that and i post the log thanks
Release v0.5.1
This is a general maintenance release.
Changes
Upgrades add-on base image to v3.1.4
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Release v0.5.2
Changes
Upgrades add-on base image to v3.2.0
After some recent update, I have noticed that my nvidia shield stoped respond to HA. Log for adb addon looks ok:
[a6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: ADB - Android Debug Bridge
The Android Debug Bridge server program
Add-on version: 0.5.2
You are running the latest version of this add-on.
System: Arch Linux ARM (armv7 / odroid-xu)
Home Assistant version: 0.98.5
Supervisor version: 187
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] adb.sh: executing...
[cont-init.d] adb.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[13:54:42] INFO: Starting the Android Debug Bridge server...
[13:54:43] INFO: Connecting to device: 192.168.0.230...
connected to 192.168.0.230:5555
[13:57:43] INFO: Connecting to device: 192.168.0.230...
already connected to 192.168.0.230:5555
So what can be wrong?
To be honest I can find the point when it stopped to work. My bad.
Never mind start working again.
Release v0.5.3
Changes
Upgrades add-on base image to v4.0.0
My nvidia shield keeps cycling between standby and playing despite it being in playing mode logs show no issues.
Exacly the same thing started happening to my configuration abourt a week ago.
Same here, I eventually got round to looking at it last night and after trying a few things it seems to work again. I restarted the add-on, turned network debugging off and back on, rebooted the Shied and then rebooted Hassio. No idea if any of that actually fixed the issue, and if so probably the on/off of the network debug but it seemed to be fine afterwards (at least last night anyway, Iâll report back if it stops working again). Perhaps worth a try?
Cheers
I restarted my nvidia shield, the addon and hassio with no luck. Havenât tried to turn off and on the networking debug. Iâll try it that too.
Yeah, Iâve got the same issue as well. I set the scan_interval to 2 seconds a few weeks ago and thought Iâd remove it as a test. After removing it, the componentâs status doesnât even update at all. It remains on Standby even if the Shield is playing.
Just as a side, seeing this in the logs of the add-on is rather disturbing as this suggests that the add-on attempts actual connectivity and realises that it is already connected. Seems rather unnecessary. I donât know much about the ADB protocol, but if there is some or other network management messaging that should be used to maintain activity on the transport instead of attempting to connect every few seconds, then that should be used and thus, there should not be a need to âconnectâ every time.
[17:50:10] INFO: Connecting to device: 192.168.1.101âŠ
already connected to 192.168.1.101:5555
Sorry false alarm, back to the same behaviour last night. Not fixed
I think the bug being discussed is fixed in the upcoming release. In the meantime, you can use this custom component (HACS compatible): https://github.com/JeffLIrion/ha-androidtv
Iâd also like to fix the ADB python library so that it works for newer devices, making the ADB add-on unnecessary. To do this, I need some logs. If youâre willing to help out, use the custom component and follow the Python ADB implementation instructions. Enable debug logging via the logger.set_level
service with the parameters:
{"custom_components.androidtv.androidtv.adb_shell": "debug"}
When the device is on, it should constantly connect and then become unavailable. Please post the log from when this is happening.
I have some logs for you. Itâs pretty verbose, would you prefer them in a GitHub issue or here?
