When I use the AdGuard API call “disable url”, it is deleting the URL information (name, url) and leaving a blank line in AdGuard Block Lists. When I try to re-enable the url, it doesn’t work because it no longer exists, or at least the url doesn’t. I can only remove_url and add_url. In addition, the call to remove_url produces an error response but it works.
Call-service API error. Error Message: ('Failed removing URL from AdGuard Home filter', {'response': ''})
After third try to report bug and failing, I’m at a loss. @frenck, can you tell me what place I should report this since it’s not HA nor apparently AdGuard Home itself? I am probably just ignorantly reporting in the incorrect GitHub.
Unless you told your router (which would tell your phone) to use adguard as the dns you wont get any filtering.
You should be able to look at the query log and see traffic from your phone. If you see traffic from your phone but are still getting ads, then look into additional block lists.
Check on your phone if you have private DNS on automatic. That could route DNS queries towards the google DNS server.
Another problem could be IPv6. I never figured out a way to block ads with adguard on IPv6, so I had to disable it completely on my network/router.
I’m using this add-on and running it as a DHCP server. Is there a possibility to use this for presence detection in Home Assistant?
I found something for Pihole, would this be possible with Adguard? Use Pi-hole DHCP to speed up ping device tracker detection
Question: Does the AdGuard Home integration only work with the the official HA AdGuard Home add-on? I was trying to connect it to a known working AdGuard instance and it keeps failing to connect. My HA instance and the AdGuard Home instance are on different physical machines in the same subnet.
I’m running it on a different machine/CT, and it is working with HA.
The HA addon has autocomplete for the port, it wants you to use 3000. Try replacing it with 80, it should work.
I managed to add this on my iPhone, from bed, in less than 15min (rpi4, 8gb)
Question: (sorry if the wrong place to ask)
Anyone got some nice templates/cards they have developed?
Maybe a nice daily trending?
Or something that shows how much blocked for each client on the network (eg my iPhone vs my partners iPhone)
This is very likely a stupid question. Successfully installed AGH on my HA Pi and everything is working well. However, when I look at the AGH web UI, the version at the bottom of the Dashboard says v0.102.0. Clicking the “update” button returns “AdGuard Home is up to date”. I have a redundant AGH installed on another Pi and the latest version there is v0.103.3. Is this just a matter of waiting for the add on to get updated or did I do something wrong installing it? FYI, I’ve already been able to successfully update the HA instance so the system appears to be checking for updates appropriately. Thanks!
