I know this isnāt the right topic but I wanted to know if itās possible to play music from Google Play Music/Youtube Music and cast to Spotify Connect speakers. Similar to Aircast but wanting to cast audio and pipe it to spotify connect speakers. I have Samsung Radiant 360 that will only play well with Spotify.
hi guys, how can i tweak the difference of sounds from 1 speaker to another in other room? there are 0,5 seconds of difference, sorry for newbye question
Are there some specific ports that need to be opened on the host machine?
My hassio instance is installed on a Ubuntu server with ufw enabled and I can only cast to my speakers using aircast if ufw is disabled. Otherwise, even though I can se the new devices in airplay, I have a ācannot connectā error message and no logs on the server.
Any help is appreciated.
Thank you
Not really the same thing but you can do continuous streaming from Google Music (preferably with Gmusic proxy in order to not stop the play in the middle) to a Chromecast group:
Hi, it is really great!
I have a question which is probably silly but is it possible to have it also for video?
So tv supporting chromecast would be available for air play?
I guess a year and half ago hasnāt changed anything to Google Chromecast open sourceā¦
Anyone has a clue how to use the AirPort from an Android or Windows device?
Hey I wonder whether anyone is experienceing the same issue or is able to provide me with some help or guidance.
I am unable to connect to Aircast device upon updating to version 2.4.0. When I try to connect to device i get the error message on the apple device saying: Unable to connect to ādevice nameā. I have tried this on all apple devices within the entire HASSIO ecosystem. ā same message on all devices.
I have tried to solve to problem doing the following:
I have uninstalled the aircast add-on and installed it again which didnāt make a change
I deleted the aircast cofig file, agian that did not solve the issue.
I am running the following system:
Add-on version: 2.4.0
You are running the latest version of this add-on.
System: HassOS 4.15 (armv7 / raspberrypi3)
Home Assistant Core: 0.116.4
Home Assistant Supervisor: 249
