hi
same for me with errors in the supervisor log :
23-03-10 14:49:08 WARNING (MainThread) [supervisor.ingress] Fails Ingress panel for a0d7b954_grafana with 500
and no more acces to the plugins store with unexpected error and This filter has been disabled because the grafana server cannot access grafana.com.
do you have found a solution ?
Are there mathematical calculations in your tiles that have stopped working? because it was the case for me, you have to cut the mathematical formula of the query, add a math expression and if the formula was in query A for example, you have to put $A and paste the formula.
I still have my problem of ingress auth that donāt work but all my graphs are now working.
It is the ingress auth that is not working I am guessing, I looked in the grafana logs and see the below, but have zero idea what it means.
InfluxDB Error: Internal Server Error - Check the Grafana server logs for the detailed error message.
logger=context userId=1 orgId=1 uname=admin t=2023-03-21T19:07:31.493927333-04:00 level=error msg=āRequest errorā error=āinterface conversion: interface {} is nil, not stringā stack="/usr/local/go/src/runtime/iface.go:262 (0x414e29)\n/drone/src/pkg/tsdb/influxdb/response_parser.go:103 (0x34714e4)\n/drone/src/pkg/tsdb/influxdb/response_parser.go:40
Hi experts,
The down arrow next to the panel titles in all my dashboards disappeared. The title is also no longer centered but on the left. I can still edit by pressing e on the keyboard and save later, so it does at least not appear to be a permission problem. Can anybody help me getting my arrows back? In case the arrow went with the last update, how do I get to the edit option other than pressing e?
Thanks a lot!!!
Home Assistant 2023.5.4
Supervisor 2023.04.1
Operating System 10.1
Frontend 20230503.3 - latest
Grafana 8.3.0
there is now 3 dots on the right hand side (only visible with mouseover)
Thanks!!! For the next version I recommend to color them black on black ⦠
Hello everyone,
getting a bit crazy about that one, not sure Iām missing an obvious thing, but since Iām getting close to giving up, time to call for help ![]()
Home assistant running like a charm on RaspPi 4, latest Core, Supervisor, OS, FE versions, installed the grafana add-on over the week-end to get up to speed on Ā« Monitoring & Observability Ā», starting by monitoring my Internet connection.
InfluxDB created, added as a data source to Grafana, first grafana dashboard looks pretty cool (although very basic), setting up thresholds, happy bunny, until I want to send alerts. Iām not going to use PagerDuty for home appliance (that would be over the top), so email alert will do, if only it would work ![]()
This is the issue:
logger=ngalert.sender.router rule_uid=f21331a5-c7f6-49f0-9ca4-6adfae7d742f org_id=1 t=2023-11-22T20:45:00.280128903+01:00 level=info msg="Sending alerts to local notifier" count=1
logger=ngalert.notifier.alertmanager 1=(MISSING) t=2023-11-22T20:45:00.606234641+01:00 level=error component=alertmanager orgID=1 component=dispatcher msg="Notify for alerts failed" num_alerts=1 err="grafana-alert-email/email[0]: notify retry canceled due to unrecoverable error after 1 attempts: failed to send notification to email addresses: [email protected]: EOF"
My SMTP config looks like that:
- name: GF_SMTP_ENABLED
value: "true"
- name: GF_SMTP_HOST
value: smtp.gmail.com:587
- name: GF_SMTP_USER
value: [email protected]
- name: GF_SMTP_PASSWORD
value: xxxxxxxxxxxxxx
- name: GF_SMTP_SKIP_VERIFY
value: "false"
- name: GF_SMTP_FROM_NAME
value: grafana
- name: GF_SMTP_FROM_ADDRESS
I am using the so-called app password from Google Mail and I have confirmed that it works as I have been able to generate emails with other apps (InfluxDB for example). Any idea what the issue could be?
Many thanks in advance!
Rom
After another week of back and forth, I half gave up, but not completely. In the end, I decided to use AWS and the Simple Email Service, works like a charm, easy setup and it gives me ideas for other personal projects.
Can anybody help me how to start http service on port 3000?
By default, I think it does not work, at least not in my case.
I am using Grafana add-on on HA OS on Raspberry Pi and I do not see anything useful for it in Configuration tab.
Any ideas why Iām getting the error message shown in this picture. Iām using the Grafana Add-on (9.1.2) with InfluxDB (5.0.0) all installed on HA OS 11.4 with Supervisor 2023.12.1.
I am able to view the list of data sources which shows the InfluxDB with my local host and port 8086 but when I click to view the settings the screen is blank.
TIA for any suggestions.
I have manually edited the grafana dashboard (yaml?) file. Made a mistakeā¦
Now grafana starts with an error: āAn unexpected error happenedā and doesnāt load my dashboard anymore.
Can anyone tell me in which file this dashboard data is stored so I can edit it manually?
I have searched all homeassistant locations as root, but could not find a file with a string I used in my dashboard.
Thanks in advance
OS Version: Home Assistant OS 12.2
Home Assistant Core: 2024.4.3
Add-on version: 9.2.2
I have the problem that datasource plugins that are not part of Grafana Core lose their configuration after a restart. So it seems the configuration directory for this plugins are not persistent. How can I fix this?
I already reinstalled the Garafana addon several times.
Not 100% this is the right place for this question. Please advise if better place.
I am loving the new labels functionality in HA. Now I would like to move some of my grafana visualizations to use them. Currently I do queries of multiple entities by doing where clauses of entity equals entity_id1, entity_id2, entity_id3, etc⦠I would love to be able to do something like label equals label1.
Looking at the InfluxDB ingress, it does not look like it even stores that data. Not sure where to go from here.
Any assistance would be greatly appreciated.
hi
how can i add svg to the grafana addon
or can i map media folder to the grafana
thank you
Same thing I face. Were you able to figure it out?
EDIT:
In case someone stumbles on this and wonders how to do it.
The way to solve it is: Log in, create a new user, switch user, delete the old one, and make sure to update the grafana_ingress_user option in your add-on configuration tab.
i have some issues trying to get the grafan stats into the HA Dashboard.
I have both the Grafan and InfluxDB Community Addon running and configured.
After connecting both addons it says after test&save ā succesfull
My Grafana config looks like this:
plugins: []
custom_plugins: []
env_vars:
- name: GF_AUTH_ANONYMOUS_ENABLED
value: "true"
- name: GF_AUTH_ANONYMOUS_ORG_NAME
value: Main Org.
- name: GF_AUTH_ANONYMOUS_ORG_ROLE
value: Viewer
ssl: false
certfile: fullchain.pem
keyfile: privkey.pem
like in the manual listed
But after i choose the āembededā link there is simply a dark Webpage Card without any error message.
What can i try to solve this?
my embede url looks like this:
http://localhost:3000/api/hassio_ingress/bOE0cojuBu2eRSq98Hf2eK2GZUmyos7JvDKZn8sDWng/d-solo/247d0771-d096-40e0-9c56-5e1d9f3036f5/akkustand?orgId=1&timezone=browser&panelId=1&__feature.dashboardSceneSolo
Thx in advance for help.
P.S: The graphs in the Grafana Dashboard view looks perfect, only the transfer to the HA Adsboard is not workingā¦
