same here, black screen after second time watching???
Release v0.7.0
This is a maintenance release.
Changed
Component > Integration
Update add-on installation instructions
Updates maintenance/license year to 2020
Fixes some spelling and grammar
Upgrades add-on base image to v6.0.1
Upgrades lua-resty-http to 0.15-r0
Upgrades nginx to 1.16.1-r4
Upgrades nodejs to 12.14.0-r0
Upgrades git to 2.24.1-r0
Thank you for your guys for great add-on.
By the way, some users like me expect the same version for Raspbian (may be custom compnent etc.). Could you suggest any solution for that?
Same here, I need to refresh the page until it appear.
Maybe I understand it wrong, or got something configured wrong, but the info shown in the log is pretty litte. Itâs useless that way.
Is there a way to see logs of zigbee2mqtt or other parts of hassio?!?
2020-02-12 11:19:30 INFO (MainThread) [homeassistant.helpers.script] Script power usage: Running script
2020-02-12 11:19:30 INFO (MainThread) [homeassistant.helpers.script] Script power usage: Executing step call service
2020-02-12 11:20:00 INFO (MainThread) [homeassistant.components.automation] Executing Zigbee Map aktualisieren
2020-02-12 11:20:00 INFO (MainThread) [homeassistant.helpers.script] Script Zigbee Map aktualisieren: Running script
2020-02-12 11:20:00 INFO (MainThread) [homeassistant.helpers.script] Script Zigbee Map aktualisieren: Executing step call service
2020-02-12 11:20:00 INFO (MainThread) [homeassistant.components.automation] Executing power usage
2020-02-12 11:20:00 INFO (MainThread) [homeassistant.helpers.script] Script power usage: Running script
2020-02-12 11:20:00 INFO (MainThread) [homeassistant.helpers.script] Script power usage: Executing step call service
2020-02-12 11:20:11 INFO (Thread-3777) [pyShelly] Get status from 0095CE Shelly 2.5
2020-02-12 11:20:12 INFO (Thread-3778) [pyShelly] Get status from 0082BC Shelly 2.5
2020-02-12 11:20:12 INFO (Thread-3779) [pyShelly] Get status from E66A84 Shelly 2.5
2020-02-12 11:20:30 INFO (MainThread) [homeassistant.components.automation] Executing power usage
2020-02-12 11:20:30 INFO (MainThread) [homeassistant.helpers.script] Script power usage: Running script
2020-02-12 11:20:30 INFO (MainThread) [homeassistant.helpers.script] Script power usage: Executing step call service
2020-02-12 11:20:32 INFO (MainThread) [hacs.factory] Processing 3 tasks
2020-02-12 11:20:41 INFO (MainThread) [hacs.factory] Task processing of 3 tasks completed in 10 seconds
2020-02-12 11:21:00 INFO (MainThread) [homeassistant.components.automation] Executing power usage
2020-02-12 11:21:00 INFO (MainThread) [homeassistant.helpers.script] Script power usage: Running script
2020-02-12 11:21:00 INFO (MainThread) [homeassistant.helpers.script] Script power usage: Executing step call service
2020-02-12 11:21:11 INFO (Thread-3780) [pyShelly] Get status from 0095CE Shelly 2.5
2020-02-12 11:21:12 INFO (Thread-3781) [pyShelly] Get status from 0082BC Shelly 2.5
2020-02-12 11:21:12 INFO (Thread-3782) [pyShelly] Get status from E66A84 Shelly 2.5
and this eg. is the output of z2m log:
zigbee2mqtt:info 2020-02-12 11:23:04: MQTT publish: topic 'zigbee2mqtt/CC2591 Router 1ST', payload '{"state":true,"led_state":true,"linkquality":47,"description":"17160/0x00158D0003230AD1","type":"CHILD_RFD","rssi":44}'
zigbee2mqtt:info 2020-02-12 11:23:04: MQTT publish: topic 'zigbee2mqtt/CC2591 Router 1ST', payload '{"state":true,"led_state":true,"linkquality":44,"description":"51248/0x00124B001B7D9A04","type":"CHILD_FFD_RXI","rssi":70}'
zigbee2mqtt:info 2020-02-12 11:23:04: MQTT publish: topic 'zigbee2mqtt/CC2591 Router 1ST', payload '{"state":true,"led_state":true,"linkquality":47,"description":"56825/0x00158D0003232A67","type":"CHILD_RFD","rssi":1}'
zigbee2mqtt:info 2020-02-12 11:23:04: MQTT publish: topic 'zigbee2mqtt/CC2591 Router 1ST', payload '{"state":true,"led_state":true,"linkquality":44,"description":"35502/0x00158D000323A157","type":"CHILD_RFD","rssi":19}'
zigbee2mqtt:info 2020-02-12 11:23:05: MQTT publish: topic 'zigbee2mqtt/Aqara Dachgeschoss', payload '{"battery":86,"voltage":2975,"temperature":24.3,"humidity":44.99,"pressure":975,"linkquality":42}'
zigbee2mqtt:info 2020-02-12 11:23:05: MQTT publish: topic 'zigbee2mqtt/Aqara Dachgeschoss', payload '{"battery":86,"voltage":2975,"temperature":24.3,"humidity":45.02,"pressure":975,"linkquality":44}'
zigbee2mqtt:info 2020-02-12 11:23:05: MQTT publish: topic 'zigbee2mqtt/Aqara Dachgeschoss', payload '{"battery":86,"voltage":2975,"temperature":24.3,"humidity":45.02,"pressure":975,"linkquality":42}'
zigbee2mqtt:info 2020-02-12 11:23:36: MQTT publish: topic 'zigbee2mqtt/Tradfri LED Vorzimmer', payload '{"state":"OFF","brightness":130,"linkquality":15}'
Release v0.8.0
Changed
Add icon/logo (#29)
Update add-on documentation to use new YAML configuration format
Re-branding
Update add-on config with new password & list features
Updates for upstream Supervisor changes
Upgrades nginx to 1.16.1-r6
Upgrades nodejs to 12.15.0-r1
Upgrades add-on base image to v7.0.2
Update community forum links
hi! is there a way to apply a custom filter directly on the log viewer screen??
I canât find the add on with the link and in the add on storeâŚHow to do?
New to Home Assistant, had been on openHAB since plant life evolved.
Trying to use the add-on Log Viewer, and edited the .yaml to look like the example in the documentation, and all I get is a black screen. This is after I had to restore back to a 10-10-2021 backup when I had zwave issues.
My log viewer wonât start ⌠It just stopped, and wont start anymore. Itâs hanging on âStarting NGINXâŚâ and wonât do anything further than that.
Having the same issue as @henkkeumus
I have the same issue that @henkkeumus
Do we have any solution for this?
For some reason I cannot get this to display when using Brave browser, even in a private window with all the privacy features disabled. Normally for most sites I can see what is blocked by using the F12 console, but in this case there is nothing. Opening the IFrame in a separate tab works so itâs fine that way, but something is getting it blocked when used as an IFrame.
It was fine when I was temporarily using Edge but now with Brave Iâve hit this problem - no other parts of HA e.g. dashboard, HACS, developer all display fine.
