Home Assistant Community Add-on: Lutron Certificate
:tada: Release v0.2.1
Full Changelog
This is a maintenance release and does not have breaking changes.
Changes
  • :arrow_up: Upgrades add-on base image to Python 1.1.0
  • :sparkles: Adds port descriptions
  • :hammer: Refactor add-on to be compatible with new base image
Questions? Join our Discord server! https://discord.me/hassioaddons
Hi. Thanks for this. Installed flawlessly. No errors. Log looks fine. One problem I am seeing is HA does not seem to be able to track the status of a device. I can turn it on but that’s pretty much it. Am I missing something?
Tried to create the cert today and got the 500 error. Logs say OAuth retry issue.
@BigMal were you able to resolve this without completely resetting your Lutron hub or did you have to rebuild Lutron from scratch?
more info, I’m also seeing a file not found error. wonder if it’s permissions related?
I installed hassio with sudo/admin but maybe the addon can’t create files?
@TurboJones, yes, I believe I just started completely over with the bridge. Since this was the initial install, it was no big deal. IIRC, I believe you have to take the url from the 500 error page and post it into the Cert Web UI.
@Phillip_Sperry, there appears to a widespread issue with users experiencing the same issue as you. I’m having the same issue…it’s PITA.
https://community.home-assistant.io/t/lutron-caseta-switches-lose-state/108568/24
Thanks. It’s good to know I’m not the only one. I’ve manged to get things working for now through the SmartThings integration, but it’s a bit of a kludge, plus the HA is local (I think) which I prefer.
:tada: Release v0.2.2
Full Changelog
:hammer: Changes
  • :arrow_up: Updates requests to v2.22.0 (#3)
  • :arrow_up: Updates Flask to v1.0.3 (#4)
:tada: Release v0.3.0
Full Changelog
:hammer: Changes
  • :pencil2: Maintaince -> Maintenance
  • :arrow_up: Upgrades openssl-dev to 1.1.1c-r0
  • :arrow_up: Upgrades dbus to 1.12.16-r0
  • :sparkles: Adds Hass.io wheels
  • :arrow_up: Updates Flask to v1.1.1 (#6)
  • :arrow_up: Updates cryptography to v2.7 (#5)
  • :arrow_up: Upgrades add-on base image to v2.1.0
  • :ambulance: Ensure we have a DBus UUID at any time
Ok, this might be a stupid question but, do I need to keep the add on running after I generate the certificates? (which worked flawlessly)
Thanks for anyones advice
-Bob
Once the cert files are in the ssl/lutron directory, you can uninstall.
As a note, I couldn’t get this addon to work so I did it the manual way.
As a second note, the spacing in the documentation and this post has only two spaces instead of the four that the Lutron integration has for each entry below lutron_caseta:
Removed - Updated below.
:tada: Release v0.4.0
Full Changelog
:hammer: Changes
  • :arrow_up: Updates cryptography to v2.8 (#7)
  • :fireworks: Updates maintenance/license year to 2020
  • :pencil2: Fixes some spelling and grammar
  • :books: Adjust add-on installation instructions
  • :arrow_up: Upgrades add-on base image to v4.0.0
  • :arrow_up: Upgrades gcc to 9.2.0-r3
  • :arrow_up: Upgrades libc-dev to 0.7.2-r0
  • :arrow_up: Upgrades openssl-dev to 1.1.1d-r3
  • :arrow_up: Upgrades dbus to 1.12.16-r2
I updated to Release 4.0. But when I clicked the “Open Web UI”, I got an error message:
# This site can’t be reached
**myha.duckdns.org**  refused to connect.
* Search Google for [myha duckdns org 5817](https://www.google.com/search?q=myha%20duckdns%20org%205817)
I have duckdns set up and I can access my Hassio (installed on Raspberry Pi) remotely. Not sure how I can make the lutron work. Do I need to set up the port forwarding for 5817 on my router? Any help would be highly appreciated!
Thanks a lot in advance,
@chenghs You do not need this add-on to be forwarded to the outside world.
This add-on is a one-time run / needed one time only type of add-on.
It only provides a tool to obtain a certificate easily. After obtaining it, you won’t need it anymore.
So I’m not sure what you question or issue is at this point.
@frenck Thanks for your prompt response and explanation. I installed the Lutron Certificate v0.4.0 and started it. In the installation section, you mentioned that Step4 is "Open the web UI for the “Lutron Certificate” add-on and follow the steps. When I clicked the “Open Web UI” on Lutron Certificate page (via Hassio -> DashBoard -> Lutron Certificate), I got the error:
:tada: Release v0.5.0
Full Changelog
:hammer: Changes
  • :books: Update add-on documentation to use new YAML configuration format
  • :arrow_up: Upgrades add-on base image to v5.0.0
  • :hammer: Re-branding
  • :hammer: Update add-on config with new password & list features
  • :arrow_up: Updates requests to v2.23.0 (#8)
  • :arrow_up: Upgrades add-on base image to v5.0.2
  • :hammer: Update community forum links
this is so easy to use!! thank you !
Does anyone else have the issue of the fan control missing the medium_high option?
Howd you make out here? Im facing the exact same issue and haven’t found a resolve yet. :frowning:
