@nickrout do you have any idea please? I find motioneye very powerful but the capacity of my hardware (raspberry pi 4) isn’t enough to leverage the full quality of one outdoor security camera. And my goal is to have three of them… Shall I buy a more powerful hardware or buying an NVR would enable me to analyse the motion on the three cameras, store high quality photos and videos locally, compress videos and send them via Telegram and store high quality photos in Google Drive?
Yes you need better hardware. I would get a mini PC like a nuc, and a coral ai and use frigate.
Ok thanks @nickrout. So a RPi4 with a coral USB and frigate won’t work? I wish I didn’t have to change hardware ^^
Great! Thanks for the link! So it should be working! Fingers crossed! Now I just need to find a coral USB to buy. They are all out of stock or crazy expensive.
Hi can anyone help, I can’t get my USB Camera to work at any resolution higher than 800x640.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: motionEye
Simple, elegant and feature-rich CCTV/NVR for your cameras
Add-on version: 0.18.0
You are running the latest version of this add-on.
System: Home Assistant OS 9.5 (amd64 / generic-x86-64)
Home Assistant Core: 2023.2.5
Home Assistant Supervisor: 2023.01.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] motioneye.sh: executing...
backing up /data/motioneye/motioneye.conf
[cont-init.d] motioneye.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[06:21:31] INFO: Starting motionEye...
INFO: hello! this is motionEye server 0.42.1
INFO: cleanup started
INFO: wsswitch started
INFO: tasks started
INFO: mjpg client garbage collector started
INFO: smb mounts started
INFO: server started
[06:21:37] INFO: Starting NGinx...
[06:21:37] INFO: Successfully send discovery information to Home Assistant.
WARNING: Connect error on fd 18: ECONNREFUSED
WARNING: Connect error on fd 16: ECONNREFUSED
ERROR: motion not running, starting it
/bin/sh: lsb_release: not found
Good day to all.
??? I’m trying to implement in HAOS using Motion eye to send short video clips of what is happening behind the door. Tell me how to add sound to these videos, this function is very important to me. Thank you.
Всем доброго времени суток.
??? Я пытаюсь реализовать в HAOS с помощью Motion eye отправку коротких видео роликов того что происходит за дверью. Подскажите как мне добавить звук к этим роликам, мне эта функция очень важна. Спасибо.
Is there any alternatives for this integration? don’t know why, but cant get some cameras working others stop working when I add new cameras, seems like addons doesn’t work reliably, in addition there is 5 to 15 second delay and no audio.
This is not possible with motion eye.
It does not support sound.
Hello, guys!
I’ve just installed MotionEye (ME) addon and ME integration. I’ve checked “Configure motionEye webhooks to report events to Home Assistant” button in ME integration settings, but no ME events are appeared in Home Assistant. What’s wrong? Should I configure anything else?
Looks like this addon was recently updated. I am having trouble finding the notes on whats changed. Dont suppose it incorporates google coral?
Hi, Runing an imou cue2 using WiFi. I can see the main rtsp stream on VLC with 25fps and 1080p.
Then i add it without problem to HA and motion eye, the problem is that I’m receiving max 5fps on motioneye. I checked all the settings and nothing seems wrong
Running HA on proxmox with 6gb ram and 4 cores, so it’s not a capacity problem.
Is there another place to change configs or a way to do a debug and found the problem?
Thanka for your help
Hi there; just wanted to point out that there are a few leftovers after uninstalling the addon (and service); i uninstalled the add-on using the frontend (both in the addon frontend, and in the configured services), and restarted HA (fully, not just a YAML reload).
After this, i see the following leftovers:
$ find /usr/share/hassio | grep eye
./share/motioneye
./share/motioneye/Camera1
./addons/git/a0d7b954/motioneye
./addons/git/a0d7b954/motioneye/DOCS.md
./addons/git/a0d7b954/motioneye/translations
./addons/git/a0d7b954/motioneye/translations/en.yaml
./addons/git/a0d7b954/motioneye/README.md
./addons/git/a0d7b954/motioneye/config.yaml
./addons/git/a0d7b954/motioneye/CHANGELOG.md
./addons/git/a0d7b954/motioneye/icon.png
./addons/git/a0d7b954/motioneye/logo.png
Can i safely delete the ./addons/git/a0d7b954/motioneye
and /usr/share/hassio/share/motioneye
folders ?
Hi, did you make any changes to your configuration? I’m having the same issue. Thanks
I’m having an issue where motionEye motion detection only works with “Motion Triggered” Recording Mode.
With Recording Mode set to Continuous and Motion Detection active my webhook call is not being made. When only changing the Recording Mode it works
I would like to be able to set a mask for the motion detection to be used for a sensor trigger, and also have events outside that mask recorded
I’ve installed and configured the add-on and it is working really smooth with 4 cameras and motion detection.
The files are stored in my NAS using a network share.
It is correctly configured and the files are saved without issue.
Since I’ve started using MotionEye I’m having a lot of logs about “cifs vfs bad security option ntlm”, I’ve correctly set the SMB protocol version to 3 and my share is set to use min 1 max 3.
Looking on the forum it seems this errors it is connected to NTLM was removed from the kernel post 5.15 and the add-on is trying to use NTLM for the CIFS mounts.
Any clue on how to solve this issue?
