I’m in the same boat as Mr. Sharp. I feel like there are some steps missing in the installation instructions…or perhaps something I should have installed prior to this add-on to make it work? I’m a complete noob with HA, so forgive my ignorance.
Router is Unifi USG. Ports 80 and 443 inbound forwarded to hassio IP address ports 80 & 443. No other forwarded ports.
Fresh install of hassio on rpi3, installed configurator, node-red, and now Nginx Proxy Manager add-ons.
Created a duckdns domain, and pointed it at my home network’s public IP. started proxy manager, and get the “listening on port 81 message” in the log.
Open web UI, and set up new host with ha.domain.duckdns.org, scheme: https, forward address/IP: hassio IP address, forward port: 8123, block common exploits & websockets support both enabled, Access List: publicly accessible. On SSL tab: Requested new cert, force SSL enabled, agreement accepted, email address entered, Saved.
New host shows:
ha.mydomain.duckdns.org under source
https://(home assistant IP):8123 under destination
Let’s Encrypt under SSL
Public under Access
Online under Status.
Everything looks good.
Restart Nginx Proxy Manager add-on, wait for “listening on port 81”
Attempting to access https://ha.mydomain.duckdns.org from inside my network yields a page in my browser warning me that the site isn’t secure. If I allow the exception, it takes me to my router’s login page (although I very briefly see the hassio page loading for a split second before the apparent redirect.
using http:// or nothing at all in front of the subdomain yields the same result.
Outside of my network, I get a timeout…regardless of http://, https://, etc.
Any kind soul care to tell me where I’m obviously screwing things up?
Edit: I ended up getting all of this to work. NPM is quite excellent, once it’s actually working. I’m not 100% positive on what I did that actually fixed the issue, as I eventually just reinstalled hassio (I only had a few things in my setup thus far, so this wasn’t as big a deal as it might be for most people), and started off installing the configurator add-on and NginX Proxy Manager add-on only. But…I think I may have previously had the http: component enabled inside my config.yaml file. If you had previously been using DuckDNS add-on or some other choice for handling your certs, the instructions for that add-on may have instructed you to do so. I left the http: component commented out (and never added the SSL key stuff like the DuckDNS instructions tell you to) on the fresh install, and was able to get everything working fine without it. If you’re new, like me…and getting stuck with this after previously using DuckDNS/Let’s Encrypt…comment out the http: stuff in your config.yaml before starting the NPM setup. It might be your issue.
