hello is anyone there?
Did you get it to work? You need to setup port forwarding on your router.
I cant figure out how to get plex amp to work, when i log into the app it just says no servers found.
Did anyone discover a way yet to update the plex server addon. Keep getting the notification from Plex that there is an update but havenât been able to find how to actually install the update.
You need to wait for the Add-On to be updated. It is not maintained by PLEX themselves.
Hello Franck,
I am running plex now and is working ok, but itâs IP (172.x.x.x) is different from my private network (192.168.x.x), based on what I could find is because the add on is running with the container IP which is different that the private network.
Since this is an add on, I canât find a way to change it from bridge to host network, so that Plex identifies my private network as itâs own local network.
Any ideas?
There is apparently a security hole in the last PlexMedia server releases.
Dear Plex user,
We recently received a report via our bug bounty program that there was a potential security issue affecting Plex Media Server versions 1.41.7.x to 1.42.0.x. Thanks to that user, we were able to address the issue, release an updated version of the server, and continue to improve our security and defenses.
Which was fixed/updated in Add-on version 3.7.0 .
Apparently, I found a solution that works, but the caveat is that it would require a Plex Pass.
What I do is to add all the IP addresses from my Plex clients to the Server Settings â Network â LAN networks.
Iâve migrated my Plex server to this addon from an old NAS and everythingâs working great. Iâm thinking of adding an off-the-air USB tuner to use Plex as a DVR. Before I purchase the tuner (something like HAUPPAUGE WinTV-DualHD USB), Iâm wondering if itâs possible to âseeâ a USB device from within the addon? Or should I go with a network-available tuner like HD Homeruns?
Is anyone successfully using the addon as a DVR?
EDIT: HD-HomeRun delivered super quickly. And working with Plexâs DVR just fine so far!
Am I to assume that this add-on is no longer recommended?
I see itâs marked as no longer maintained. Should I be looking at alternatives?
just an fyi, theyâre no longer called âAdd-onsâ, theyâve been renamed to âAppsâ.
Otherwise, we use the official repository maintained by Frenck. Here. It should be baked into Home Assistant in the Apps âinstall appâ page.
