@talss89 you are a genius sir. Your pkg i python-numpy did the trick. I also needed your detail about uninstalling & reinstalling lru-dict
In the end, I think this is a full list of the instructions I needed to get HomeAssistant set up based on @gj9159a post (I’m not sure if there is anything that is unnecessary in the end, but I’m pasting it here in case it helps others):
# set SELinux=Permissive
su
setenforce 0
apt update
apt upgrade
pkg install openssh
passwd #setting the password
sshd #go to kitty/putty on PC
termux-setup-storage #confirm on the device
pkg install tsu python nano termux-api make libjpeg-turbo make rust python-cryptography libcrypt libffi binutils mosquitto wget -y
pkg install git
pkg i python-numpy
python -m venv --without-pip hass
source hass/bin/activate
pip install wheel
pip install tzdata
pip install maturin
pip install setuptools
MATHLIB=m pip install aiohttp_cors==0.7.0
MATHLIB=m pip install numpy==1.24.2
MATHLIB=m pip install PyTurboJPEG==1.6.7
export RUSTFLAGS="-C lto=n"
export CARGO_BUILD_TARGET="$(rustc -Vv | grep "host" | awk '{print $2}')"
export CRYPTOGRAPHY_DONT_BUILD_RUST=1
pip download homeassistant==2023.2.3
wheel unpack homeassistant-2023.2.3-py3-none-any.whl
nano homeassistant-2023.2.3/homeassistant/package_constraints.txt
#We are looking for aiohttp and change its version to 3.8.3, as well as numpy to version 1.24.2, then press CTRL-X, Y, ENTER.
nano homeassistant-2023.2.3/homeassistant-2023.2.3.dist-info/METADATA
#We are looking for aiohttp and change its version to 3.8.3, press CTRL-X, Y, ENTER.
rm homeassistant-2023.2.3-py3-none-any.whl
wheel pack homeassistant-2023.2.3
pip uninstall lru-dict
pip install git+https://github.com/amitdev/lru-dict@5013406c409a0a143a315146df388281bfb2172d
pip install homeassistant-2023.2.3-py3-none-any.whl
pip install --upgrade pip
hass -v
#wait 5 minutes and restart the device
source hass/bin/activate #don't forget to activate the environment
hass -v #after a couple of minutes, you can try to log in
