configure, for example, via Macrodroid, Termux reboot or the entire device after the connection is restored. Ie, the connection is lost, then restored, and only then the device is rebooted. Of course, you should have the Home Assistant server configured to automatically start after Termux is started (and automatically start Termux itself after Android is started).
I configured the server to automatically reboot through its own automation if this error is displayed in the log. But this is not a solution to the problem. I want this error not to occur at all.
I did a fresh flash of Lineage 20 (Android 13) on my Xiaomi Redmi Note 7 (lavender), rooted with Magisk 25.2 and installed Home Assistant in Termux by following @gj9159a excellent instructions.
All seemed to work fine but then i ran into the āpermission to access /proc/net is deniedā problem.
I tried following @porcupine_moon instructions, but found I couldnāt complete the part about editing the lines in common.py as I didnāt seem to have a ⦠/site-packages/pyroute2 directory and Iām not clever enough to know why not.
I then discovered I was getting a similar permissions error just executing ifconfig
After a bit of Googling, it seems this is because I have SELinux=Enforcing. The simple instructions here explained how to set SELinux=Permissive in Termux
After setting SELinux to Permissive, Home Assistant worked fine on my phone without any issues.
Iām aware that setting SELinux to Permissive opens my phone to exploits (and Iām assuming setting it in Termux is both system wide & permanent until i set it back to Enforcing?) but if its necessary to run Home Assistant on Android 13 and thatās pretty much all the phone is used for, then Iām assuming its relatively safe to leave it as Permissive?
Slight aside question:
Having got Home Assistant installed & running on my rooted Android phone, does anyone know how I could create a sensor for display on a dashboard which shows the current battery level of the Android phone? (the phone on which HomeAssistant is running, not the client).
To do this, I installed Home Assistant companion app from GP on the phone server. The application collects information from various sensors and sends it to the server. In particular - the battery charge and whether it is on charge.
What a genius idea! Thank you
I tried LineageOS sometime ago and ran into problems. I heard about PostmarketOS (which totally replaces Android) and spent quite some time finding my way through the documents.
I now am happy with it and published a guide for my old Nexus5
Not a core installation though, I use docker.
Might be worth a look if postmarketos is available for your phone,
Thanks for the guide and all the comments. Getting the server up and running took some time and sharpening of my linux commandline skills. But knowing python and having installed LineageOS already it wat doable. Main issue was python library dependancies which has already been highlighted above.
I recently had an issue where termux would crash (every 12hrs or so) with āfailed to allocate memoryā. After some trial and error, it was actually the termux boot causing an issue. Instead I now just open the bootscript manually instead of using the termux:boot app. I also pinned the termux app which hopefully also causes android to not reduce memory allowance. Its now been running smoothly for over a week or so.
Update: it worked fine for quite a while however storage limitations meant that I have switched to a mini pc with HAOS after reading many forum discussions. The easy updates and add-ons remove the headaches of supervised. Android is an easy platform to try if itās your thing however.
Hi! I tried to follow the guide, but unfortunately when I tried to run āpip install homeassistantā I got this error:
Could not build wheels for bcrypt, cryptography, orjson, which is required to install pyproject.toml-based projects
The device Iām trying to install on is a Samsung S9 with Android 10.
Could someone help me out? Thanks
I have an error due to lru-dict dependency, because it doesnāt work with python 3.11, any way to solve it?
`Ć Running setup.py install for lru-dict did not run successfully.
ā exit code: 1
ā°ā> [14 lines of output]
running install
/data/data/com.termux/files/usr/lib/python3.11/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
running build running build_ext
building 'lru' extension creating build
creating build/temp.linux-aarch64-cpython-311
aarch64-linux-android-clang -DNDEBUG -g -fwrapv -O3 -Wall -fstack-protector-strong -O3 -fstack-protector-strong -O3 -fPIC -I/data/data/com.termux/files/usr/include/python3.11 -c lru.c -o build/temp.linux-aarch64-cpython-311/lru.o
lru.c:629:17: error: incompatible function pointer types initializing 'PyCFunction' (aka 'struct _object *(*)(struct _object *, struct _object *)') with an expression of type 'PyCFunctionWithKeywords' (aka 'struct _object *(*)(struct _object *, struct _object *, struct _object *)') [-Wincompatible-function-pointer-types]
{"popitem", (PyCFunctionWithKeywords)LRU_popitem, METH_VARARGS | METH_KEYWORDS,
1 error generated.
error: command '/data/data/com.termux/files/usr/bin/aarch64-linux-android-clang' failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: legacy-install-failure
Ć Encountered error while trying to install package.
ā°ā> lru-dict
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.`
Hi @natsukiller,
The compilation error you shared is not related to Python 3.11 incompatibility. Itās because clang now detects function pointer mismatches (like GCC has done for ages).
Install a pre-release lru-dict by using:
pip install git+https://github.com/amitdev/lru-dict@5013406c409a0a143a315146df388281bfb2172d
To disable the incompatible pointer type warning, run:
CFLAGS=-Wno-incompatible-pointer-types pip install lru-dict
thank you it worked for me
My hack may cause segfaults. A proper solution is this:
Hello. i want to install ha on redmi s2. everything is installed, but when I try to start ha, it writes this:
(hass) ~ $ hass -v
Unable to find configuration. Creating default one in /data/data/com.termux/files/home/.homeassistant
2023-04-17 02:37:30.487 INFO (MainThread) [homeassistant.bootstrap] Config directory: /data/data/com.termux/files/home/.homeassistant
Bad system call
what do i need to do? Iām a complete zero in programming, I installed according to the instructions
PS: ha is 2023.4.4. all other packages are also the latest versions
PSS: lru-dict installing from āCFLAGS=-Wno-incompatible-pointer-types pip install lru-dictā
A couple of months ago I was able to follow @gj9159a instructions to get HomeAssistant working on LineageOS 20 on Xiaomi Redmi Note 7.
However, I found Lineage rather sluggish when memory was tight, and have reflashed with crDroid 9.1 on Redmi Note 7 (ASOP based ROM), but when I try to install Home Assistant, I get the massive error output shown below when I try to install numpy (Iāve cut out a large chunk of the repetitive stuff in the middle).
Can anyone indicate if this is a compatibility issue with whatever packages & if there is a way to resolve it? Or if its a fundamental problem with trying to do this on a non-LineageOS ROM and Iāll have to reflash?
(hass) ~ $ MATHLIB=m pip install numpy==1.24.2
Collecting numpy==1.24.2
Using cached numpy-1.24.2.tar.gz (10.9 MB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Building wheels for collected packages: numpy
Building wheel for numpy (pyproject.toml) ... error
error: subprocess-exited-with-error
Ć Building wheel for numpy (pyproject.toml) did not run successfully.
ā exit code: 1
ā°ā> [962 lines of output]
Running from numpy source directory.
setup.py:67: DeprecationWarning:
`numpy.distutils` is deprecated since NumPy 1.23.0, as a result
of the deprecation of `distutils` itself. It will be removed for
Python >= 3.12. For older Python versions it will remain present.
It is recommended to use `setuptools < 60.0` for those Python versions.
For more details, see:
https://numpy.org/devdocs/reference/distutils_status_migration.html
#lots of subsequent output, ending with the below
ret.c99_z = casinhl(z1.c99_z);
numpy/core/src/npymath/npy_math_complex.c.src:1765:17: note: include the header <complex.h> or explicitly provide a declaration for 'casinhl'
numpy/core/src/npymath/npy_math_complex.c.src:1765:17: error: call to undeclared library function 'catanhl' with type '_Complex long double (_Complex long double)'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
ret.c99_z = catanhl(z1.c99_z);
numpy/core/src/npymath/npy_math_complex.c.src:1765:17: note: include the header <complex.h> or explicitly provide a declaration for 'catanhl'
19 errors generated.
error: Command "aarch64-linux-android-clang -DNDEBUG -g -fwrapv -O3 -Wall -fstack-protector-strong -O3 -fstack-protector-strong -O3 -fPIC -ftrapping-math -Ibuild/src.linux-aarch64-3.11/numpy/core/src/npymath -Inumpy/core/include -Ibuild/src.linux-aarch64-3.11/numpy/core/include/numpy -Ibuild/src.linux-aarch64-3.11/numpy/distutils/include -Inumpy/core/src/common -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -Inumpy/core/src/_simd -I/data/data/com.termux/files/usr/include/python3.11 -Ibuild/src.linux-aarch64-3.11/numpy/core/src/common -Ibuild/src.linux-aarch64-3.11/numpy/core/src/npymath -c build/src.linux-aarch64-3.11/numpy/core/src/npymath/npy_math_complex.c -o build/temp.linux-aarch64-3.11/build/src.linux-aarch64-3.11/numpy/core/src/npymath/npy_math_complex.o -MMD -MF build/temp.linux-aarch64-3.11/build/src.linux-aarch64-3.11/numpy/core/src/npymath/npy_math_complex.o.d" failed with exit status 1
INFO:
########### CLIB COMPILER OPTIMIZATION ###########
INFO: Platform :
Architecture: aarch64
Compiler : clang
CPU baseline :
Requested : 'min'
Enabled : NEON NEON_FP16 NEON_VFPV4 ASIMD
Flags : none
Extra checks: none
CPU dispatch :
Requested : 'max -xop -fma4'
Enabled : ASIMDHP ASIMDDP ASIMDFHM
Generated : none
INFO: CCompilerOpt.cache_flush[857] : write cache to path -> /data/data/com.termux/files/usr/tmp/pip-install-omlvtrez/numpy_19147465a3e342479d58d27c5195b878/build/temp.linux-aarch64-3.11/ccompiler_opt_cache_clib.py
[end of output]
ERROR: Failed building wheel for numpy
Failed to build numpy
ERROR: Could not build wheels for numpy, which is required to install pyproject.toml-based projects
(hass) ~ $
pip list gives the below list of packages:
(hass) ~ $ pip list
Package Version
aiohttp 3.8.4
aiohttp-cors 0.7.0
aiosignal 1.3.1
async-timeout 4.0.2
attrs 23.1.0
cffi 1.15.1
charset-normalizer 3.1.0
cryptography 40.0.2
frozenlist 1.3.3
idna 3.4
maturin 0.14.17
multidict 6.0.4
pip 23.1
pycparser 2.21
setuptools 67.6.1
tzdata 2023.3
wheel 0.40.0
yarl 1.8.2
(hass) ~ $
Iām using Python 3.11.3
Hi @djdery,
Please uninstall lru-dict
, and reinstall using:
Hi @smithbill17,
I ran into this error on Lineage 19.x, so donāt think you need to re-flash.
If youāre using the packaged Termux python 3.11, then try: pkg i python-numpy
If not, youāll have to build a patched package from the termux-packages
repo.
Hello @talss89 .
I did everything as you said and in the end I get this:
(hass) ~ $ pip install git+https://github.com/amitdev/lru-dict@5013406c409a0a143a315146df388281bfb2172d
Collecting git+https://github.com/amitdev/lru-dict@5013406c409a0a143a315146df388281bfb2172d
Cloning https://github.com/amitdev/lru-dict (to revision 5013406c409a0a143a315146df388281bfb2172d) to /data/data/com.termux/files/usr/tmp/pip-req-build-du45fk9s
Running command git clone --filter=blob:none --quiet https://github.com/amitdev/lru-dict /data/data/com.termux/files/usr/tmp/pip-req-build-du45fk9s
Running command git rev-parse -q --verify 'sha^5013406c409a0a143a315146df388281bfb2172d'
Running command git fetch -q https://github.com/amitdev/lru-dict 5013406c409a0a143a315146df388281bfb2172d
Running command git checkout -q 5013406c409a0a143a315146df388281bfb2172d
Resolved https://github.com/amitdev/lru-dict to commit 5013406c409a0a143a315146df388281bfb2172d
Preparing metadata (setup.py) ... done
(hass) ~ $ pip list
Package Version
aiohttp 3.8.4
aiohttp-cors 0.7.0
aiosignal 1.3.1
anyio 3.6.2
astral 2.2
async-timeout 4.0.2
atomicwrites-homeassistant 1.4.1
attrs 22.2.0
awesomeversion 22.9.0
bcrypt 4.0.1
certifi 2022.12.7
cffi 1.15.1
ciso8601 2.3.0
cryptography 40.0.1
frozenlist 1.3.3
h11 0.14.0
home-assistant-bluetooth 1.9.3
homeassistant 2023.4.4
httpcore 0.16.3
httpx 0.23.3
idna 3.4
ifaddr 0.1.7
Jinja2 3.1.2
lru-dict 1.1.8
MarkupSafe 2.1.2
maturin 0.14.17
multidict 6.0.4
numpy 1.24.2
orjson 3.8.7
pip 23.1
pycparser 2.21
PyJWT 2.6.0
pyOpenSSL 23.1.0
python-slugify 4.0.1
PyTurboJPEG 1.7.0
pytz 2023.3
PyYAML 6.0
requests 2.28.2
rfc3986 1.5.0
setuptools 67.6.1
sniffio 1.3.0
text-unidecode 1.3
typing_extensions 4.5.0
tzdata 2023.3
ulid-transform 0.6.3
urllib3 1.26.15
voluptuous 0.13.1
voluptuous-serialize 2.6.0
wheel 0.40.0
yarl 1.8.1
(hass) ~ $ hass -v
2023-04-17 12:28:10.337 INFO (MainThread) [homeassistant.bootstrap] Config directory: /data/data/com.termux/files/home/.homeassistant
Bad system call
You need to remove lru-dict
first.
Try:
pip uninstall lru-dict
then:
(hass) ~ $ pip uninstall lru-dict
Found existing installation: lru-dict 1.1.8
Uninstalling lru-dict-1.1.8:
Would remove:
/data/data/com.termux/files/usr/lib/python3.11/site-packages/lru.cpython-311.so
/data/data/com.termux/files/usr/lib/python3.11/site-packages/lru_dict-1.1.8.dist-info/*
Proceed (Y/n)? y
Successfully uninstalled lru-dict-1.1.8
Cloning https://github.com/amitdev/lru-dict (to revision 5013406c409a0a143a315146df388281bfb2172d) to /data/data/com.termux/files/usr/tmp/pip-req-build-fv_k_o5d
Running command git clone --filter=blob:none --quiet https://github.com/amitdev/lru-dict /data/data/com.termux/files/usr/tmp/pip-req-build-fv_k_o5d
Building wheels for collected packages: lru-dict
Building wheel for lru-dict (setup.py) ... done
Created wheel for lru-dict: filename=lru_dict-1.1.8-cp311-cp311-linux_armv7l.whl size=22808 sha256=5c14a44f0cd119ab7e7c61f5e3413ee1090090d707ff6472f3eb1297bd38298d
Stored in directory: /data/data/com.termux/files/home/.cache/pip/wheels/06/a3/a4/1451203259031f09c1d125226a23d74f822a56c09c33bca1ce
Successfully built lru-dict
Installing collected packages: lru-dict
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
homeassistant 2023.4.4 requires pip<23.1,>=21.0, but you have pip 23.1 which is incompatible.
Successfully installed lru-dict-1.1.8
(hass) ~ $ hass -v
2023-04-17 12:55:18.002 INFO (MainThread) [homeassistant.bootstrap] Config directory: /data/data/com.termux/files/home/.homeassistant
Bad system call
````(hass) ~ $ pip install pip==23.0.1
Collecting pip==23.0.1
Using cached pip-23.0.1-py3-none-any.whl (2.1 MB)
Installing collected packages: pip
Attempting uninstall: pip
Found existing installation: pip 23.1
Uninstalling pip-23.1:
Successfully uninstalled pip-23.1
Successfully installed pip-23.0.1
[notice] A new release of pip is available: 23.0.1 -> 23.1
[notice] To update, run: pip install --upgrade pip
(hass) ~ $ hass -v
2023-04-17 12:57:53.419 INFO (MainThread) [homeassistant.bootstrap] Config directory: /data/data/com.termux/files/home/.homeassistant
Bad system call`
[notice] A new release of pip is available: 23.0.1 ā 23.1
(hass) ~ $ hass -v
Bad system call
