run: rustc -vV | sed -n 's|host: ||p' it returns target system, something like: armv7-linux-androideabi copy it and set to cargo running: export CARGO_BUILD_TARGET=armv7-linux-androideabi
from homeassistant==2021.12.X versions, needs cryptography==35.0.0 but install with this method fail. However installation succes for cryptography==36.0.0 which is incompatible with homeassistant==2021.12.X
if you want to upgrade from homeassistant==2021.11.5 you can overide cryptography==35.0.0 with cryptography==36.0.0 following method described above and modifiying cryptography line on package_constraints.txt copiying from source code and creating a local file placed on /data/data/com.termux/files/home/homeassistant/package_constraints.txt and running:
I followed your guideline. However I got a lot of error messages during the execution of the sequence of commands.
Finally given the hass -v command, but no results.
I bought a Samsung a7 lite. Are the commands shown also valid for the Tablet a7?
I hope you can help me any further.
Thx in advance.
Had some issues. This is how I installed it on Termux:
# If you get errors run: "termux-change-repo" and change the sources mirrors to ex. termux.me
pkg update
# Upgrade current packages
pkg upgrade -y
# Install required packages
pkg install nano openssh termux-api make libjpeg-turbo wget rust python -y
# Export build target for Rust
export CARGO_BUILD_TARGET="$(rustc -Vv | grep "host" | awk '{print $2}')"
# There's a bug where python 3.10 is being detected as lower than 3.6 (minimumn build version)
# Will cause error: cargo failed with code: 101
# Remove python 3.10 (But keep dependencies)
pkg remove python -y
# We have to install python 3.9.7, but we need to know the system architecture first
# Get your current architecture, based on that choose the next step
echo $CARGO_BUILD_TARGET
# Choose only one, based on the architecture you got (arm or aarch64)
# For arm
wget https://raw.githubusercontent.com/Termux-pod/termux-pod/main/arm/python/python-3.9.7/python_3.9.7_arm.deb
dpkg -i python_3.9.7_arm.deb
# For aarch64
wget https://raw.githubusercontent.com/Termux-pod/termux-pod/main/aarch64/python/python-3.9.7/python_3.9.7_aarch64.deb
dpkg -i python_3.9.7_aarch64.deb
# Upgrade pip
pip install --upgrade pip
# Install homeassistant
pip install wheel homeassistant
Still, lots of errors when starting hass which Iām trying to solve.
Canāt build numpy wheel for python 3.9.7 but success for python 3.10.2 likewise cant build cryptography==35.0.0 wheel for python 3.10.2 but succes for python 3.9.7
Not sure if itās because of this, but I managed to build numpy 1.22.2 with python 3.9.7. Could be because of the aarch64 architecture, though.
This coupled with the previous help about cargo to build cryptography 35.0.0, I managed to get HA 2022.2 running on my Lenovo m10!
One thing though, for me it refused to start because of a missing component library: "libzstd.so.1" not found. This caused āimageā to not load, then person, then frontend, so basically nothing could launch.
I fixed this with installing it manually: pip install zstd.
I still have to solve PyNaCl not building, so for now I donāt have mobile_app working. But at least the rest is fine.
I also canāt install numpy==1.22.2 with Python 3.9.7
For PyNaCl this worked for me:
(hass) ~ $ SODIUM_INSTALL=system pip install pynacl==1.4.0
Collecting pynacl==1.4.0
Using cached PyNaCl-1.4.0.tar.gz (3.4 MB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing wheel metadata ... done
Requirement already satisfied: six in ./hass/lib/python3.9/site-packages (from pynacl==1.4.0) (1.16.
Requirement already satisfied: cffi>=1.4.1 in ./hass/lib/python3.9/site-packages (from pynacl==1.4.0(1.15.0)
Requirement already satisfied: pycparser in ./hass/lib/python3.9/site-packages (from cffi>=1.4.1->pycl==1.4.0) (2.21)
Building wheels for collected packages: pynacl
Building wheel for pynacl (PEP 517) ... done
Created wheel for pynacl: filename=PyNaCl-1.4.0-cp39-cp39-linux_armv7l.whl size=191568 sha256=292bf96e7a90809d6aac71e41f678d8774980e134e34b16b7faf4f024d8947
Stored in directory: /data/data/com.termux/files/home/.cache/pip/wheels/3b/bb/4f/1cac0cbc50558d501046fb2942596ca9004b1055553856b8
Successfully built pynacl
Installing collected packages: pynacl
Successfully installed pynacl-1.4.0
Edit:
Finally i could install numpy on python 3.9.7 without building it. I Just downloading a wheel from piwheels.org for correct python version and system arch, and installing it locally using pip.
In spite of that wheel is for Bullseye and not for android, for the time being, hass starting and works fine except for some reason i cant run hass as daemon hass --daemon it show error: unrecognized arguments: --daemon . Then when i restart hass from hass ui the system not restart
Iām currently trying out daemonize, installed via pkg install daemonize. Seems to work so far.
PyNaCl is not installing for me, something about missing sodium.h. Iāll have to check it further later.
Edit: Ok, a pkg install libsodium helped with that one.
I didnāt configure anything really, I just launched the app with it (you need a full path): daemonize /data/data/com.termux/files/home/hass/bin/hass
It seems to work so far, I havenāt really wondered more to be honest and I havenāt checked how it launched with the venv, I just did the usual source hass/bin/activate before. Though I assume that if something was not on the venv it would have taken much longer to launch.
Hi, has anyone been able to install the latest version with termux? what packages have you used (nexus 7) or what version of HASS and packages are correct? i am using LineageOs 18 (Android 11).
For the record, Iāve just updated to 2022.4.1 without issues on upgrade. That said, I got issues with PyNaCl when starting, not finding ld in the path for some reason: checking for ld used by aarch64-linux-android-clang... no
@Ritual I have not encountered errors related to this package.
Do you have more details about the error, a longer log message perhaps? Also, try to give more details on your configuration (tablet, system, etc)
I was trying to install it on oneplus x.
I wanted to try before i buy a raspberry and install on it.
But with no luck.
I tried it on lineage(Android 11) and rr remix Android 7
I got many different errors on both those roms.
I got the previous error which i posted from the playstore version,which got resolved once i downloaded the apk from github.
I got many errors after that and i tried resolving it for few hours and ultimately gave up.
Thank you tho.
