Home Assistant Core on Android Tablet
ahh nice, tried to to downgrade too but couldnt find old python installers for termux.
Nevertheless, I managed to get the @dev of HA 11/29/22 working with Python 3.11 in termux (Galaxy S5). Its accessible on http://192.168.x.x:8123
Steps:
I now downloaded the latest @dev version of HA, as the requirements.txt is updated for aiohttp 3.8.1 (which doesnt work for python 3.11) to 3.8.3. See Update aiohttp to 3.8.3 by frenck · Pull Request #78860 · home-assistant/core · GitHub
Local install with something like pip install -e folder homeassistant
after that, start hass started
during start, it hangs at installing PyTurboJPEG
(fixing ystemError: One of the required function to build numpy is not available (the list is [‘sin’, ‘cos’, ‘tan’, ‘sinh’, ‘cosh’, ‘tanh’, ‘fabs’, ‘floor’, ‘ceil’, ‘sqrt’, ‘log10’, ‘log’, ‘exp’, ‘asin’, ‘acos’, ‘atan’, ‘fmod’, ‘modf’, ‘frexp’, ‘ldexp’])
fix is running: MATHLIB=“m” pip3 install PyTurboJPEG==1.6.7
same for numpy: MATHLIB=“m” pip3 install numpy
BTW. The process of starting hass with more installs during its boot, takes quite some time.
few errors left like CRITICAL : Can’t open /proc/net/dev and Can’t open* /proc/net/route but these see no dealbreakers for running HA clients
Hi thanks for the tips. I have downgraded phyton, and have try to install homeassistant but now i have a completely different error during the installation
try apt install libpython3.9-devapt install libpython3.10-dev
I have the same Issue and apt install libpython3.9-devapt install libpython3.10-dev dont work.
Hey guys, new here, sorry if my question was already answered, but i’m having problems trying to install HA on my old Galaxy Tab A 10.1 (2016).
Sorry for my dumb linux-related questions, but is my first time working with it.
When trying to install HA (using this tutorial), i get the following error on the orjson part (i believe it’s a rust compiler error, correct me if i’m wrong)
Log:
~ $ python -m venv hass
~ $ source hass/bin/activate
(hass) ~ $ pip install homeassistant
Collecting homeassistant
  Using cached homeassistant-2022.12.0-py3-none-any.whl (20.6 MB)
Collecting aiohttp==3.8.3
  Using cached aiohttp-3.8.3.tar.gz (7.3 MB)
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
  Installing backend dependencies ... done
  Preparing metadata (pyproject.toml) ... done
Collecting astral==2.2
  Using cached astral-2.2-py2.py3-none-any.whl (30 kB)
Collecting async-timeout==4.0.2
  Using cached async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
Collecting attrs==21.2.0
  Using cached attrs-21.2.0-py2.py3-none-any.whl (53 kB)
Collecting atomicwrites-homeassistant==1.4.1
  Using cached atomicwrites_homeassistant-1.4.1-py2.py3-none-any.whl (7.1 kB)
Collecting awesomeversion==22.9.0
  Using cached awesomeversion-22.9.0-py3-none-any.whl (12 kB)
Collecting bcrypt==3.1.7
  Using cached bcrypt-3.1.7.tar.gz (42 kB)
Collecting certifi>=2021.5.30
  Using cached certifi-2022.12.7-py3-none-any.whl (155 kB)
Collecting ciso8601==2.2.0
  Using cached ciso8601-2.2.0.tar.gz (18 kB)
Collecting httpx==0.23.1
  Using cached httpx-0.23.1-py3-none-any.whl (84 kB)
Collecting home-assistant-bluetooth==1.8.1
  Using cached home_assistant_bluetooth-1.8.1.tar.gz (10 kB)
Collecting ifaddr==0.1.7
  Using cached ifaddr-0.1.7-py2.py3-none-any.whl (10 kB)
Collecting jinja2==3.1.2
  Using cached Jinja2-3.1.2-py3-none-any.whl (133 kB)
Collecting lru-dict==1.1.8
  Using cached lru-dict-1.1.8.tar.gz (10 kB)
  Preparing metadata (setup.py) ... done
Collecting PyJWT==2.5.0
  Using cached PyJWT-2.5.0-py3-none-any.whl (20 kB)
Collecting cryptography==38.0.3
  Using cached cryptography-38.0.3.tar.gz (599 kB)
Collecting orjson==3.8.1
  Using cached orjson-3.8.1.tar.gz (860 kB)
  Installing build dependencies ... error
  error: subprocess-exited-with-error
  × pip subprocess to install build dependencies did not run successfully.
  │ exit code: 1
  ╰─> [56 lines of output]
      Collecting maturin<0.14,>=0.13
        Using cached maturin-0.13.7.tar.gz (154 kB)
        Installing build dependencies: started
        Installing build dependencies: finished with status 'done'
        Getting requirements to build wheel: started
        Getting requirements to build wheel: finished with status 'done'
        Preparing metadata (pyproject.toml): started
        Preparing metadata (pyproject.toml): finished with status 'done'
      Building wheels for collected packages: maturin
        Building wheel for maturin (pyproject.toml): started
        Building wheel for maturin (pyproject.toml): finished with status 'error'
        × Building wheel for maturin (pyproject.toml) did not run successfully.
        │ exit code: 1
        ╰─> [34 lines of output]
            running bdist_wheel
            running build
            running build_py
            creating build
            creating build/lib.linux-aarch64-cpython-311
            creating build/lib.linux-aarch64-cpython-311/maturin
            copying maturin/__init__.py -> build/lib.linux-aarch64-cpython-311/maturin
            copying maturin/import_hook.py -> build/lib.linux-aarch64-cpython-311/maturin
            copying maturin/__main__.py -> build/lib.linux-aarch64-cpython-311/maturin
            running egg_info
            creating maturin.egg-info
            writing maturin.egg-info/PKG-INFO
            writing dependency_links to maturin.egg-info/dependency_links.txt
            writing requirements to maturin.egg-info/requires.txt
            writing top-level names to maturin.egg-info/top_level.txt
            writing manifest file 'maturin.egg-info/SOURCES.txt'
            reading manifest file 'maturin.egg-info/SOURCES.txt'
            reading manifest template 'MANIFEST.in'
            running build_ext
            running build_rust
            error: rustup could not choose a version of rustc to run, because one wasn't specified explicitly, and no default is configured.
            help: run 'rustup default stable' to download the latest stable release of Rust and set it as your default toolchain.
            error: can't find Rust compiler
            If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
            To update pip, run:
                pip install --upgrade pip
            and then retry package installation.
            If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
            [end of output]
        note: This error originates from a subprocess, and is likely not a problem with pip.
        ERROR: Failed building wheel for maturin
      Failed to build maturin
      ERROR: Could not build wheels for maturin, which is required to install pyproject.toml-based projects
      [end of output]
│ exit code: 1
╰─> See above for output.
(hass) ~ $
Tried (no sucess)
What should i do?
try this
pkg upgrade
pkg install python nano make rust libcrypt libffi libjpeg-turbo binutils
python -m venv hass
pip install wheel
pip install tzdata
pip install maturin
MATHLIB=m pip install numpy
MATHLIB=m pip install PyTurboJPEG==1.6.7
export RUSTFLAGS="-C lto=n"
export CARGO_BUILD_TARGET="$(rustc -Vv | grep "host" | awk '{print $2}')"
export CRYPTOGRAPHY_DONT_BUILD_RUST=1
pip install homeassistant==2022.12.0
hass -v
Hey man, thanks for getting back to me.
I followed your steps and everything was going as per normal. However, upon installing maturin, i got a similar error (can’t find Rust compiler)
~ $ pkg upgrade
No mirror or mirror group selected. You might want to select one by running 'termux-change-repo'
Testing the available mirrors:
[*] (10) https://packages-cf.termux.dev/apt/termux-main: ok
[*] (1) https://mirrors.cbrx.io/apt/termux/termux-main: ok
[*] (1) https://linux.domainesia.com/applications/termux/termux-main: ok
[*] (1) https://mirror.bardia.tech/termux/termux-main: ok
[*] (1) https://mirror.nevacloud.com/applications/termux/termux-main: bad
[*] (1) https://mirror.albony.xyz/termux/termux-main: ok
[*] (1) https://packages.nscdn.top/termux-main: bad
[*] (1) https://mirrors.sdu.edu.cn/termux/termux-main: ok
[*] (1) https://mirrors.sau.edu.cn/termux/apt/termux-main: bad
[*] (1) https://mirrors.ustc.edu.cn/termux/apt/termux-main: ok
[*] (1) https://mirrors.cqupt.edu.cn/termux/apt/termux-main: ok
[*] (1) https://mirrors.nju.edu.cn/termux/apt/termux-main: ok
[*] (1) https://mirrors.pku.edu.cn/termux/termux-main/: bad
[*] (1) https://mirrors.njupt.edu.cn/termux/apt/termux-main: ok
[*] (1) https://mirrors.bfsu.edu.cn/termux/apt/termux-main: ok
[*] (1) https://mirrors.dgut.edu.cn/termux/apt/termux-main: bad
[*] (1) https://mirrors.hit.edu.cn/termux/apt/termux-main: ok
[*] (1) https://mirror.iscas.ac.cn/termux/apt/termux-main: ok
[*] (1) https://mirror.nyist.edu.cn/termux/apt/termux-main: ok
[*] (1) https://mirrors.scau.edu.cn/termux/apt/termux-main: ok
[*] (1) https://mirrors.aliyun.com/termux/termux-packages-24: bad
[*] (1) https://mirrors.sustech.edu.cn/termux/apt/termux-main: ok
[*] (1) https://mirrors.tuna.tsinghua.edu.cn/termux/apt/termux-main: ok
[*] (1) https://termux.3san.dev/termux/termux-main: ok
[*] (1) https://mirrors.sahilister.in/termux/termux-main: ok
[*] (1) https://termux.cdn.lumito.net/termux-main: ok
[*] (1) https://termux.librehat.com/apt/termux-main: ok
[*] (1) https://mirror.accum.se/mirror/termux.dev/termux-main: ok
[*] (1) https://mirror.termux.dev/termux-main: ok
[*] (1) https://termux.astra.in.ua/apt/termux-main: ok
[*] (4) https://grimler.se/termux/termux-main: ok
[*] (1) https://termux.mentality.rip/termux-main: ok
[*] (1) https://mirror.mwt.me/termux/main: ok
[*] (1) https://mirrors.utermux.dev/termux/termux-main: ok
[*] (1) https://plug-mirror.rcac.purdue.edu/termux/termux-main: ok
[*] (1) https://dl.kcubeterm.com/termux-main: ok
[*] (1) https://mirror.fcix.net/termux/termux-main: ok
[*] (1) https://mirror.vern.cc/termux/termux-main: ok
[*] (1) https://mirror.csclub.uwaterloo.ca/termux/termux-main: ok
[*] (4) https://packages.termux.dev/apt/termux-main: ok
[*] (1) https://mirror.surf/termux/termux-main/: ok
[*] (1) http://mirror.mephi.ru/termux/termux-main: ok
Picking mirror: (17) /data/data/com.termux/files/usr/etc/termux/mirrors/china/mirrors.nju.edu.cn
Get:1 https://mirrors.nju.edu.cn/termux/apt/termux-main stable InRelease [14.0 kB]
Get:2 https://mirrors.nju.edu.cn/termux/apt/termux-main stable/main aarch64 Packages [435 kB]
Fetched 449 kB in 2min 22s (3154 B/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
~ $ pkg install python nano make rust libcrypt libffi libjpeg-turbo binutils
Checking availability of current mirror:
[*] https://mirrors.nju.edu.cn/termux/apt/termux-main: ok
python is already the newest version (3.11.1).
nano is already the newest version (7.0).
make is already the newest version (4.4).
rust is already the newest version (1.65.0).
libcrypt is already the newest version (0.2-5).
libffi is already the newest version (3.4.4).
libffi set to manually installed.
libjpeg-turbo is already the newest version (2.1.4).
binutils is already the newest version (2.39-4).
(hass) ~ $ pip install --upgrade pip
Requirement already satisfied: pip in ./hass/lib/python3.11/site-packages (22.3.1)
(hass) ~ $ pip install wheel
Requirement already satisfied: wheel in ./hass/lib/python3.11/site-packages (0.38.4)
(hass) ~ $ pip install tzdata
Collecting tzdata
  Downloading tzdata-2022.7-py2.py3-none-any.whl (340 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 340.1/340.1 kB 4.5 MB/s eta 0:00:00
Installing collected packages: tzdata
Successfully installed tzdata-2022.7
(hass) ~ $ pip install maturin
Collecting maturin
  Using cached maturin-0.14.5.tar.gz (170 kB)
  Building wheel for maturin (pyproject.toml) ... error
  │ exit code: 1
      running bdist_wheel
      running build
      running build_py
      creating build
      running egg_info
      running build_ext
      running build_rust
      To update pip, run:
      [end of output]
(hass) ~ $
Should i continue with the steps?
Thank you bro it worked
try to reinstall termux
also no problems with HA 2022.12.1 instead of 2022.12.0
Able to compile ginko kernel (xiomi note 8) with additional flags. Now I have HA core in docker containers in Termux.
script for checking kernel config
Hi!
I managed to install all the necessary things ( in theory)
wen i try HASS - V this fail every time with this line
I’ve try to get root and i have already gave permission to the storage.
have any tips?
I’ll refer you to my previous message Home Assistant Core on Android Tablet - #110 by Gnoupi
I don’t see a failure in your log. Well, there is a failure to access some core data that could be used to monitor the system, but I have that as well. Termux just does not allow access to those. It does not prevent HA from functioning, though.
So try to launch it again, give it time to install some sub-dependencies in the back, and monitor CPU activity on side if you have doubts that anything is happening with it.
I was successfully able to install home assistant 2022.12.2 on a Teclast P80X android tablet using these steps, thank you!
I needed two additional steps though.
  1. Cargo kept crashing with a SIGKILL on my tablet due to running out of memory during building (2GB ram). I needed to restrict the number of parallel tasks to 1 by calling:
export CARGO_BUILD_JOBS=1
  1. I forced aiohttp to >3.8.1 by the following two commands:
echo "aiohttp>=3.8.2" > constraints.txt
pip install -c constraints.txt homeassistant
Hi all. Thanks for this great guide. One topic seems to be missing: How to make automations work in time, which are prevented by sleeping of the home assistant server because of energy saving of your android device.
I didn’t find a solution, yet. Maybe one of you has a good idea?
Problem description: If I program an automation, which should be triggered at a certain time, it does not start at this specific time but at least 10 minutes later - sometimes hours later. (the phone time is set correctly, also the command “date” in termux outputs the correct time.) I have the impression that the automation is not running until I use my phone, unlock the screen and it wakes up. Then after several minutes the automation is triggered. The dashboard however, is responsive. I believe this could be related to energy saving mode of my phone. I tried to set in the LineageOS settings the termux app to “do not optimize battery”, but this didn’t make a difference. I’m using LineageOS 17.1 on an old Samsung Galaxy S5 neo.
What can I do?
Edit: I was studying the logs and found following warning entry which has been mentioned above. However, I don’t understand it. Is there a relation to the issue? Maybe it’s not related to the device beeing in energy saving mode. I also found plenty of other forum entries discussing the delay issue, however without solution.
2022-12-26 16:32:27.420 WARNING (SyncWorker_3) [pyroute2.netlink.rtnl.tcmsg.common] tcmsg: [Errno 13] Permission denied: '/proc/net/psched'
2022-12-26 16:32:27.477 WARNING (SyncWorker_3) [pyroute2.netlink.rtnl.tcmsg.common] the tc subsystem functionality is limited
Edit2:
I also created a date & time sensor entity for testing purposes by inserting following in the configuration.yaml:
  - platform: time_date
    display_options: 'date_time'
I placed it on my dashboard and learned that it also updates very irregularly and is always several minutes late:
date_time
I think this might be related to the automations not trigger in time.
Edit3: After reading and investigating a lot, I think there is a general issue running home assistant on android 10 and above with termux, because since android 10, the permission to access /proc/net/ is denied.
This is what I found additionally in my home-assistant.log
2022-12-26 20:47:10.402 CRITICAL (SyncWorker_3) [scapy.loading] Can't open /proc/net/dev !
2022-12-26 20:47:10.709 CRITICAL (SyncWorker_3) [scapy.loading] Can't open /proc/net/route !
2022-12-26 20:47:10.765 CRITICAL (SyncWorker_3) [scapy.loading] Can't open /proc/net/dev !
2022-12-26 20:47:13.463 WARNING (SyncWorker_2) [pyroute2.netlink.rtnl.tcmsg.common] tcmsg: [Errno 13] Permission denied: '/proc/net/psched'
2022-12-26 20:47:13.491 WARNING (SyncWorker_2) [pyroute2.netlink.rtnl.tcmsg.common] the tc subsystem functionality is limited
I don’t see a workaround on non rooted devices.
Edit4: I think I found a solution. All automations work now in time if you follow the steps discussed here:
link to reddit/r/termux
Thanks to u/agnostic-apollo, I found a working solution, I try to summarize here:
  • In LineageOS settings: activate android-debugging, root-debugging and adb over network
  • In termux: pkg install android-tools, and connect it with adb connect, verify with adb devices and test if you can access /proc/net/psched within adb shell
  • edit in file (which belongs to the home assistant’s venv !!!) “lib/python3.11/site-packages/pyroute2/netlink/rtnl/tcmsg/common.py”
replace
with open('/proc/net/psched', 'r') as psched:
[t2us, us2t, clock_res, wee] = [
int(i, 16) for i in psched.read().split()
with
psched=os.popen('adb shell cat /proc/net/psched').read().rstrip('\n')
int(i, 16) for i in psched.split()
  • finally, to prevent your phone from falling into deep sleep, it is necessary to run termux-wake-lock
With these steps home assistants automations should work in time, if you run it on an android phone within termux.
Thank you! This (post 169) worked for me with homeassistant==2022.12.0 (but not with 2022.12.1).
Im using a tablet with android 10 (unrooted).
For those having trouble installing numpy and cryptography under termux, this packages need to be installed via pkg to avoid compilation errors:
pkg install python-numpy python-cryptography
https://wiki.termux.com/wiki/Python#Package_management
An installation option with which you can use the latest version of Home assistant (now it’s homeassistant==2023.2.3). My device: 32 GB ROM, 2 GB RAM, Android 7.1.2.
#If some package failed to download or assemble, then you need to repeat the command again (maybe even several times).
apt update
apt upgrade
pkg install openssh
passwd #setting the password
sshd #go to kitty/putty on PC
termux-setup-storage #confirm on the device
pkg install tsu python nano termux-api make libjpeg-turbo make rust python-cryptography libcrypt libffi binutils mosquitto wget -y
python -m venv --without-pip hass
pip install wheel
pip install tzdata
pip install maturin
pip install setuptools
MATHLIB=m pip install aiohttp_cors==0.7.0
MATHLIB=m pip install numpy==1.24.2
pip download homeassistant==2023.2.3
wheel unpack homeassistant-2023.2.3-py3-none-any.whl
nano homeassistant-2023.2.3/homeassistant/package_constraints.txt
#We are looking for aiohttp and change its version to 3.8.3, as well as numpy to version 1.24.2, then press CTRL-X, Y, ENTER.
nano homeassistant-2023.2.3/homeassistant-2023.2.3.dist-info/METADATA
#We are looking for aiohttp and change its version to 3.8.3, press CTRL-X, Y, ENTER.
rm homeassistant-2023.2.3-py3-none-any.whl
wheel pack homeassistant-2023.2.3
pip install homeassistant-2023.2.3-py3-none-any.whl
hass -v
#wait 5 minutes and restart the device
source hass/bin/activate #don't forget to activate the environment
hass -v #after a couple of minutes, you can try to log in
#if you need FTP access, then:
pkg install busybox termux-services
source $PREFIX/etc/profile.d/start-services.sh
sv-enable ftpd
sv up ftpd #to disable: sv down ftpd
Thanks to all guys who commented previously.
For the latest HA build, to solve aiohttp (==3.8.1) incompatibility with python 3.11 , see below:
#Downgrade to python3.10
pkg install tur-repo
pkg update
pkg install python3.10
pkg install python-is-python3.10
I have an old Allview phone unrooted Andoird 7.0 (RAM=2GB) and getting daily crashes of Termux 0.118.0 (F-droid). I reduced the number of Termux crashes with Termux:Boot uninstall.
Do you have similar problems ?
@gj9159a Thank you very much for these detailed explanation. It worked for me on a Samsung Galaxy Tab S2.
Hello everyone.
I was able to run Home Assistant 2023.2.3 server on Xiaommi Mi A2 Lite (android 10).
But I ran into the same problem as @Gnoupi in GitHub issue - tons of thousands of error messages about BaseSelectorEventLoop._accept_connection after internet disconnected.
Can someone suggest how to fix this?
