I’m getting some fantastic suggestions here in the forum as well as on Github.
I’d like to implement them all and I also have some stuff in mind.
The problem is, that I’m doing a full-time study as well as a full-time job (in a startup) at the moment , so I have much less time for the project than I would like to have.
Nevertheless I will try to release new versions on a regular basis, it might just take a while sometimes.
Thank you for all the nice and motivating feedback btw.
That’s really what keeps the project going!
I just uploaded a new version. It contains tons of bugfixes.
Also a major security issue was found in the version of electron, that I used. The new version is not affected, so I recommend to update quickly. Version 1.10 is safe, older versions are potentially vulnerable.
If you failed to login, you could go to preferences (via the go-menu) and reset the configuration (in case your password was wrong). If this does’t help I would need some more information to fix the issue:
Do you connect to HomeAssistant via http or https
Do you connect directly via IP/Hostname or DynDNS
Whatt app/HomeAssistant/Windows- Version do you use
no problem, im connecting via htpps, direct from ip https://ip:8123 , im using the latest version 1.1, hassio 0.63.3 and windows 10 1709, hope you can help
Hi i managed to get it working, disabling the HTTPS, i use the conversation component so i need htpps and i can’t port forward my router so i can’t conect to https://user.duckdns.org , insted i use https://IP:8123, so i Guess that’s why i can’t enter like that, Is there a way to get it working with https://IP:8123 ?, It’s a great app so far, one more thing i get a grey bar at the bottom of the page, it would be great to disable this, and hide, the, developer bar too
