Home Assistant for iOS 2.0 Beta Testing
What device are you on?
What does it say for “Connecting via” in the Connection settings screen?
Remote UI.
Try disabling remote UI and force quitting the app.
says now: “External URL”.
Should i re-enable remote UI and try again?
iPhone X, HA 0.92, nabu casa remote UI, have tried reinstalling the app and rebooting the phone
Please ensure Remote UI is turned on if you have it.
Yeah, sure
Are you doing manual setup or automatic setup?
Same. Shows Connecting Via Remote UI, i turn off Wifi, won’t connect (screenshot). I try connecting via web browser to the Nabu Casa generated URL and all works.
Manual config, I’m on 4G right now so can’t test automatic
There may be an issue with manual setup still if you don’t enter a string that can be converted to a URL. Ensure it is of the format "https://hassio.local:8123l. Must have protocol (http or https), hostname and port (if port isn’t 80 or 443)
Okay. Will fix tomorrow morning, about to go to bed.
great, thanks man. Please let me know if you need anything to help debug it.
Figured it out! I accidentally had https://myhomeassistantstring.ui.nabu.casa/ got to the login screen but not any further, when I removed the “/” it worked!
Mine now starts up, and asks me to login. I do that, i get the http popup which then brings me back to the connect button. After that it just hangs on the the url to my site. We will see tomorrow :slight_smile:
Anyone else unable to get the app to setup the sensors, getting this error in my log:
2019-04-29 10:12:59 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update non-registered sensor: f49880421f22187ef8bacc6020f06454f9ca332b89b9fe7417324ce0c1ce556f_connectivity_ssid 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor activity! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor battery_state! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor battery_level! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor pedometer_distance! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor pedometer_floors_ascended! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor pedometer_steps! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor connectivity_bssid! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor connectivity_connection_type! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor connectivity_cellular_provider_0000000100000001! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor last_update_trigger! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor geocoded_location! 2019-04-29 10:13:00 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to re-register existing sensor activity!
Thanks for your hard work, @robbiet480 - can you advise if there are any fixes planned for the location element of the app? :slight_smile: :slight_smile:
Excellent job with the update. I appreciate your hard work.
All went smoothly with the update.
Siri shortcut works but generates an error, as per screenshot below.
latest update is working very nicely! Only issue i seem to have is with notification.
When sending a notification i get: 2019-04-29 12:58:33 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found.
once in while 1 comes trough but 99% doenst :wink:
The few that get trough are always with the app active.
