This is a Blueprint for Home Assistant for the Xiaomi Aqara double key wall switch using zigbee2mqtt.
Unlike in this Blueprint all actions can be configured freely.
As suggested in the documentation, the device has to be updated to the non legacy mode in zigbee2mqtt.
This can be done with the following by adding the line legacy: false
in the zigbee2mqtt configuration file as described in the documentation.
blueprint:
name: Aqara Double Key Switch
description: 'Blueprint for Home Assistant for the Xiaomi Aqara double key wireless wall switch using zigbee2mqtt.'
domain: automation
input:
switch:
description: Action sensor of Aqara Wireless Switch to use
selector:
entity:
domain: sensor
integration: mqtt
press_single_left:
name: Single left button press
description: Action to run on single left button press
default: []
selector:
action: {}
press_double_left:
name: Double left button press
description: Action to run on double left button press
default: []
selector:
action: {}
press_hold_left:
name: Hold left button
description: Action to run on holding left button
default: []
selector:
action: {}
press_single_right:
name: Single right button press
description: Action to run on single right button press
default: []
selector:
action: {}
press_double_right:
name: Double right button press
description: Action to run on double right button press
default: []
selector:
action: {}
press_hold_right:
name: Hold right button
description: Action to run on holding right button
default: []
selector:
action: {}
press_single_both:
name: Single both buttons press
description: Action to run on single both button press
default: []
selector:
action: {}
press_double_both:
name: Double both buttons press
description: Action to run on double both button press
default: []
selector:
action: {}
press_hold_both:
name: Hold both buttons
description: Action to run on holding both buttons
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: state
entity_id: !input switch
- variables:
command: "{{ trigger.to_state.state }}"
- choose:
- conditions:
- "{{ command == 'single_left' }}"
sequence: !input press_single_left
- conditions:
- "{{ command == 'double_left' }}"
sequence: !input press_double_left
- conditions:
- "{{ command == 'hold_left' }}"
sequence: !input press_hold_left
- conditions:
- "{{ command == 'single_right' }}"
sequence: !input press_single_right
- conditions:
- "{{ command == 'double_right' }}"
sequence: !input press_double_right
- conditions:
- "{{ command == 'hold_right' }}"
sequence: !input press_hold_right
- conditions:
- "{{ command == 'single_both' }}"
sequence: !input press_single_both
- conditions:
- "{{ command == 'double_both' }}"
sequence: !input press_double_both
- conditions:
- "{{ command == 'hold_both' }}"
sequence: !input press_hold_both
Screenshot:
