This blueprint is for the double switch WXKG02LM. It is used to toggle lights on left, right and both. and also the double click left and right changes mireds in 5 steps, looping back to the minimum allowed.
I used @starbuck93’s ikea 5button zigbee2mqtt’s blueprint as inspiration which again is based on @frenck’s zha version
It uses an input_select to determine time of day, blueprint is currently using dutch values: overdag, avond & nacht. Based on those values lights are turned on at a certain brightness.
blueprint:
name: aqara double switch to control Light
description: perform actions on light when button is clicked
domain: automation
input:
switch_entity:
name: Switch action Sensor
description: aqara mqtt action sensor, don't use the click sensor for the switch.
selector:
entity:
domain: sensor
integration: mqtt
light_entity_left:
selector:
entity:
domain: light
light_entity_right:
selector:
entity:
domain: light
light_entity_both:
selector:
entity:
domain: light
mode_selector:
name: time of day
description: input select that determines time of day, values are overdag, avond & nacht
selector:
entity:
domain: input_select
mode: single
max_exceeded: silent
variables:
mode_selector: !input mode_selector
brightness: >
{% if is_state(mode_selector , 'overdag') %}
191
{% elif is_state(mode_selector , 'avond') %}
128
{% elif is_state(mode_selector , 'nacht') %}
1
{% else %}
255
{% endif %}
condition: []
- platform: state
entity_id: !input switch_entity
- variables:
command: "{{ trigger.to_state.state }}"
- choose:
- conditions:
- "{{ command == 'single_left' }}"
sequence:
- service: light.toggle
entity_id: !input light_entity_left
transition: 2
brightness: "{{ brightness }}"
- conditions:
- "{{ command == 'single_right' }}"
sequence:
entity_id: !input light_entity_right
transition: 2
- conditions:
- "{{ command == 'single_both' }}"
sequence:
entity_id: !input light_entity_both
transition: 2
- conditions:
- "{{ command == 'double_left' }}"
sequence:
- variables:
light_entity: !input light_entity_left
start_mired: '{{ state_attr(light_entity , ''min_mireds'') |int }}'
end_mired: '{{ state_attr(light_entity , ''max_mireds'') |int }}'
step: '{{ ((end_mired - start_mired )/4 )| int }}'
current_mired: '{{ state_attr(light_entity, ''color_temp'') }}'
- choose:
- conditions:
- condition: template
value_template: "{{ current_mired == None }}"
sequence:
- service: light.turn_on
transition: 2
color_temp: "{{ start_mired }}"
- conditions:
value_template: "{{ ( current_mired |int + step) > end_mired }}"
sequence:
transition: 2
default:
transition: 2
color_temp: "{{ state_attr(light_entity, 'color_temp') |int + step }}"
- conditions:
- "{{ command == 'double_right' }}"
sequence:
- variables:
light_entity: !input light_entity_right
- choose:
- conditions:
sequence:
transition: 2
- conditions:
sequence:
transition: 2
default:
transition: 2
versions:
1.0.0 first version
1.0.1 fixed typo in brightness template
