Home Assistant Green install error
Hi, new HA Green, fired it up and can find the server on my network, but I get a message:
Error installing Home Assistant
An error occured while installing Home Assistant, check the logs below for more information.
I’m lost as to what to do - there is nothing to change I can see - have tried going through a different connection but no luck.
Full log at:
Install error log
Received my HA Green this morning and have the exact same problem.
Log
Same problem here. Until now, I have not found a solution. I will keep this posted updated I case I find a way to make HA Green up and running.
As I seem to be having the exact same problem with my brand new Home Assistant Green I am also searching for a solution. This seems to be a duplicate of this issue, and in that thread a solution is suggested by @cycreator.
Might be worth a try.
I’m having the same issue… Just ordered a microSD card so I can try the factory reset suggested in the other thread.
Update: The factory reset worked for me, too!
I fixed my issue by changing DNS server settings on my router to Google - for some reason my ISP’s default servers were blocking the configuration.
Posting in case this helps anyone else.
Would you mind sharing your DNS settings to Google?
