Home Assistant installation on Asustor AS1002v2 NAS
Hello all!
I recently purchased an AS1002v2 partly because according to the Asustor page it indicated that Home Assistant was available as an app. I thought great! That would save me from having one extra raspberry running somewhere. However, I did not notice that the model I purchased is actually NOT supported… It looks like this entry-level NAS is using a 32bit ARM processor which seems quite different from the more high end Asustor NASses.
So I thought maybe it could be manually installed.
I found this thread Make Home Assistant autostart on ASUSTOR on these forums and tried to follow the instructions provided by “js_online”. Installing python and went well but it failed on the ./python3 -m pip install homeassistant==0.64.3 with the following output:
Building wheels for collected packages: aiohttp, yarl, idna-ssl, MarkupSafe, multidict, pyyaml, typing
  Building wheel for aiohttp (PEP 517) ... done
  Created wheel for aiohttp: filename=aiohttp-2.3.10-py3-none-any.whl size=275943 sha256=70b7d45d3997caa1651a1249c0795beff0959d06357dfaf3f        2059942a3e6f3c6
  Stored in directory: /volume1/.@root/.cache/pip/wheels/10/b7/bf/90260eacd894b16d234ab789830ef5f24eccc46d6ce25bdd21
  Building wheel for yarl (setup.py) ... done
  Created wheel for yarl: filename=yarl-1.1.0-py3-none-any.whl size=82046 sha256=14ddefdad6188c4605694d706bfa303c2eeb66c8d2737937c3105393e        b7fe025
  Stored in directory: /volume1/.@root/.cache/pip/wheels/d5/e1/3d/448a768a8baff7feee1e5babfeadfa073fb01c6121fa4adc92
  Building wheel for idna-ssl (setup.py) ... done
  Created wheel for idna-ssl: filename=idna_ssl-1.1.0-py3-none-any.whl size=3160 sha256=76525452001f4ffe648df94c8e96495f600f750e1ec191af8a        199794b92cb6cb
  Stored in directory: /volume1/.@root/.cache/pip/wheels/f8/6e/1a/2b06858462be949392cca86c5d84db2822fad22e360fe68156
  Building wheel for MarkupSafe (setup.py) ... done
  Created wheel for MarkupSafe: filename=MarkupSafe-1.1.1-py3-none-any.whl size=12629 sha256=1d5c953e2224e503b42db76d55a0160d6ac64a5f91ff4        6efb93c3ac67e949b4d
  Stored in directory: /volume1/.@root/.cache/pip/wheels/b9/d9/ae/63bf9056b0a22b13ade9f6b9e08187c1bb71c47ef21a8c9924
  Building wheel for multidict (PEP 517) ... error
  ERROR: Command errored out with exit status 1:
   command: /volume1/.@plugins/AppCentral/python3/bin/python3 /volume1/.@plugins/AppCentral/python3/lib/python3.7/site-packages/pip/_vendo        r/pep517/_in_process.py build_wheel /opt/tmp/tmpsoeqigai
       cwd: /volume1/.@plugins/AppCentral/entware-ng/opt/tmp/pip-install-9wjb1m_1/multidict_eca6f8ce83e64e6292bd5d632a9a1ede
  Complete output (43 lines):
  * Accelerated build *
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-armv7l-3.7
  creating build/lib.linux-armv7l-3.7/multidict
  copying multidict/_multidict_base.py -> build/lib.linux-armv7l-3.7/multidict
  copying multidict/_multidict_py.py -> build/lib.linux-armv7l-3.7/multidict
  copying multidict/__init__.py -> build/lib.linux-armv7l-3.7/multidict
  copying multidict/_abc.py -> build/lib.linux-armv7l-3.7/multidict
  copying multidict/_compat.py -> build/lib.linux-armv7l-3.7/multidict
  running egg_info
  writing multidict.egg-info/PKG-INFO
  writing dependency_links to multidict.egg-info/dependency_links.txt
  writing top-level names to multidict.egg-info/top_level.txt
  reading manifest file 'multidict.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  warning: no previously-included files matching '*.pyc' found anywhere in distribution
  warning: no previously-included files found matching 'multidict/_multidict.html'
  warning: no previously-included files found matching 'multidict/*.so'
  warning: no previously-included files found matching 'multidict/*.pyd'
  no previously-included directories found matching 'docs/_build'
  writing manifest file 'multidict.egg-info/SOURCES.txt'
  copying multidict/__init__.pyi -> build/lib.linux-armv7l-3.7/multidict
  copying multidict/_multidict.c -> build/lib.linux-armv7l-3.7/multidict
  copying multidict/py.typed -> build/lib.linux-armv7l-3.7/multidict
  creating build/lib.linux-armv7l-3.7/multidict/_multilib
  copying multidict/_multilib/defs.h -> build/lib.linux-armv7l-3.7/multidict/_multilib
  copying multidict/_multilib/dict.h -> build/lib.linux-armv7l-3.7/multidict/_multilib
  copying multidict/_multilib/istr.h -> build/lib.linux-armv7l-3.7/multidict/_multilib
  copying multidict/_multilib/iter.h -> build/lib.linux-armv7l-3.7/multidict/_multilib
  copying multidict/_multilib/pair_list.h -> build/lib.linux-armv7l-3.7/multidict/_multilib
  copying multidict/_multilib/views.h -> build/lib.linux-armv7l-3.7/multidict/_multilib
  running build_ext
  building 'multidict._multidict' extension
  creating build/temp.linux-armv7l-3.7
  creating build/temp.linux-armv7l-3.7/multidict
  arm-marvell-linux-gnueabi-gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -I/AS10XX/arm/staging/usr/include -I/AS10X        X/arm/staging/usr/builtin/include -I/AS10XX/arm/staging/linux-3.10.70-headers/include -fPIC -I/volume1/.@plugins/AppCentral/python3/includ        e/python3.7m -c multidict/_multidict.c -o build/temp.linux-armv7l-3.7/multidict/_multidict.o -O2 -std=c99 -Wall -Wsign-compare -Wconversio        n -fno-strict-aliasing -pedantic
  error: command 'arm-marvell-linux-gnueabi-gcc' failed with exit status 1
  ERROR: Failed building wheel for multidict
  Building wheel for pyyaml (setup.py) ... done
  Created wheel for pyyaml: filename=PyYAML-3.13-cp37-cp37m-linux_armv7l.whl size=43085 sha256=eca00c06d55261249983b5ae55ca9cc5902b7135611        db455b942126654cd75b4
  Stored in directory: /volume1/.@root/.cache/pip/wheels/95/cd/14/899edaa9cdb9a65aa7224539f6e0ad488e9a7b202bb48f6ae6
  Building wheel for typing (setup.py) ... done
  Created wheel for typing: filename=typing-3.7.4.3-py3-none-any.whl size=26308 sha256=268797d435b8defd431898b21b3d4be0e656f54d81b62c6347c        b7e8e4dd8ab1e
  Stored in directory: /volume1/.@root/.cache/pip/wheels/35/f3/15/01aa6571f0a72ee6ae7b827c1491c37a1f72d686fd22b43b0e
Successfully built aiohttp yarl idna-ssl MarkupSafe pyyaml typing
Failed to build multidict
ERROR: Could not build wheels for multidict which use PEP 517 and cannot be installed directly
root@irmanas:/volume1/.@plugins/AppCentral/python3/bin #
I also tried without the “==0.64.3” version but the result was similar, but it downloaded a lot more packages. I tried rebooting and giving the pip install homeassistant command a couple more times. At some point it then started complaining that it had run out of hard disk space; which is interesting as df -h did not show any mounted filesystem to be even near 100%.
I have updated pip and installed pyhon3-dev.
Has somebody else been successful in installing Home Assistant on the AS1002v2 NAS?
Thanks for taking the time to read the post.
Here is the output form pip install homeassistant (the part that fit the shell history, not able to upload text files ): https://pastebin.com/RZMwr6PA
