Make Home Assistant autostart on ASUSTOR
Hello friends!
I am trying to make hass-daemon autostart. I can’t configure the usual files, because the ASUSTOR resets everything on restart. So after installing entware-ng, I discovered it has the directory /usr/local/AppCentral/entware-ng/opt/etc/init.d so I thought I might just put my script for autostarting Home Assistant there. I created a script and tried a few things like
#!/bin/sh
/my_hass_directory/hass-daemon start
which works, when I run it manually, but it doesn’t work on startup. What am I doing wrong.
I named the script S60hass-daemon (there is already a S56dnsmasq script used to start my dns-server, which I want to do first), and I ran chmod 777 S60hass-daemon and chmod +x S60hass-daemon.
I also tried to copy the content of S56dnsmasq into S60hass-daemon and change the name to hass-daemon and path to /my_hass_directory, but that gave a strange error.
I also tried to make a link my hass-daemon file named S60hass-daemon, which would also run manually, but not at startup.
The /entware-ng/opt/etc/init.d folder doesn’t have the normal rcX.d folders, but has a rc.unslung file, that, according to itself:
# Start/stop all init scripts in /opt/etc/init.d including symlinks
# starting them in numerical order and
# stopping them in reverse numerical order
I never had any experience with linux, and I am completely lost.
Please help!
Guys; this is really important. How can I use the Home Assistant as an alarm clock, if I don’t know that it restarts after a power outage?
Please help!
This was actually very easy! You just need to make a link to your hass-daemon in the local init.d folder. In my case:
homeassistant@AS-302T:/usr/local/etc/init.d $ ln -s /volume1/homeassistant/hass-daemon S95hass-daemon
the name is broken down thus: S means start, whatever comes after S is sorted so that the first starts first. By convention, two numbers is used first. I use S95 because I want home assistant to start when everything else already started. I keep the rest of the name hass-daemon so I know what it is, but it could be anything.
Thanks to Philippe aka. Father Mande for leading me to the post in the Asustor forum that solved my problem.
Sharing How to Install info for Asustor users:
  1. Nas Web Interface --> App Central, install Python, Python3, Entware-ng
2.Connect to NAS using Putty (SSH) with root user
cd /volume1/.@plugins/AppCentral/python3/bin
./python3 -m ensurepip
./python3 -m pip install homeassistant==0.64.3
./python3 -m pip install --upgrade pip
./python3 -m pip install --upgrade homeassistant
  1. Nas Web Interface --> Access Control:
    Create homeassitant user (users group)
    Create Shared Directory HomeAssistant (volume1) and RW permissions for homeassitant user (?user not used yet?).
  2. Create hass-daemon file (WinSCP Shift+F4) in directory created in #2 (/volume1/HomeAssistant) - (see code at the bottom)
    cd /volume1/HomeAssistant
    #Assign Permissions
    chmod 755 hass-daemon
    #Check Results
    ls -ltr
  3. Create links
    #Create Links
    ln -s /volume1/.@plugins/AppCentral/python3/bin/python3 python3
    ln -s /volume1/.@plugins/AppCentral/python3/lib/python3.7/site-packages/homeassistant homeassistant
    #Check results
    ls -ltr
6.Install sudo (entware)
opkg update
opkg install sudo
7.Start HomeAssistant daemon
./hass-daemon start
#Check results
ps -ef | grep hass
#to restart (after changing config file)
./hass-daemon restart
if started sucessfully you will have also many files created in /volume1/HomeAssistant directory:
home-assistant.pid file, *.yaml files etc.
  1. From Local network
    in Browser type
    NAS_IP_address:8123
    to open Home Assistant page and complete and create account
  2. In Router define port forwarding to point NAS_IP_address:8123 from external network
    Preformatted textOpen Home Assistant from Anywere using external IP address and port or using dynimic ip (no-ip.com) etc
  3. Add to init.d (as described in previous post)
    cd /usr/local/etc/init.d
    ln -s /volume1/HomeAssistant/hass-daemon S95hass-daemon
hass-daemon file:
#!/bin/sh
Package
PACKAGE=“homeassistant”
DNAME=“Home Assistant”
Others
USER=“homeassistant”
PYTHON_DIR="/volume1/.@plugins/AppCentral/python3/bin"
PYTHON="$PYTHON_DIR/python3"
HASS="$PYTHON_DIR/hass"
INSTALL_DIR="/volume1/HomeAssistant"
PID_FILE="$INSTALL_DIR/home-assistant.pid"
FLAGS="-v --config $INSTALL_DIR --pid-file $PID_FILE --daemon"
REDIRECT="> $INSTALL_DIR/home-assistant.log 2>&1"
start_daemon ()
sudo -u ${USER} /bin/sh -c “$PYTHON $HASS $FLAGS $REDIRECT;”
stop_daemon ()
kill cat ${PID_FILE}
wait_for_status 1 20 || kill -9 cat ${PID_FILE}
rm -f ${PID_FILE}
daemon_status ()
if [ -f ${PID_FILE} ] && kill -0 cat ${PID_FILE} > /dev/null 2>&1; then
return
fi
rm -f ${PID_FILE}
return 1
wait_for_status ()
counter=$2
while [ ${counter} -gt 0 ]; do
daemon_status
[ $? -eq $1 ] && return
let counter=counter-1
sleep 1
done
return 1
case $1 in
start)
if daemon_status; then
echo ${DNAME} is already running
exit 0
else
echo Starting ${DNAME} …
start_daemon
exit $?
fi
stop)
echo Stopping ${DNAME} …
stop_daemon
exit $?
else
echo ${DNAME} is not running
exit 0
fi
restart)
stop_daemon
start_daemon
exit $?
else
start_daemon
exit $?
fi
status)
echo ${DNAME} is running
exit 0
else
exit 1
fi
log)
echo ${LOG_FILE}
exit 0
exit 1
esac
@js_online
Thank you for helping out! Incredibly much appreciated!
I followed your steps exactly and got stuck at step #7 executing: ./hass-daemon start
Unfortunately this is what I get in Terminal (running a ssh session):
bas@NAS-10TB-RAID1:/volume1/HomeAssistant $ cd /volume1/HomeAssistant
bas@NAS-10TB-RAID1:/volume1/HomeAssistant $ ./hass-daemon start
./hass-daemon: line 4: Assistant”: not found
Starting …
sudo: unknown user: “homeassistant”
sudo: unable to initialize policy plugin
./hass-daemon: line 94: ”: not found
Any suggestions?
This is the hass-daemon file (no extention) I created:
#!/bin/sh
#Package
#Others
PYTHON_DIR=“/volume1/.@plugins/AppCentral/python3/bin”
PYTHON=“$PYTHON_DIR/python3”
HASS=“$PYTHON_DIR/hass”
INSTALL_DIR=“/volume1/HomeAssistant”
PID_FILE=“$INSTALL_DIR/home-assistant.pid”
FLAGS=“-v --config $INSTALL_DIR --pid-file $PID_FILE --daemon”
REDIRECT=“> $INSTALL_DIR/home-assistant.log 2>&1”
start_daemon ()
stop_daemon ()
rm -f ${PID_FILE}
daemon_status ()
return
fi
rm -f ${PID_FILE}
return 1
wait_for_status ()
counter=$2
daemon_status
sleep 1
done
return 1
case $1 in
start)
exit 0
else
start_daemon
exit $?
fi
stop)
stop_daemon
exit $?
else
exit 0
fi
restart)
stop_daemon
start_daemon
exit $?
else
start_daemon
exit $?
fi
status)
exit 0
else
exit 1
fi
log)
echo ${LOG_FILE}
exit 0
exit 1
esac
I also noted that a folder homeassistant within the shared folder HomeAssistant is created.
Unfortunately I cannot explain the process, what to expect.
Hi there, i tried following your step by step but i got stuck on step 2 due to an error that the following line is throwing:
Right when the installation is going to proceed with Cryptography and bcrypt, it fails.
Seems from my perspective that it is missing a gcc compiler but i’m not sure how to fix it.
below the output right from the error onwards.
Running setup.py install for cryptography ... error
    ERROR: Command errored out with exit status 1:
     command: /volume1/.@plugins/AppCentral/python3/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-x6w2ve2m/cryptography/setup.py'"'"'; __file__='"'"'/tmp/pip-install-x6w2ve2m/cryptography/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-e2pexg_3/install-record.txt --single-version-externally-managed --compile
         cwd: /tmp/pip-install-x6w2ve2m/cryptography/
    Complete output (133 lines):
    running install
    running build
    running build_py
    creating build
    creating build/lib.linux-i686-3.7
    creating build/lib.linux-i686-3.7/cryptography
    copying src/cryptography/utils.py -> build/lib.linux-i686-3.7/cryptography
    copying src/cryptography/fernet.py -> build/lib.linux-i686-3.7/cryptography
    copying src/cryptography/exceptions.py -> build/lib.linux-i686-3.7/cryptography
    copying src/cryptography/__init__.py -> build/lib.linux-i686-3.7/cryptography
    copying src/cryptography/__about__.py -> build/lib.linux-i686-3.7/cryptography
    creating build/lib.linux-i686-3.7/cryptography/x509
    copying src/cryptography/x509/oid.py -> build/lib.linux-i686-3.7/cryptography/x509
    copying src/cryptography/x509/ocsp.py -> build/lib.linux-i686-3.7/cryptography/x509
    copying src/cryptography/x509/name.py -> build/lib.linux-i686-3.7/cryptography/x509
    copying src/cryptography/x509/general_name.py -> build/lib.linux-i686-3.7/cryptography/x509
    copying src/cryptography/x509/extensions.py -> build/lib.linux-i686-3.7/cryptography/x509
    copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-i686-3.7/cryptography/x509
    copying src/cryptography/x509/base.py -> build/lib.linux-i686-3.7/cryptography/x509
    copying src/cryptography/x509/__init__.py -> build/lib.linux-i686-3.7/cryptography/x509
    creating build/lib.linux-i686-3.7/cryptography/hazmat
    copying src/cryptography/hazmat/_oid.py -> build/lib.linux-i686-3.7/cryptography/hazmat
    copying src/cryptography/hazmat/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat
    creating build/lib.linux-i686-3.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives
    creating build/lib.linux-i686-3.7/cryptography/hazmat/bindings
    copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/bindings
    creating build/lib.linux-i686-3.7/cryptography/hazmat/backends
    copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends
    copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends
    creating build/lib.linux-i686-3.7/cryptography/hazmat/primitives/twofactor
    copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/twofactor
    copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/twofactor
    copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/twofactor
    copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/twofactor
    creating build/lib.linux-i686-3.7/cryptography/hazmat/primitives/serialization
    copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/serialization
    copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/serialization
    copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/serialization
    copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/serialization
    creating build/lib.linux-i686-3.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/kdf
    creating build/lib.linux-i686-3.7/cryptography/hazmat/primitives/ciphers
    copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/ciphers
    copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/ciphers
    copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/ciphers
    copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/ciphers
    copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/ciphers
    creating build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/primitives/asymmetric
    creating build/lib.linux-i686-3.7/cryptography/hazmat/bindings/openssl
    copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-i686-3.7/cryptography/hazmat/bindings/openssl
    copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-i686-3.7/cryptography/hazmat/bindings/openssl
    copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/bindings/openssl
    creating build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/ocsp.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-i686-3.7/cryptography/hazmat/backends/openssl
    running egg_info
    writing src/cryptography.egg-info/PKG-INFO
    writing dependency_links to src/cryptography.egg-info/dependency_links.txt
    writing requirements to src/cryptography.egg-info/requires.txt
    writing top-level names to src/cryptography.egg-info/top_level.txt
    reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
    reading manifest template 'MANIFEST.in'
    no previously-included directories found matching 'docs/_build'
    warning: no previously-included files found matching 'vectors'
    warning: no previously-included files matching '*' found under directory 'vectors'
    warning: no previously-included files found matching 'azure-pipelines.yml'
    warning: no previously-included files found matching '.azure-pipelines'
    warning: no previously-included files found matching '.travis.yml'
    warning: no previously-included files found matching '.travis'
    warning: no previously-included files matching '*' found under directory '.azure-pipelines'
    warning: no previously-included files matching '*' found under directory '.travis'
    warning: no previously-included files found matching 'release.py'
    warning: no previously-included files found matching '.coveragerc'
    warning: no previously-included files found matching 'codecov.yml'
    warning: no previously-included files found matching 'dev-requirements.txt'
    warning: no previously-included files found matching 'rtd-requirements.txt'
    warning: no previously-included files found matching 'tox.ini'
    writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
    running build_ext
    generating cffi module 'build/temp.linux-i686-3.7/_padding.c'
    creating build/temp.linux-i686-3.7
    generating cffi module 'build/temp.linux-i686-3.7/_constant_time.c'
    generating cffi module 'build/temp.linux-i686-3.7/_openssl.c'
    building '_openssl' extension
    creating build/temp.linux-i686-3.7/build
    creating build/temp.linux-i686-3.7/build/temp.linux-i686-3.7
    i686-asustor-linux-gnu-gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -I/AS3XX/x86/staging/usr/include -I/AS3XX/x86/staging/usr/builtin/include -I/AS3XX/x86/staging/linux-3.4.26-headers/include -fPIC -I/volume1/.@plugins/AppCentral/python3/include/python3.7m -c build/temp.linux-i686-3.7/_openssl.c -o build/temp.linux-i686-3.7/build/temp.linux-i686-3.7/_openssl.o -Wconversion -Wno-error=sign-conversion
    unable to execute 'i686-asustor-linux-gnu-gcc': No such file or directory
    error: command 'i686-asustor-linux-gnu-gcc' failed with exit status 1
