Home assistant keeps crashing after 5 to 10 minutes
Hi all,
I’ve been running my HomeAssistant instance whit no issue for the last year. Last week I changed my home router/modem from KPN to a Ubiquiti Cloud gateway Ultra. Some things changed like the gateway IP and some IP’s from hubs i wanted to change to a different static IP. I’ve set all this up in the Ultra and in the HA add-ons / Network settings but for some reason the HomeAssistant keeps rebooting between the 5 to 10 minutes +/- When i check the logs i dont realy see a critical error which could cause the HA to crash
HA setup:
  • Core - 2025.1.4
  • Supervisor - 2024.12.3
  • Operating System - 14.2
  • Frontend - 20250109
  • Raspberry Pi 4 8GB with NVME storage (500GB) no SD card (Argon ONE V2 M.2 Expansion Board (NVME))
Logs:
  • home-assistant.log.fault > Empty ? 0KB
  • Home-assistant.log.1 > 34 entries only warnings.
  • Home-assistant.log > 104 enties mostly warning and few error’s from a old automation thats allready deleted but i dont know why its showing? (Sensor.droger was a amp/watt checker to see if the washing machine was done but i deleted this like 3 months ago)
I’m kinda out of options where to go looking / what is causing it… When home assistant is back online is shows all data like nothing happend, all dashboards work and integrations etc… Where should i start beside the logs?
2025-01-27 17:41:30.990 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration fontawesome which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:30.995 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration plant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:30.997 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration eufy_security which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:31.000 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:31.002 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration buienalarm which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:31.004 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bambu_lab which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:31.006 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration quatt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:31.009 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration openplantbook which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:31.012 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xtend_tuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:31.013 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-27 17:41:36.557 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-01-27 17:41:36.620 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=361 from 2025-01-27 16:36:26.376221)
2025-01-27 17:41:56.405 WARNING (ImportExecutor_0) [homeassistant.const] STATE_ALARM_ARMED_AWAY was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2025.11. Use AlarmControlPanelState.ARMED_AWAY instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.415 WARNING (ImportExecutor_0) [homeassistant.const] STATE_ALARM_ARMED_HOME was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2025.11. Use AlarmControlPanelState.ARMED_HOME instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.424 WARNING (ImportExecutor_0) [homeassistant.const] STATE_ALARM_DISARMED was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2025.11. Use AlarmControlPanelState.DISARMED instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.434 WARNING (ImportExecutor_0) [homeassistant.const] STATE_ALARM_TRIGGERED was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2025.11. Use AlarmControlPanelState.TRIGGERED instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.480 WARNING (ImportExecutor_0) [homeassistant.components.light] ATTR_COLOR_TEMP was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2026.1. Use kelvin equivalent (ATTR_COLOR_TEMP_KELVIN) instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.489 WARNING (ImportExecutor_0) [homeassistant.components.light] ATTR_COLOR_TEMP was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2026.1. Use kelvin equivalent (ATTR_COLOR_TEMP_KELVIN) instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.540 WARNING (ImportExecutor_0) [homeassistant.components.vacuum] STATE_CLEANING was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2026.1. Use VacuumActivity.CLEANING instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.549 WARNING (ImportExecutor_0) [homeassistant.components.vacuum] STATE_DOCKED was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2026.1. Use VacuumActivity.DOCKED instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.558 WARNING (ImportExecutor_0) [homeassistant.components.vacuum] STATE_RETURNING was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2026.1. Use VacuumActivity.RETURNING instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.567 WARNING (ImportExecutor_0) [homeassistant.components.vacuum] STATE_CLEANING was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2026.1. Use VacuumActivity.CLEANING instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.576 WARNING (ImportExecutor_0) [homeassistant.components.vacuum] STATE_DOCKED was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2026.1. Use VacuumActivity.DOCKED instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:56.585 WARNING (ImportExecutor_0) [homeassistant.components.vacuum] STATE_RETURNING was used from xtend_tuya, this is a deprecated constant which will be removed in HA Core 2026.1. Use VacuumActivity.RETURNING instead, please report it to the author of the 'xtend_tuya' custom integration
2025-01-27 17:41:57.568 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.heatpump_flowmeter_flowrate (<class 'custom_components.quatt.sensor.QuattSensor'>) is using native unit of measurement 'L/h' which is not a valid unit for the device class ('volume_flow_rate') it is using; expected one of ['m³/h', 'gal/min', 'ft³/min', 'mL/s', 'L/min']; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/marcoboers/home-assistant-quatt/issues
2025-01-27 17:41:59.750 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for higrow04 @ xxx.xxx.x.86: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='xxx.xxx.x.86', port=6053))]: [Errno 111] Connect call failed ('xxx.xxx.x.86', 6053) (SocketAPIError)
2025-01-27 17:42:02.809 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for higrow01 @ xxx.xxx.x.28: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='xxx.xxx.x.28', port=6053))]: [Errno 113] Connect call failed ('xxx.xxx.x.28', 6053) (SocketAPIError)
2025-01-27 17:42:02.811 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for higrow02 @ xxx.xxx.x.83: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='xxx.xxx.x.83', port=6053))]: [Errno 113] Connect call failed ('xxx.xxx.x.83', 6053) (SocketAPIError)
2025-01-27 17:42:02.876 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for higrow03 @ xxx.xxx.x.41: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='xxx.xxx.x.41', port=6053))]: [Errno 113] Connect call failed ('xxx.xxx.x.41', 6053) (SocketAPIError)
2025-01-27 17:42:02.904 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for 3d-cam @ xxx.xxx.x.42: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='xxx.xxx.x.42', port=6053))]: [Errno 113] Connect call failed ('xxx.xxx.x.42', 6053) (SocketAPIError)
2025-01-27 17:42:27.948 WARNING (MainThread) [homeassistant.core] Something is blocking Home Assistant from wrapping up the start up phase. We're going to continue anyway. Please report the following info at https://github.com/home-assistant/core/issues: conversation, solaredge, buienradar.sensor, philips_js, homewizard.button, philips_js.remote, buienalarm.sensor, history, utility_meter, mqtt.binary_sensor, philips_js.light, system_log, esphome, eufy_security.number, automation, assist_pipeline, bambu_lab, bambu_lab.fan, plant.number, solaredge.sensor, xtend_tuya.vacuum, system_health, network, homeassistant_sky_connect, esphome.button, lock, schedule, eufy_security.button, assist_satellite, analytics, homeassistant, integration.sensor, eufy_security.image, tado, xtend_tuya.select, bambu_lab.light, tradfri.fan, tradfri.sensor, bambu_lab.sensor, file_upload, xtend_tuya, local_todo, wiz.number, trace, switch, picnic, cloud.tts, xtend_tuya.alarm_control_panel, eufy_security.switch, plant, zone, mobile_app.notify, energy.sensor, stt, cover, time, rpi_power, hue.sensor, mqtt, wiz.switch, xtend_tuya.camera, template, hacs.update, tradfri.light, device_automation, bambu_lab.switch, speedtestdotnet, hue, xtend_tuya.sensor, hacs.switch, esphome.climate, hassio, media_player, event, xtend_tuya.cover, quatt.sensor, bluetooth, buienradar.camera, homeassistant_alerts, bambu_lab.number, hue.scene, config, backup, wiz, tts, wiz.light, openplantbook, logbook, input_button, raspberry_pi, rpi_power.binary_sensor, image_upload, device_tracker, my, number, systemmonitor, systemmonitor.sensor, counter, homeassistant.scene, frontend, androidtv_remote, hue.switch, remote, tradfri.cover, xtend_tuya.light, person, philips_js.switch, cloud.stt, eufy_security.select, shopping_list, recorder, api, sensor, homewizard.number, auth, eufy_security.camera, hardware, cast.media_player, google_translate, application_credentials, group.light, tag, button, met.weather, blueprint, weather, openai_conversation, google_translate.tts, esphome.update, sun, xtend_tuya.button, buienradar, xtend_tuya.number, xtend_tuya.binary_sensor, logger, water_heater, camera, onboarding, xtend_tuya.switch, fontawesome, philips_js.media_player, hue.event, input_select, update, mqtt.switch, xtend_tuya.scene, group.notify, default_config, eufy_security.binary_sensor, persistent_notification, lovelace, intent, sun.sensor, webrtc, xtend_tuya.fan, co2signal.sensor, input_text, homewizard, vacuum, openai_conversation.conversation, scene, esphome.light, tado.device_tracker, quatt.binary_sensor, bambu_lab.select, bambu_lab.camera, plant.sensor, hassio.update, esphome.sensor, zeroconf, tado.climate, picnic.sensor, mobile_app.device_tracker, diagnostics, ffmpeg, hassio.sensor, speedtestdotnet.sensor, buienradar.weather, repairs, integration, forecast_solar.sensor, forecast_solar, input_datetime, met, alarm_control_panel, xtend_tuya.lock, eufy_security.alarm_control_panel, humidifier, select, fan, ssdp, ipp, homewizard.sensor, wyoming, shopping_list.todo, androidtv_remote.media_player, bambu_lab.binary_sensor, script, energy, image, stream, template.binary_sensor, co2signal, tado.binary_sensor, todo, google_assistant, quatt, picnic.todo, webhook, wiz.binary_sensor, xtend_tuya.time, ipp.sensor, mobile_app, eufy_security.sensor, mobile_app.binary_sensor, binary_sensor, systemmonitor.binary_sensor, light, xtend_tuya.climate, template.sensor, websocket_api, mqtt.button, radio_browser, wiz.sensor, http, cast, xtend_tuya.siren, local_todo.todo, hue.light, homeassistant_hardware, esphome.switch, siren, tado.sensor, search, bambu_lab.image, utility_meter.sensor, mobile_app.sensor, androidtv_remote.remote, timer, hassio.binary_sensor, dhcp, eufy_security.lock, cloud.binary_sensor, input_boolean, esphome.camera, go2rtc, bambu_lab.button, tradfri.switch, xtend_tuya.humidifier, philips_js.binary_sensor, tado.water_heater, eufy_security, mqtt.sensor, usb, tradfri, notify, climate, cloud, homewizard.switch, hacs, media_source, input_number, hue.binary_sensor, group, wake_word The system is waiting for tasks: {<Task pending name='Task-901' coro=<AbstractConfig.async_initialize.<locals>.sync_google() running at /usr/src/homeassistant/homeassistant/components/google_assistant/helpers.py:114> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()]> cb=[set.remove()]>}
2025-01-27 17:44:38.021 ERROR (Thread-113) [pychromecast.socket_client] [Kantoor(xxx.xxx.x.59):8009] Failed to connect to service MDNSServiceInfo(name='Chromecast-0859ad1405c81baa5c58e4b657c49d5c._googlecast._tcp.local.'), retrying in 5.0s
2025-01-27 17:47:33.717 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({% set wasmachine = states('sensor.washmachine_stroom') | float > 0.01 %}
          {% set droger = states('sensor.droger_stroom') | float > 0.01 %}
          {% if wasmachine and droger %}
            Was zowel droger actief
          {% elif wasmachine %}
            Wasmachine actief
          {% elif droger %}
            Droger actief
          {% else %}
            Geen was of droger actief.
          {% endif %}) renders=2>
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2364, in forgiving_float_filter
    return float(value)
ValueError: could not convert string to float: 'unknown'
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 643, in async_render
    render_result = _render_with_context(self.template, compiled, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2745, in _render_with_context
    return template.render(**kwargs)
  File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 1295, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 942, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "<template>", line 1, in top-level template code
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2367, in forgiving_float_filter
    raise_no_default("float", value)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1921, in raise_no_default
    raise ValueError(
    ...<2 lines>...
ValueError: Template error: float got invalid input 'unknown' when rendering template '{% set wasmachine = states('sensor.washmachine_stroom') | float > 0.01 %}
            Wasmachine actief
          {% elif droger %}
            Droger actief
          {% else %}
          {% endif %}' but no default was specified
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 760, in async_render_to_info
    render_info._result = self.async_render(  # noqa: SLF001
        variables, strict=strict, log_fn=log_fn, **kwargs
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 645, in async_render
    raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: float got invalid input 'unknown' when rendering template '{% set wasmachine = states('sensor.washmachine_stroom') | float > 0.01 %}
            Wasmachine actief
          {% elif droger %}
            Droger actief
          {% else %}
You can look at this topic:
Not working for me on neither of my rP5s 4GB systems. One appears to have fallen back after a long time to 14.1. The other still scrolling on the CLI - appears to be having trouble with network startup.
Just powered down and rebooted. Now the other is back up and on 14.1. Not messing with this 14.2 update till I hear more feedback on it.
You should try to correct your conversions (| float)!
They need a default value stated, so they know how to pass a impossible conversion.
And those look like Lovelace card definitions and not automations.
Then you need to look into the homeassistant…log.1 file in the config directory.
This is the file from the previous run.
Rebooting or restarting? They are different.
Actually they are not.
booting is just an IT word for starting coming from the bootstrap word, which is the strap used to pull your own boots on.
The bootstrap refers to the little code the computer use to start itself up when it is turned on.
The issue turned out to be a faulty smart plug. To clarify, we have multiple Hombli smart plugs, and the one managing the network closet was faulty.
While troubleshooting next to the network closet last night, I heard a faint clicking sound twice in quick succession. My other devices, like the Hue Gen1 hub, IKEA hub, and network switch, didn’t seem affected by this. However, Home Assistant wasn’t happy with it. After removing the faulty plug, Home Assistant has been stable again.
I feel kinda dumb to be not think of this but i totally forgot the network closet had a smartplug…
I said “booting or restarting”. They are different. Booting is running bootstrap code to start the computer. Restart means the OS is running but the program or service is restarted.
In my day… I toggled the 16-word bootstrap code into the PDP-8 so often I memorized it.
It is now stuck, like a bad song.
7756 6032
7757 6031
7760 5357
7761 6036
7762 7106
7763 7006
7764 7510
7765 5357
7766 7006
7767 7510
7770 6031
7771 5367
7772 6036
7773 7106
7774 7006
7775 7510
That line says it all. Booting = starting.
It is true the booting does not make sense in relation to single programs. It is specific for starting a computer.
Starting means the same, but is just more general.
I meant restarting Home Assistant. Not the host computer. The title of the thread is “Home Assistant keeps crashing”. I was trying to clarify if the host computer crashed and needed rebooting or did Home Assistane crash and need restarting.
I know what you meant, because I know the restart options available in HA, but restart and reboot means the same thing and Home Assistant is ambiguous too, because it can both means Home Assistant OS and Home Assistant Core.
An inexperienced user might misunderstand the meaning and then you are on a side track in your help from then on. :slight_smile:
I always try to differentiate the two by saying HA Core and the entire host system.
