Kliko
(Jasper)
October 22, 2020, 11:50am
1
HAKA!
This is a Home Assistant Kodi Addon (HAKA!).
Prerequisites
Home Assistant 2021.2.1 or higher (older versions have a different API)
Kodi 18 or Kodi 19
Installation
Download the zip file from Github (Kodi 18 / Kodi 19 )
In Home Assistant navigate to your profile (bottom icon in the side-menu).
Scroll down and generate a long life token (long live the tokens!).
Write down the token / carve it in a stone / memorize / use a carrier pigeon and send it to yourself or… just copy the token.
Launch Kodi >> Add-ons >> Get More >> … >> Install from zip file
Enter your Home Assistant IP and port (i.e. https://myfancypansyhainstallation.duckdns.org:8123 )
Enter the token obtained in step four (don’t forget to release the pigeon if you used one)
Set up the domains you would like to browse from your couch.
Enjoy!
Features
The following domains are supported:
Automations (toggle)
Camera (view)
Climate (toggle)
Fan (toggle)
Group (toggle)
Light (toggle)
Persons (no action)
Scene (turn on)
Script (turn on)
Sensor (no action)
Switch (toggle)
Vacuum (start, stop, return to base, locate)
HAKA! Favorites
Add home assistant entities in a favorites folder which can be added to Kodi main menu in form of tiles, widget or whatever you want to name them. See the example of HAKA! favorites when using the Embuary skin below.
Change log
Version 1.2.0 (2021-10-13)
Camera support (view picture of HA camera’s)
Fan support (toggle)
Fixed issue: Crash when friendly name is not available
Version 1.1.0 (2021-02-21)
Kodi Matrix support
HAKA! Favorites section added (add items via context menu)
Extra sensor icons and sensor attributes as label
Persons domain added
Navigate to settings from within addon menu
Sort items by friendly name by default
Fixed issue: Items in Kodi main menu keep refreshing
Fixed issue: Not ascii characters give errors when generating label
Version 1.0.1 (2020-10-23)
Version 1.0.0 (2020-10-22)
Fritske
October 22, 2020, 12:34pm
2
i keep getting unknown error: check ip address or if server is online.
kodi 18.8
libreelec 9.2.4
raspberry pi 3
Kliko
(Jasper)
October 22, 2020, 1:02pm
3
Whats the format of your IP address? It should include https:// or http:// and the port number.
its https://domain.com:8123
also tried https://ipaddres:8123
and tried both without https
Kliko
(Jasper)
October 22, 2020, 1:29pm
5
Can you pastebin the last part of your Kodi.log file?
Makis
(Makis)
October 22, 2020, 1:38pm
6
Hi
Can you explain a little what the addon can do? (1-2 exmples)
I don’t have kodi right now but I can install it.
I am a little confused for the possibilities of this addon.
2020-10-22 14:20:12.146 T:1305465728 NOTICE: LoadJpeg: unable to load /storage/.kodi/addons/script.program.homassistant/fanart.jpg
2020-10-22 14:21:28.628 T:1937514512 NOTICE: Samba is idle. Closing the remaining connections
2020-10-22 14:23:58.647 T:1208214400 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'NoneType' object has no attribute 'text'
File "/storage/.kodi/addons/script.program.homassistant/addon.py", line 242, in <module>
browseByDomain()
File "/storage/.kodi/addons/script.program.homassistant/addon.py", line 130, in browseByDomain
parsedResponse = json.loads(response.text)
AttributeError: 'NoneType' object has no attribute 'text'
-->End of Python script error report<--
2020-10-22 14:23:58.993 T:1305465728 ERROR: GetDirectory - Error getting plugin://script.program.homassistant/
2020-10-22 14:23:58.996 T:1937514512 ERROR: CGUIMediaWindow::GetDirectory(plugin://script.program.homassistant/) failed
2020-10-22 14:24:36.663 T:1090511744 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
browseByDomain()
2020-10-22 14:24:37.028 T:1492878208 ERROR: GetDirectory - Error getting plugin://script.program.homassistant/
2020-10-22 14:24:37.028 T:1937514512 ERROR: CGUIMediaWindow::GetDirectory(plugin://script.program.homassistant/) failed
2020-10-22 14:25:33.551 T:1090511744 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
browseByDomain()
2020-10-22 14:25:33.918 T:1305465728 ERROR: GetDirectory - Error getting plugin://script.program.homassistant/
2020-10-22 14:25:33.918 T:1937514512 ERROR: CGUIMediaWindow::GetDirectory(plugin://script.program.homassistant/) failed
2020-10-22 14:26:38.647 T:1313858432 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
browseByDomain()
2020-10-22 14:26:38.980 T:1492878208 ERROR: GetDirectory - Error getting plugin://script.program.homassistant/
2020-10-22 14:26:38.980 T:1937514512 ERROR: CGUIMediaWindow::GetDirectory(plugin://script.program.homassistant/) failed
2020-10-22 14:27:41.865 T:1937514512 NOTICE: Quitting due to POSIX signal
2020-10-22 14:27:41.899 T:1937514512 NOTICE: Stopping player
Kliko
(Jasper)
October 22, 2020, 1:41pm
8
Its just a simple addon that will put all your entities in a list. “Playing” the kodi item will toggle your entity.
Makis
(Makis)
October 22, 2020, 1:43pm
9
so we can handle the above domains of HA from kodi. Very nice. Thanks!
Kliko
(Jasper)
October 22, 2020, 1:45pm
10
I will add some more logging in the next version to help you out.
Well, I was able to install and get this running way faster than I expected, nice work
I wwill also need to post some error logs… apparently i sucessfully connected to home assistant as it shows me the version. latest beta 117 b2 but get error … let me check logs and revert
for the moemnt light, sensr and vacuum seems not working
Kliko
(Jasper)
October 23, 2020, 10:51am
13
I created a dev branch that will give a bit more logging. You can enable it in the settings.
just need to figure out how to get those logs then
K thanks Will have a look into it tonight
GlennHA
(Glenn)
January 11, 2021, 5:36am
17
I would just like to verify this is still working with before I proceed.
Kliko
(Jasper)
January 11, 2021, 9:18am
18
Yes, its still working. Tested on Kodi 18.9 and HA 2021.1
Kliko
(Jasper)
February 18, 2021, 11:41pm
19
Just uploaded version 1.1.0 with the following changes.
Biggest one in my view is to add items to a favourites folder which you can place on the main screen of Kodi (see my first post).
Feel free to drop any bugs, suggestions and / or comments…
Kliko
(Jasper)
March 4, 2021, 7:41am
21
The Kodi Matrix version is added to the official Kodi addon repository for easier installation from within Kodi
