How much RAM should HA use?
I had my Proxmox set to 2GB and it was using over 90% so I decided to up it to 4GB and it is still using over 90%
See here:
My HA-VM uses 4.24GiB of the 12 available.
Donât worry, this is a quirk in how linux reports free memory, which isnât always intuitive. See this page for an explanation, and some commands to use to see what % of your ram is actually being used for running the HA applications: https://www.linuxatemyram.com/
Just wanted to chime in here with a question.
My PROXMOX memory usage for my HA VM is sitting at a relatively stable ~80%
HA is reporting quite different figures
I suppose this may be the âquirkâ in how linux reports free memory in action.
My only concern is when I check how much âreal free (available) memoryâ I have it is showing only about ~1.2GB.
RAM is there to be used and 1.2GB isnât âcloseâ to 0GB, however relative to the total 16GB in the system, it is quite close.
Hoping someone more knowledgable may be able to enlighten me on whatâs going on with the inconsistency in RAM reporting and whether I should be âworriedâ.
I have something very similar
Proxmos says Memory usage 86.65% (5.20 GiB of 6.00 GiB)
While home assistant:
I suppose is the quirk explained aboveâŚ
I had the same issue, and I was able to fix it. The problem (at least in my case) was that in the wizard, when it asked about the machine type, I selected the q35 machine, which caused the machine to consume so much memory. Then, I created a new HA instance but using the i440fx, and that fixed the issue.
My machine is i400fx and I have memeory problems too. But increase when I do a google drive backup. My question , is necessary to execute a google backup if i have a proxmox backup and also copies of proxmox backup in my NAS?
My personal experience says, the HA/Google backup is the one to go with. The VM backup is nice to have, and it will do its job, but for HA, you are more reliant on the HA backup.
If something happens to your VM, youâre done with the VM backup. You need to setup a new Proxmox machine and restore there. But what, if you want or need HA to be up and running fast? You could buy a Pi or something like that, but youâd need the full Proxmox environment there, to restore the VM backup⌠So not really ideal.
Where the HA backup can be restored to every platform, HA runs on. You do a fresh install on the new machine, upload the HA backup, restore it and youâre good to go.
Iâd say, the HA backup is much more important, than a VM backup, in a HA case!
Note, this is only valid for HA on Proxmox or other virtualization software. For all other things, it might be best to use a VM backup!
The 3-2-1 rule is a good practice. 3 copies of the data, on 2 different media, 1 off-site.
Mine is even more strange⌠![]()
I do my HA backup to my Nextcloud and GoogleDrive. The Nextcloud (and with it the HA backup) is synced once a day with a Hetzner Storage Box in Finland.
This must be enough, at least I hope so! ![]()
EDIT: and itâs really cheap, 1TB for 3,81âŹ/month⌠And BorgBackup is supported. ![]()
I do both because of different scenarios
Proxmox backup runs every month, and I only store the last 3 backups. Useful if you want a quick rebuild on existing hardware.
HA backups I trigger manually prior to an upgrade, then copy them to another device. Useful if your hardware dies and your backup hardware doesnât have proxmox installed
Seems like there a lot of similar but slightly different memory issues running HA in a Proxmox VM. In my case, I found that the memory would start to climb gradually (as reported by both HA and Proxmox) when the VM was started or restarted from Proxmox. Eventually, HA would run out of memory and lock up. However, if HA was restarted from within the HA UI, the memory would remain stable (eventually reports in Proxmox and fully utilized, but remains around 40-50% as reported by HA). You can see in the screen shot below that around 04:00, when Proxmox was scheduled to stop the VM and backup, the memory would start increasing. Then, around 11:00 I noticed and restarted from within HA.
My current solution is to run an automation using the Proxmox integration that restarts HAOS every time the âLast Bootâ entity is updated. If anyone has an idea on the root cause of this I would be happy to provide additional detail, but if not then hopefully this band-aid solution will be helpful to someone else.
Update - for some reason this stopped solving the issue. I was forced to actually find the cause and it turned out to be my M5 Atom Echo.
I have i440fx and still the problem. According to HA I use 2.8GB. According to proxmox 9.55GB of 10GB.
