I’m trying to link Home Assistant with Nest and followed the extensive manual step by step.
Now I’m stuck on the part where I’m adding the integration. Redirects to the Google Page, I Log in with my Nest Account (which is migrated to Google) and now it says: “No access to partner.”
Information could not be retrieved. Please contact HomeAssistant to verify that your account has been properly set up. You may need to add the developer email address as a home member in the Google Home app settings.
The later part I’ve tried, but as that is part of gSuite account you are not able to add this to Google Home.
So, it is a bit catch22. I’ve tried to add the account that is connected to Nest as a test User on the oAuth account, same result…
