Home Assistant - New Zealand
Great info thanks @Databitz I will look into the Bosch alarms
these are the 3 resources I have used in the past
https://www.global-mark.com.au/
https://equipment.erac.gov.au/Registration/EquipmentSearch.aspx?atn=public
I believe if they are OK in AU then they are good for NZ, Disclaimer: well that’s what I have read.
There are not different ZigBee channels on different regions.
There is a very long thread about Australian certified devices.
NZ and Oz have a combined approvals regime, if it is certified for AU it is certified for NZ and vice versa. It would pay the search or ask there. You’ll get a wider audience.
Search for Allterco and Shelly if your looking on global-mark.
https://www.global-mark.com.au/certificate-search/
Most devices are under Allterco, some of the latest are under Shelly. Allterco was the name of the company previously and Shelly was a brand they had, but now the company/group is also called Shelly.
Zigbee is the same channels and frequency.
However, Z-Wave, if they still do, use different frequencies depending on the region, I am sure the Z-Wave devices aren’t allowed in NZ or AU if the frequencies aren’t registered for that region as they could cause interference which is illegal so you have to purchase NZ licensed Z-Wave devices.
This may have all changed in the past 2 years but I doubt it.
I know, I didn’t argue with the statement that z-wave uses different frequencies in different regions.
sorry replied to the wrong post DOH
Hi fellow HA kiwi’s
Can anyone explain how to use the previously mentioned Metservice home assistant integration? I’ve not seen it available when adding an integration in HA.
I aim to read in a forecast for my Waikato location so that I can alert on forecast parameters (eg frost).
Many thanks.
GitHub - ciejer/metservice-weather: Metservice New Zealand component for Home Assistant - follow that :slight_smile:
Excellent, thanks.
The data coming back from the Metservice integration looks great. To use lat/long instead of a town/city I’d need to use the mobile API option, right?
Anyone know how to get one?
The GitHub discussion suggests it is a API key for the Metservice iOS app but no detail on how to obtain it.
I note that the forecast is not a sensor but named weather.Metservice_hamilton so I’m currently unsure how I’d specify that programmatically for notifications etc.
Cheers
The forecast still has has some attributes which you can get to like this:
{{ state_attr('weather.metservice_hamilton', 'temperature') }}
That will get you only the current temperature.
The weather sensors used to have the future forecasts also as attributes, but they don’t now.
A change was signaled last year and recently the future forecast attributes has been removed. See here for how to get at the forecast data now:
2023.9: New climate entity dialogs, lots of tile features, and template sensors from the UI! - Home Assistant
So now you need to use a service something like this:
- trigger:
    - platform: time_pattern
      hours: /1
    - service: weather.get_forecasts
        type: daily
        entity_id: weather.metservice_hamilton
      response_variable: daily
    - name: Hamilton Temperature Max Today
      unique_id: hamilton_temperature_max_today_new
      state: "{{ daily['weather.metservice_hamilton'].forecast[0].temperature }}"
      unit_of_measurement: °C
    - name: Hamilton Temperature Max Tomorrow
      unique_id: hamilton_temperature_max_tomorrow_new
      state: "{{ daily['weather.metservice_hamilton'].forecast[1].temperature }}"
    - name: Hamilton Condition Tomorrow
      unique_id: hamilton_weather_condition_tomorrow_new
      state: "{{ daily['weather.metservice_hamilton'].forecast[1].condition }}"
Thanks for the useful info.
Interested in ideas anyone has to automate turning off devices when there is a lot of load on the grid, like expected tomorrow morning.
Weather: Power cuts possible on one of coldest mornings of 2024: Auckland in for frosts, subzero temperatures around NZ (newstalkzb.co.nz)
The ask is to turn off non essential heating, and high load devices during the peak times.
I’ve currently got an automation which kinda does the job, based on fossil fuel generation. It triggers off the ā€œElectricity Maps Grid fossil fuel percentageā€ when it exceeds 22%.
Weird, I only have weather.metservice In my entities.
In my case I chose a city (Hamilton) and gave it a name ā€œhamiltonā€ replacing the default word ā€œhomeā€. This added _hamilton to the weather entity.
Hi Cody, thanks again for the integration. I just added today and it hasn’t seem to downloaded any data. I have the 9-12 free hours. Just like the other user below. Any support? (I am very beginner at this)
Has anyone had the Contact Energy integration working? I would love to know. Thanks a lot
I did, but in my old system. I have been rebuilding, but not got up to that but yet.
