Hi Nathan, I guess you may already have a solution for the gas bottle weighing. If not, i seem
to remember seeing that the gas bottle selector valve has a lever which the pressure differential flips over when changing supply bottle. Could you attach a microswitch to this lever and use the signal?
Just wondering…
Keep tinkering regards
Dangerousdave.
Hi David, yes we do have a gas bottle selector that switches over to the next bottle. I was also thinking about putting a Zigbee door/window sensor on it and tracking the open/closed state in Home Assistant. But in the end I decided to buy a “Lippert Bottlecheck Bluetooth GAS Gauge Single” from RV Super Centre. It just arrived a few days ago and I haven’t set it up yet, but it will also be nice to check the level of the gas bottle and see how much we are using each day, etc.
I just decided to get one, and will swap it over to the other gas bottle when one runs out. We only replace one bottle at a time, so hopefully I won’t lose it
Back when we had gas bottles in Auckland I was tinkering with load sensors and trying to weigh the bottles to determine home much was in the tank. I got some progress but then we moved down south with no more gas…
It was actually a bit of a mission and ended up taking most of the afternoon and evening. Our gas bottles were on a slight slope and the sensor complains if it’s not level, so I used an old monitor stand with 4 adjustable feet.
It also complains if the gas bottle is sitting directly on a flat surface (something to do with the ultrasonic sensor), so I used a few bits of wood to give it some more clearance. I was getting errors and 0-1 stars for quality until I leveled it properly.
Then I installed ESPHome on a ESP32 NodeMCU development board, and set up the Mopeka Pro Check BLE Sensor integration. The range is pretty decent, I was able to plug it into a socket about 8 meters away through a wall and it picks up the BLE signals.
Like you I have the same gas setup (Rockgas as well), and have thought about monitoring them - dont you have to manually change the sensor over to the bottom of the bottle every change?
FYI - I live in TGA and have all of our lights (Hue and Nanoleaf), Zigbee and Thread via SkyConnect, Z-Wave via USB stick, some Shelly stuff and a BT proxy. All of our internal and external lights, exterior doors are controlled via automations etc. I use a lot of timers in rooms with monitoring via hue motion sensors. Starting to get into ESPHome now and been using HAOS for about a year. I like the “if ute is home and ive forgotten to lock it, lock it at night” automation
We are all apple users here, so using homekit to trigger a helper in HA when we leave the house etc. This has been absolutely rock sold for home presence detection.
Things I want todo:
Add data from met service somehow (has anyone done this?)
Add bed occupancy to our master bed for lighting and heating control
As above, monitor gas bottle usage and automate re-ordering
Automate shower extractor fans with humidity sensors
Install power monitoring (have been thinking of a couple of Shelly 4PMs)
Fairly new to home assistant, but using it now in anger for a couple of months. I’m a kiwi living in South Island. Reason for post is I’ve got warm floor thermostats/title heating working with home assistant and from there into HomeKit. Required a mod to the local Tula integration but works pretty well. Warm floor is a Nz company so if anyone is interested in it let me know. I’ve had a chat to the company and they are going to put a howto up on their website.
Cheers
Miles
I did get this going and it seems to be fairly reliable, however I have not checked it out fully and I know that there is still issues at certain times of the day with the data. Plus all the div IDs are specific to Tauranga and you would need to change them for other cities. I just wish we had a proper API provided by the met service.
multiscrape:
- name: WeatherWatch Tauranga Forcast
resource: https://www.weatherwatch.co.nz/forecasts/Tauranga
scan_interval: 3600
- unique_id: weatherwatch_tauranga_summary
name: WeatherWatch Tauranga Summary
icon: mdi:text-long
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-66893679.forecast-heading.grid-item.grid-width-12 > p"
- unique_id: weatherwatch_tauranga_alertforcast
name: WeatherWatch Tauranga Alert Forcast
icon: mdi:cloud-alert
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-487647650.alert-wrapper.grid-width-12.alert-no-link-wrapper > div > div > div"
on_error:
log: false
value: default
default: "No Alerts"
- unique_id: weatherwatch_tauranga_currenttemp
name: WeatherWatch Tauranga Current Temperature
value_template: "{{ value.replace('°', '') }}"
state_class: measurement
unit_of_measurement: "°C"
device_class: temperature
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-66893679.forecast-summaries.grid-container.grid-width-12 > div.jsx-66893679.current-conditions.grid-item.grid-width-4 > div.jsx-3619355618.conditions-slider > div > div > div > div.slick-slide.slick-active.slick-current > div > div > div > div:nth-child(1) > div.jsx-3024714417.temp"
- unique_id: weatherwatch_tauranga_todaystemp
name: WeatherWatch Tauranga Todays Temperature
value_template: "{{ value.replace('°', '')|float(0) }}"
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-66893679.forecast-summaries.grid-container.grid-width-12 > div:nth-child(2) > div.jsx-238692970.forecast.day.grid-container-4 > div.jsx-238692970.summary-block.grid-item.grid-width-3 > div.jsx-238692970.temp"
- unique_id: weatherwatch_tauranga_tonightsstemp
name: WeatherWatch Tauranga Tonights Temperature
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-66893679.forecast-summaries.grid-container.grid-width-12 > div:nth-child(3) > div.jsx-238692970.forecast.night.grid-container-4 > div.jsx-238692970.summary-block.grid-item.grid-width-3 > div.jsx-238692970.temp"
- unique_id: weatherwatch_tauranga_rain
name: WeatherWatch Tauranga Rain
value_template: "{{ value.replace('mm', '')|float(0) }}"
unit_of_measurement: "mm"
device_class: precipitation
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-66893679.forecast-summaries.grid-container.grid-width-12 > div.jsx-66893679.current-conditions.grid-item.grid-width-4 > div.jsx-3619355618.conditions-slider > div > div > div > div.slick-slide.slick-active.slick-current > div > div > div > div.jsx-3024714417.bottom-section.grid-item.grid-width-4.grid-container-3 > div.jsx-3024714417.details.grid-item.grid-width-2 > span:nth-child(1)"
- unique_id: weatherwatch_tauranga_wind
name: WeatherWatch Tauranga Wind
value_template: "{{ value.split(' ')[1] | replace('km/h', '') }}"
unit_of_measurement: "km/h"
device_class: wind_speed
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-66893679.forecast-summaries.grid-container.grid-width-12 > div.jsx-66893679.current-conditions.grid-item.grid-width-4 > div.jsx-3619355618.conditions-slider > div > div > div > div.slick-slide.slick-active.slick-current > div > div > div > div.jsx-3024714417.bottom-section.grid-item.grid-width-4.grid-container-3 > div.jsx-3024714417.details.grid-item.grid-width-2 > span:nth-child(2)"
attributes:
- name: Wind Direction
value_template: "{{ value.split(' ')[0] }}"
- unique_id: weatherwatch_tauranga_humidity
name: WeatherWatch Tauranga Humidity
value_template: "{{ value.replace('%', '') }}"
unit_of_measurement: "%"
device_class: humidity
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-66893679.forecast-summaries.grid-container.grid-width-12 > div.jsx-66893679.current-conditions.grid-item.grid-width-4 > div.jsx-3619355618.conditions-slider > div > div > div > div.slick-slide.slick-active.slick-current > div > div > div > div.jsx-3024714417.bottom-section.grid-item.grid-width-4.grid-container-3 > div.jsx-3024714417.details.grid-item.grid-width-2 > span:nth-child(4)"
- unique_id: weatherwatch_tauranga_pressure
value_template: "{{ value.replace('hPa', '') }}"
unit_of_measurement: "hPa"
device_class: atmospheric_pressure
name: WeatherWatch Tauranga Pressure
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-66893679.forecast-summaries.grid-container.grid-width-12 > div.jsx-66893679.current-conditions.grid-item.grid-width-4 > div.jsx-3619355618.conditions-slider > div > div > div > div.slick-slide.slick-active.slick-current > div > div > div > div.jsx-3024714417.bottom-section.grid-item.grid-width-4.grid-container-3 > div.jsx-3024714417.details.grid-item.grid-width-2 > span:nth-child(5)"
- unique_id: weatherwatch_tauranga_chanceofrain
name: WeatherWatch Tauranga Chance Of Rain
select: "#__next > div.jsx-1060093929.grid-container.weather-forecast.for.tauranga > div.jsx-1060093929.grid-width-12.grid-wrapper.section-wrapper-home > div.jsx-66893679.forecasts-top-block-wrapper.grid-width-12 > div > div > div.jsx-66893679.forecast-summaries.grid-container.grid-width-12 > div:nth-child(2) > div.jsx-238692970.forecast.day.grid-container-4 > div.jsx-238692970.bottom-section.grid-item.grid-width-4.grid-container-3 > div.jsx-238692970.details.grid-item.grid-width-2 > span:nth-child(1)"
Adding to this NZ tread, im using the multiscrape HACS add-on to get Powershop daily rates based off excellent work from @joem & @xbmcnut in other threads. This works very well!
Now i have added the suggestion as follows which splits out the electrical charge and the daily power shop charge. I had to add the following entities:
No integration. You have to use multiscrape via HACS and then bring in the data. I could not find anything done already unfortunatly. Note Im only using it to get the powershop daily prices, not my usage. For usage im using a Shelly EM with a 120AMP clamp.
