Testing configuration at /home/fvicente/.homeassistant
ERROR:homeassistant.scripts.check_config:BURB
File "/usr/local/lib/python3.6/dist-packages/homeassistant/scripts/check_config.py", line 209, in check
check_ha_config_file(hass))
File "/usr/lib/python3.6/asyncio/base_events.py", line 484, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/dist-packages/homeassistant/scripts/check_config.py", line 326, in check_ha_config_file
core_config = CORE_CONFIG_SCHEMA(core_config)
File "/home/fvicente/.local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 267, in __call__
return self._compiled([], data)
File "/home/fvicente/.local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 589, in validate_dict
return base_validate(path, iteritems(data), out)
File "/home/fvicente/.local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 381, in validate_mapping
cval = cvalue(key_path, value)
File "/home/fvicente/.local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 811, in validate_callable
return schema(data)
File "/home/fvicente/.local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 368, in validate_mapping
new_key = ckey(key_path, key)
return schema(data)
File "/usr/local/lib/python3.6/dist-packages/homeassistant/helpers/config_validation.py", line 173, in entity_id
if valid_entity_id(value):
File "/usr/local/lib/python3.6/dist-packages/homeassistant/core.py", line 90, in valid_entity_id
slugify(entity_id) == entity_id.replace('.', '_', 1))
File "/usr/local/lib/python3.6/dist-packages/homeassistant/util/__init__.py", line 41, in slugify
return unicode_slug.slugify(text, separator='_') # type: ignore
TypeError: slugify() got an unexpected keyword argument 'separator'
Fatal error while loading config: slugify() got an unexpected keyword argument 'separator'
Failed config
General Errors:
- slugify() got an unexpected keyword argument 'separator'
Any can helpme?
