I have a GENERIC X86-64 Home Assistant installation running of an Intel DQ77KB board. After updating to the latest core my installation fails on the GRUB startup.
Both slots A and B display (OK=1 TRY=3)
then I get following message:
Booting ‘Slot B (rescue shell)’
EFI stub: ERROR: exit_boot() failed!
EFI stub: ERROR efi_stub_entry() failed!
error: start_image() returned 0x8000000000000005.
Failed both default and fallback entries.
and then it just hangs on the GRUB menu.
I knew I should have studied Linux instead of windows I am screwed…
Question is I guess, can something be salvaged or should I just reinstall and do the setup from scratch?
