this error now suggests something in /config/.storage/core.config_entries which is a json file isn’t correctly json formatted.
Quite weird if anything given this should be a fresh install so how is it non valid in the first place lol
It can be a long file but given what should be a fresh installation it should hardly have anything inside. Try cat /mnt/data/supervisor/homeassistant/.storage/core.config_entries in case it’s readable and not too long (need to login first)
Seems like everything in .storage is corrupted. Not sure whether rebuild will fix that.
Can potentially take it to the extreme, remove every single file and folder within /homeassistant which should theoretically get supervisor to make a fresh HA configuration. It could be that it doesn’t but it’s not like it can get worse anyway I guess.
This is the message I have been getting from day 1 when the system boots up. Look at the 3rd line from bottom regarding the FAT and corrupted files. Usually in DOS I would do a fdsk to check and repair. I’m not sure about Linx. Do u think the files might have been stored in those potentially faulty sectors???
Thou i also have this in my HOST logs, im really not sure what it implies, but i’ve never had any issues indicating hardware/file-corruptions
PS: Maybe it’s just trying to umount with FAT, to check whether it’s FAT, then it goes on the EXT4 which should be the right filesystem
EDIT: thou i just checked, mine is on SDA1, which is actually FAT16(it seems)
this is good. That’s the file where integration configuration lives. It’s saying the sun integration is set up which is correct as it is installed automatically in fresh installations. And also looks like a json file too. But not sure why every other dependency fails
Does still going at the IP of homeassistant on port 8123 not show onboarding?
