Hi there,
I’m just getting started with home assistant on odroid n2+
My question is, can I run flash android 9 on odroid and still run home assistant. (And be able to use it normally?)
The idea is to connect the odroid android 9 to the TV using the hdmi like a android box. And I still want to use home assistant and ad on store etc.
So firstly can this even be done?
If yes, is it hard to do since I’m just a beginner?
Finally, will home assistant run smoothly?
Thanks a lot!
