I’m new to home assistant and currently trying to flash the operating system to odroid n2
I read the installation guide for odroids and I get stuck eith an error on my computer. When I connect odroid to my laptop using a micro usb cable and run the codes (ls /devmmc*) etc
I get an error message on the notification panel of the laptop and it says device not recognised. I tried it in several laptops and still the same problem occurs.
I tried installing drivers, at this point I’m thinking either the odroid is or emmc is faulty? Or I’m clearly missing something.
Did you actually follow the full instructions, i.e. changing the switch on the odroid board, hook up keyboard, hook the odroid to a monitor, etc, etc… ?
The ls /devmmc* you mention happens on the odroid, not on your laptop.
Short answer: No
Long answer: Well, just no, unless you are able to build a custom kernel and a custom android image, but then I guess you wouldn’t ask
Ubuntu and Android are 2 completely different things.
Ubuntu is still a Linux OS.
Android is just using a linux kernel.
Supervised on Ubuntu will work but is not supported. Considering you don’t seem to know your way around those notions very well, I’d very much discourage you to use anything else than Debian 11, or you will be on your own if you encounter issues.
HAOS is another Linux OS, which packages together an OS and HA itself.
Debian 11 would be the base OS if you would use the “supervised” HA installation method.
So if I just install supervised. Will i automatically have debian 11?
What I’m trying to achieve now is: if i can have android 9. Then i would rather have a PC functionality on it and plug it into a monitor. At least than i can use it as a “computer” while still running home assistant and its ad ons
Sorry to be blunt, but you don’t seem in a knowledge position to do “fancy” stuff.
Forget about android and use HAOS on your Odroid as you originally planned.
Theres no need to be blunt here mate.
I’m simply familiarising myself with odroids and home assistant.
You can simply tell me to be careful and not indulge in anything I’m not sure about.
Thanks for your help. I won’t be asking you for more help.
