Has anyone been able to use Razberry (http://razberry.z-wave.me/) with HA? This looks like it could be a pretty good setup and clean too in that you would not have any ZWave sticks hanging off the USB ports. But before I tried one I thought I would see if it would integrate with HA.
Iāve used the razberry in HA daily for around 3months now and it works really good once itās installed
I assume, then, there are some tips and tricks, ins and outs to the install process? Looking at the website it seemed rather straight forward but I thought that too of the bridge to try and get HA to work with my SmartThings HUB.
I have a few (4 or 5 ) zigbee devices, mainly door sensors that I will swap out zwave based ones if Razberry will work well enough.
Iāve also been using the Razberry for a long time with HA. At first on a raspberry pi 2, now with a raspberry pi 3. I did have to run the z-wave.me installer before it would work, but I disabled all of the extra services it enables by default.
I think I only have around 5 or so devices hooked up using z-wave, but I havenāt really had any issues with the razberry card. Itās really nice to not have to have a big zwave usb stick hanging out of the pi though.
Post here if you have any issues getting it set up =D
@justyns thank you for that. So, do I understand correctly, you donāt have to use the Z-Wave.me software to use the Razberry? The Razberry will detect your ZWave devices and allow you to automate them with HA? I just want to be sure before I purchase one.
The thought of this is getting me pumped up that I can finally move my home automation in-house (well, I assume all but the garage door opener from what I understand) and be able to set things up exactly how I want them rather than what some vendor āthinksā I will want or need. Iām ready to buy the Razberry, just got to make sure it will all integrate and work well as I have nearly 30 ZWave devices in my house.
Thatās correct you donāt have to use the z-wave.me, Iām running one on my rpi3. However, there is an issue - if you wish to use bluetooth on the rpi3 I would suggest getting a z-wave usb dongle instead. See Raspberry pi 3 + Razberry z-wave-me GPIO daughter card
@justyns the z-wave.me installer just sets pi3-disable-bt else it conflicts
Alrighty then. Thank you @samriley. I had ordered the Aeon Labs USB stick but I donāt mind ordering the Razberry as well. Could be a good opportunity to experiment with both. Perhaps buy another RPi and use one for development and the other for production sort of thing. Or just learn both so that perhaps I can help others set thiers up.
samriley: what exactly did you do to get it to work? (explained so that a complete beginner can understand )
Iāve got a rpi3 and a razberry. I installed everything with the āRaspberry Pi All-In-One Installerā. Iāve been fiddling with different usb paths in the yaml and turning off bluetooth and setting āCore_freq=250ā in the config.txt as suggested in different threads.
When all is upp and running, how do you confirm that it is working?
Edit: Iāve got the razberry software up and running. I will also specify my questions.
- What should I add in the yaml file?
- What should I add in the config.txt file?
3a) Can it be different configurations in the yaml and config files on two separate RPi3?
3b) If yes in 3a, why? - How do you confirm that the configurations is working?
- Hereās the āzwaveā part of my configuration.yaml (you might not need polling_interval, but it was required for some of my sensors to update):
zwave:
config_path: /srv/hass/src/python-openzwave/openzwave/config
usb_path: /dev/ttyAMA0
polling_interval: 30000
- This is my config.txt file, but note that I do not have bluetooth working and I do not remember what was default vs what wasnāt default. I didnāt need to change config.txt at all originally, but started messing with it to try and get bluetooth working (@samriley mentioned that earlier)
dtparam=audio=on
gpu_mem=16
dtoverlay=pi3-miniuart-bt
core_freq=250
enable_uart=1
- The openzwave and usb path could both be different depending on how everything was installed. Itās also possible to configure udev to give your razberry (or aeon stick) a different device name.
- Depending on the z-wave devices youāre using, you should see them added to home-assistant on the default page. You can check the log as well to see if there are any errors.
Also, keep in mind that youāll need to add devices to your zwave network. I donāt think you can add one device to both your razberry and aeon stick at the same time, but someone could correct me if Iām wrong.
Thank you, now it is up an running! After a myriad of reboots and adding and removing devices
These are the steps (for me)
Installed HA with the All-in-one installer. Followed all steps in this video: https://youtu.be/VGl3KTrYo6s
Added this to the yaml file:
config_path: /srv/hass/hass_venv/lib/python3.4/site-packages/libopenzwave-0.3.1-py3.4-linux-armv7l.egg/config(USB path from @justyns example)
(Config path from this video: https://www.youtube.com/watch?v=ajklDCaOGwY) -
Added this to the config.txt
core_freq=250
dtoverlay=pi3-disable-bt -
Installed RaZberry
Added devices in the RaZberry page, YourIP:8083 and they showed up in HA!
I guess you can add devices from HA with the zwave/add_node service?
I think Iām starting to understand how it all works now! Thanks again
For some reason not all my nodeās are pulling into home assistant? Anyone know why?
Also when running home assistant my razberry pages shows no devices and gives me an error saying it is unable to initialise the z-wave controller data.
17-02-13 20:09:44 ERROR (Dummy-21) [openzwave] Error in manager callback
File ā/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/network.pyā, line 974, in zwcallback
self._handle_essential_node_queries_complete(args)
File ā/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/network.pyā, line 1266, in _handle_essential_node_queries_complete
**{ānetworkā: self, ānodeā: self.nodes[args[ānodeIdā]]})
KeyError: 18
17-02-13 20:14:41 ERROR (Dummy-21) [openzwave] Error in manager callback
File ā/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/network.pyā, line 948, in zwcallback
self._handle_value_added(args)
File ā/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/network.pyā, line 1474, in _handle_value_added
self.nodes[args[ānodeIdā]].add_value(args[āvalueIdā][āidā])
KeyError: 11
I have the same problem, did you find any solution?
//Fredrik
I also have the same problem with not being able to run homeassistant parallel to the razberry UI. Did you find any solution?
You can not run two different zwave applications at the same time. In order to have HA handle your Zwave you need to disable the razberry service (z-way).
After you have install the razberry device. Run this:
sudo update-rc.d disable z-way-server
Edit /boot/config.txt. Add this:
I added this to my HA configuration.yaml:
zwave:
config_path: /srv/homeassistant/lib/python3.4/site-packages/libopenzwave-0.3.2-py3.4-linux-armv7l.egg/config
device_config: !include zwave_device_config.yaml
This will get you into the open zway control panel:
Make sure Home Assistant is not running! So stop that first
Login to Raspberry Pi ssh pi@your_raspberry_pi_ip
Change to the ozwcp directory cd /srv/homeassistant/src/open-zwave-control-panel/
Launch the control panel sudo ./ozwcp -p 8888
Open a web browser to http://your_pi_ip:8888
Specify your zwave controller, for example /dev/ttyACM0 (this should be /dev/ttyAMA0) and hit initialize
Your zwave config_path may be different and your usb_path may also be different. Hope this helps out.
Check out https://community.home-assistant.io/t/unable-to-configure-razberry-board-with-openzwave/4686/5 for more information
Lastly HA 0.43.0 killed my zwave so I had to roll it back for now.
Thank you very much!
It looks like everything is working but I will have to verify when I get home.
Note, the command to disable was:
sudo update-rc.d z-way-server disable
where can I find zwave_device_config.yaml ?
Just make an empty file with that name.
what step will fill the write config to this file?
my question is how the configuration we do on http://your_pi_ip:8888/ gets to the yams file?
thanks!
There is literally nothing in my zwave_device_config.yaml file. I only have it because HA requires it. That file you are talking about is completely different to this yaml file.
Thanks, @jordanb05 . This almost got me thereā¦
I have installed the SD card via Hassbian, and the paths seem similar to yours. However, mine seem to be version 0.4.0 and I presume some filename changes have occurred.
None of the folders (see below) have a config
subfolder, but there is ozw_config
in one. Iām going to try that. In case you already know what works with 0.4.0, Iād be happy to hear.
$ ls /srv/homeassistant/lib/python3.4/site-packages/*openz*
/srv/homeassistant/lib/python3.4/site-packages/libopenzwave.cpython-34m.so
/srv/homeassistant/lib/python3.4/site-packages/libopenzwave-0.4.0.35.egg-info:
dependency_links.txt not-zip-safe PKG-INFO requires.txt SOURCES.txt top_level.txt
/srv/homeassistant/lib/python3.4/site-packages/openzwave-0.4.0.35-py3.4.egg:
EGG-INFO openzwave
/srv/homeassistant/lib/python3.4/site-packages/python_openzwave:
ozw_config
/srv/homeassistant/lib/python3.4/site-packages/python_openzwave-0.4.0.35-py3.4-linux-armv7l.egg:
EGG-INFO libopenzwave.cpython-34m.so libopenzwave.py openzwave __pycache__ pyozwman python_openzwave
In case others share my situation (Hassbian + RaZberry, with 0.4.0 Openzwave), please answer here what worked for you.
Adding:
config_path: /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config
ā¦did indeed make HA start without warnings, for me. Iām still not sure if thatās the intended folder, though.
