already three times in a row I could not turn on lights in the morning. Then I realized, HA is not accessible. Restarting router does not change it. Only plugging out and in my RPI 4 from power grid forced HA to restart. I use proper power source. Can this be caused by a bad sd card? I checked logs in supervisor and there is nothing suspicious.
Which is not necessarily bad thing if all custom components and addons remain included, however, I guess snapshots do not contain third party addons such as hacs and its content.
Anybody some ideas what logs could I check to know what is happening?
Had similar issue some time ago, when recorder DB get out of control (30GB+). I had it configured to keep almost everything and up to 30 days of history. Then one day (30 days from recent installationā¦ what a conincident ) I started to have problems with HA hanging or barely responding. Events were not recorded, or recorded with several minutes delay, same with any actions. Turned out recorder started purge of DB process, that was so heavy operation for such large DB, that it virtually killed HA. If this is the case, it should start around 4AM, when HA performs purge by default.
Having the same issue, noticed it after upgrading from Home Assistant OS 5.8 -> 5.9. Randomly the RPi freezes and I must pull the power, UI is not accessible nor can I access it through SSH. This seem to happen more than once per 24 hours. Didnāt see anything like this on 5.8 so until this is solved, is there a way to downgrade to 5.8?
Ok looks we have the same problem. You sure downgrading the core will not cause more damage? Have you found an official/supported method how to do it to be sure we do what the developers count on?
I recently used a snapshot to move from an SD card to an SSD drive, as well as from a 32 bit install to a 64 bit install, and HACS was successfully restored along with the lone repository Iām using.
When using an SD card, I would occasionally (~monthly) create a clone of the card, which in addition to more current snapshots would make a restore from a card failure go quickly. Now that Iām using an SSD drive I will need to create a .img file using Win32DiskImager and save that to a different device since I donāt have a second SSD drive. Thatās no more difficult than cloning an SD card. The only issue with either option is the downtime while you have the disk pulled in order to create the backup copy.
I wonder if as the OS grows in size it may also be consuming more power, and the issue is your power supply? I believe the Rpi4 needs a minimum of 3 amps. I havenāt checked mine since itās running just fine, but I do have one of these I would use to see what itās drawing: https://tinyurl.com/ycemztur
Downgraded it to 5.8 using:
ha os update --version 5.8
I am curious to see if this will solve the problem, the downgrade itself worked just fine and HA is up and running as normal. Letās see if it will hang again.
Make sure you have installed the addon called āTerminal & SSHā, then use either SSH from your computer or go to the addon and open the Web UI and then from the command prompt run the command:
That will initiate the downgrade and restart your RPi.
BTW, I am running on a RPi 4 8Gb with a new SD Card if that is any information that might be needed.
