Hi
i cannot find the problem, why my HA restarts every night.
I am missing the log files from 00:00 am till 00:27 am.
Here is the screenshot:
2022-02-17 00:27:28 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_cloud_map_extractor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-17 00:27:28 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-17 00:27:28 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-17 00:27:30 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-02-17 00:27:31 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=64 from 2022-02-16 11:18:36.605860)
2022-02-17 00:27:31 WARNING (MainThread) [homeassistant.components.lovelace] Lovelace is running in storage mode. Define resources via user interface
2022-02-17 00:27:44 ERROR (MainThread) [homeassistant.components.vacuum] The xiaomi_miio platform for the vacuum integration does not support platform setup. Please remove it from your config.
2022-02-17 00:27:52 WARNING (MainThread) [homeassistant.setup] Setup of hacs is taking over 10 seconds.
2022-02-17 00:27:54 ERROR (MainThread) [homeassistant.components.sensor] Platform hacs does not generate unique IDs. ID 0717a0cd-745c-48fd-9b16-c8534c9704f9-bc944b0f-fd42-4a58-a072-ade38d1444cd already exists - ignoring sensor.hacs
2022-02-17 00:27:54 ERROR (MainThread) [zigpy.application] Couldn't start application
2022-02-17 00:27:54 WARNING (MainThread) [homeassistant.helpers.entity] Update of camera.xiaomi_cloud_map_extractor is taking over 10 seconds
2022-02-17 00:27:54 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
File "/usr/local/lib/python3.9/site-packages/serial/serialposix.py", line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2412261-if00'
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 152, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.9/site-packages/zigpy/application.py", line 69, in new
await app.startup(auto_form)
File "/usr/local/lib/python3.9/site-packages/zigpy_deconz/zigbee/application.py", line 66, in startup
await self._api.connect()
File "/usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py", line 253, in connect
self._uart = await zigpy_deconz.uart.connect(self._config, self)
File "/usr/local/lib/python3.9/site-packages/zigpy_deconz/uart.py", line 142, in connect
_, protocol = await serial_asyncio.create_serial_connection(
File "/usr/local/lib/python3.9/site-packages/serial_asyncio/__init__.py", line 448, in create_serial_connection
serial_instance = serial.serial_for_url(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/serial/__init__.py", line 90, in serial_for_url
instance.open()
File "/usr/local/lib/python3.9/site-packages/serial/serialposix.py", line 325, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2412261-if00: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2412261-if00'
2022-02-17 00:27:54 WARNING (MainThread) [homeassistant.config_entries] Config entry 'ConBee II, s/n: DE2412261 - dresden elektronik ingenieurtechnik GmbH' for zha integration not ready yet: [Errno 2] could not open port /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2412261-if00: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2412261-if00'; Retrying in background
2022-02-17 00:28:00 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'int' got invalid input 'unknown' when rendering template '{% set count = states('sensor.regenmesser') | int %} {% set mm_per_pulse = 0.30303 %} {% set mm = count * mm_per_pulse %} {{ mm|round(1, 'floor') }}' but no default was specified. Currently 'int' will return '0', however this template will fail to render in Home Assistant core 2022.1
2022-02-17 00:28:04 ERROR (MainThread) [zigpy.application] Couldn't start application
2022-02-17 00:28:04 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
instance.open()
2022-02-17 00:28:17 ERROR (MainThread) [zigpy.application] Couldn't start application
2022-02-17 00:28:17 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
instance.open()
2022-02-17 00:28:37 ERROR (MainThread) [zigpy.application] Couldn't start application
2022-02-17 00:28:37 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
instance.open()
2022-02-17 00:29:18 ERROR (MainThread) [zigpy.application] Couldn't start application
2022-02-17 00:29:18 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
instance.open()
2022-02-17 00:30:38 ERROR (MainThread) [zigpy.application] Couldn't start application
2022-02-17 00:30:38 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
instance.open()
Can anybody help me?
I dont understand the logs and cannot retrace, why the system is shutting down every night.
Here is my problem describted:
