Hi, I am testing HA on a laptop. Is there a command to turn off the monitor or set a screensaver?
You can execute shell command using home assistant or just set the power settings of computer to turn off screen after 10 minutes or so
I have so far not found a “screensaver” command I can run in the HA server shell, and my laptop BIOS has no power settings to accomplish this.
Thank you for your suggestions.
Same issue here, is there a screen saver?
Seems in short: enable the addon from the +addon shop ssh terminal, there you can then edit a file adding a line or more lines. I myself couldnt get it working like that, maybe to less experience with the terminal, I decided to close the lid (Lenovo T430) which does close the screen. Turn off laptop screen running Hassio
