Home assistant - starting not everything available yet?
Hi guys,
I’m running homeassistant for a few years now. Did a few rebuilds to tidy everything up and that usually did the job.
Not long ago I rebuild my system and it has been working great, until I saw this morning that it couldn’t start properly!
This should be lights and sensor details
This is an error from recorder:
log recorder warning
So this are my details:
SYSTEM HEALTH:
arch x86_64
chassis vm
dev false
docker true
docker_version 19.03.11
hassio true
host_os HassOS 4.12
installation_type Home Assistant OS
os_name: Linux
os_version: 5.4.56
python_version: 3.8.3
supervisor: 242
timezone: Europe/Amsterdam
version: 0.114.4
virtualenv: false
Lovelace
dashboards: 2
mode: storage
resources: 3
These are the logs:
SUPERVISOR Log
20-09-10 16:09:04 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
20-09-10 16:10:41 INFO (SyncWorker_0) [supervisor.docker.interface] Clean addon_core_configurator application
20-09-10 16:10:42 INFO (SyncWorker_0) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-configurator with version 5.0.0
20-09-10 16:14:18 INFO (MainThread) [supervisor.host.control] Initialize host reboot over systemd
20-09-10 16:14:18 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' stop 1 add-ons
20-09-10 16:14:18 INFO (SyncWorker_1) [supervisor.docker.interface] Stop addon_core_configurator application
20-09-10 16:14:22 INFO (SyncWorker_1) [supervisor.docker.interface] Clean addon_core_configurator application
20-09-10 16:14:22 ERROR (MainThread) [supervisor.utils] Can't execute stop while a task is in progress
20-09-10 16:14:22 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' stop 4 add-ons
20-09-10 16:14:22 INFO (SyncWorker_2) [supervisor.docker.interface] Stop addon_core_samba application
20-09-10 16:14:26 INFO (SyncWorker_2) [supervisor.docker.interface] Clean addon_core_samba application
20-09-10 16:14:26 INFO (SyncWorker_0) [supervisor.docker.interface] Stop addon_core_rpc_shutdown application
20-09-10 16:14:26 INFO (SyncWorker_0) [supervisor.docker.interface] Clean addon_core_rpc_shutdown application
20-09-10 16:14:26 INFO (SyncWorker_4) [supervisor.docker.interface] Stop addon_core_ssh application
20-09-10 16:14:30 INFO (SyncWorker_4) [supervisor.docker.interface] Clean addon_core_ssh application
20-09-10 16:14:30 INFO (SyncWorker_1) [supervisor.docker.interface] Stop addon_core_zwave application
20-09-10 16:14:36 INFO (SyncWorker_1) [supervisor.docker.interface] Clean addon_core_zwave application
20-09-10 16:14:36 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' stop 2 add-ons
20-09-10 16:14:36 INFO (SyncWorker_2) [supervisor.docker.interface] Stop addon_core_mariadb application
20-09-10 16:14:42 INFO (SyncWorker_2) [supervisor.docker.interface] Clean addon_core_mariadb application
20-09-10 16:14:42 INFO (SyncWorker_7) [supervisor.docker.interface] Stop addon_core_mosquitto application
20-09-10 16:14:43 INFO (SyncWorker_7) [supervisor.docker.interface] Clean addon_core_mosquitto application
20-09-10 16:14:43 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' stop 0 add-ons
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[16:16:33] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[16:16:33] INFO: Start local supervisor watchdog...
20-09-10 16:16:34 INFO (MainThread) [__main__] Initialize Supervisor setup
20-09-10 16:16:35 INFO (MainThread) [supervisor.bootstrap] Initialize Supervisor Sentry
20-09-10 16:16:35 INFO (MainThread) [supervisor.bootstrap] Setup coresys for machine: qemux86-64
20-09-10 16:16:35 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 242
20-09-10 16:16:35 INFO (MainThread) [__main__] Setup Supervisor
20-09-10 16:16:35 INFO (MainThread) [supervisor.host.info] Update local host information
20-09-10 16:16:35 INFO (MainThread) [supervisor.host.services] Update service information
20-09-10 16:16:35 INFO (MainThread) [supervisor.host.network] Update local network information
20-09-10 16:16:35 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-09-10 16:16:35 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-09-10 16:16:35 INFO (MainThread) [supervisor.host.services] Reload local service hassos-apparmor.service
20-09-10 16:16:35 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-dns with version 9
20-09-10 16:16:35 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin
20-09-10 16:16:35 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_dns application
20-09-10 16:16:36 INFO (SyncWorker_0) [supervisor.docker.dns] Start DNS homeassistant/amd64-hassio-dns with version 9 - 172.30.32.3
20-09-10 16:16:36 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-09-10 16:16:36 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-audio with version 17
20-09-10 16:16:36 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin
20-09-10 16:16:36 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_audio application
20-09-10 16:16:38 INFO (SyncWorker_0) [supervisor.docker.audio] Start Audio homeassistant/amd64-hassio-audio with version 17 - 172.30.32.4
20-09-10 16:16:38 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-cli with version 26
20-09-10 16:16:38 INFO (MainThread) [supervisor.plugins.cli] Start cli plugin
20-09-10 16:16:38 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_cli application
20-09-10 16:16:39 INFO (SyncWorker_0) [supervisor.docker.cli] Start CLI homeassistant/amd64-hassio-cli with version 26 - 172.30.32.5
20-09-10 16:16:39 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-multicast with version 3
20-09-10 16:16:39 INFO (MainThread) [supervisor.plugins.multicast] Start Multicast plugin
20-09-10 16:16:39 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_multicast application
20-09-10 16:16:39 INFO (SyncWorker_0) [supervisor.docker.multicast] Start Multicast homeassistant/amd64-hassio-multicast with version 3 - Host
20-09-10 16:16:39 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-09-10 16:16:40 INFO (MainThread) [supervisor.homeassistant.secrets] Load Home Assistant secrets: 1
20-09-10 16:16:40 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.114.4
20-09-10 16:16:40 INFO (MainThread) [supervisor.hassos] Detect HassOS 4.12 / BootSlot B
20-09-10 16:16:40 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-09-10 16:16:40 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-09-10 16:16:40 INFO (MainThread) [supervisor.store] Load add-ons from store: 66 all - 66 new - 0 remove
20-09-10 16:16:40 INFO (MainThread) [supervisor.addons] Found 8 installed add-ons
20-09-10 16:16:40 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-configurator with version 5.0.0
20-09-10 16:16:40 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-mariadb with version 2.2.1
20-09-10 16:16:40 INFO (SyncWorker_3) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-zwave with version 0.5.2
20-09-10 16:16:40 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-mosquitto with version 5.1
20-09-10 16:16:40 INFO (SyncWorker_5) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-ssh with version 8.7.0
20-09-10 16:16:40 INFO (SyncWorker_4) [supervisor.docker.interface] Attach to hassioaddons/node-red-amd64 with version 7.1.1
20-09-10 16:16:40 INFO (SyncWorker_7) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-samba with version 9.2.0
20-09-10 16:16:40 INFO (SyncWorker_6) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-rpc_shutdown with version 2.2
20-09-10 16:16:40 INFO (MainThread) [supervisor.snapshots] Found 1 snapshot files
20-09-10 16:16:40 INFO (MainThread) [supervisor.discovery] Load 2 messages
20-09-10 16:16:40 INFO (MainThread) [supervisor.ingress] Load 6 ingress session
20-09-10 16:16:40 INFO (MainThread) [__main__] Run Supervisor
20-09-10 16:16:40 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-09-10 16:16:40 INFO (MainThread) [supervisor.hassos] Rauc: B - marked slot kernel.1 as good
20-09-10 16:16:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' start 0 add-ons
20-09-10 16:16:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' start 2 add-ons
20-09-10 16:16:41 INFO (SyncWorker_2) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-mariadb with version 2.2.1
20-09-10 16:16:43 INFO (SyncWorker_6) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-mosquitto with version 5.1
20-09-10 16:16:44 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
20-09-10 16:16:44 INFO (MainThread) [supervisor.services.modules.mysql] Set core_mariadb as service provider for MySQL
20-09-10 16:16:48 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' start 4 add-ons
20-09-10 16:16:49 INFO (SyncWorker_1) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-samba with version 9.2.0
20-09-10 16:16:49 INFO (SyncWorker_7) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-rpc_shutdown with version 2.2
20-09-10 16:16:50 INFO (SyncWorker_2) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-ssh with version 8.7.0
20-09-10 16:16:51 INFO (SyncWorker_6) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-zwave with version 0.5.2
20-09-10 16:16:56 INFO (SyncWorker_7) [supervisor.docker.interface] Start homeassistant
20-09-10 16:16:57 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
20-09-10 16:17:02 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
20-09-10 16:47:03 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
CORE Logs
2020-09-10 17:42:19 INFO (SyncWorker_6) [homeassistant.loader] Loaded solaredge from homeassistant.components.solaredge
2020-09-10 17:42:19 INFO (SyncWorker_26) [homeassistant.loader] Loaded adguard from homeassistant.components.adguard
2020-09-10 17:42:19 INFO (SyncWorker_23) [homeassistant.loader] Loaded wemo from homeassistant.components.wemo
2020-09-10 17:42:19 INFO (SyncWorker_17) [homeassistant.loader] Loaded local_ip from homeassistant.components.local_ip
2020-09-10 17:42:19 INFO (SyncWorker_22) [homeassistant.loader] Loaded dynalite from homeassistant.components.dynalite
2020-09-10 17:42:19 INFO (SyncWorker_30) [homeassistant.loader] Loaded sms from homeassistant.components.sms
2020-09-10 17:42:19 INFO (SyncWorker_29) [homeassistant.loader] Loaded upb from homeassistant.components.upb
2020-09-10 17:42:19 INFO (SyncWorker_49) [homeassistant.loader] Loaded pi_hole from homeassistant.components.pi_hole
2020-09-10 17:42:19 INFO (SyncWorker_54) [homeassistant.loader] Loaded guardian from homeassistant.components.guardian
2020-09-10 17:42:19 INFO (SyncWorker_58) [homeassistant.loader] Loaded griddy from homeassistant.components.griddy
2020-09-10 17:42:19 INFO (SyncWorker_16) [homeassistant.loader] Loaded ecobee from homeassistant.components.ecobee
2020-09-10 17:42:19 INFO (SyncWorker_11) [homeassistant.loader] Loaded sonarr from homeassistant.components.sonarr
2020-09-10 17:42:19 INFO (SyncWorker_43) [homeassistant.loader] Loaded august from homeassistant.components.august
2020-09-10 17:42:19 INFO (SyncWorker_40) [homeassistant.loader] Loaded dialogflow from homeassistant.components.dialogflow
2020-09-10 17:42:19 INFO (SyncWorker_1) [homeassistant.loader] Loaded poolsense from homeassistant.components.poolsense
2020-09-10 17:42:19 INFO (SyncWorker_51) [homeassistant.loader] Loaded glances from homeassistant.components.glances
2020-09-10 17:42:19 INFO (SyncWorker_14) [homeassistant.loader] Loaded dunehd from homeassistant.components.dunehd
2020-09-10 17:42:19 INFO (SyncWorker_35) [homeassistant.loader] Loaded xiaomi_aqara from homeassistant.components.xiaomi_aqara
2020-09-10 17:42:19 INFO (SyncWorker_44) [homeassistant.loader] Loaded minecraft_server from homeassistant.components.minecraft_server
2020-09-10 17:42:19 INFO (SyncWorker_39) [homeassistant.loader] Loaded izone from homeassistant.components.izone
2020-09-10 17:42:19 INFO (SyncWorker_24) [homeassistant.loader] Loaded ring from homeassistant.components.ring
2020-09-10 17:42:19 INFO (SyncWorker_2) [homeassistant.loader] Loaded isy994 from homeassistant.components.isy994
2020-09-10 17:42:25 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook b3b734889260643f4161a7a14939aecef1e17546be1eb6d1374bb9b1068d82ed from 192.168.1.1
2020-09-10 17:42:30 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook b3b734889260643f4161a7a14939aecef1e17546be1eb6d1374bb9b1068d82ed from 192.168.1.1
2020-09-10 17:42:49 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301391880448] Connection closed by client
2020-09-10 17:43:12 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 75c685d07ed1864b7810b0d8c180c02125b601f74e9ddb81334a5a14735bc708 from 192.168.1.1
2020-09-10 17:43:43 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301322345344] Connection closed by client
2020-09-10 17:44:23 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301322355376] Connection closed by client
2020-09-10 17:45:43 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301325936720] Connection closed by client
2020-09-10 17:47:00 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 75c685d07ed1864b7810b0d8c180c02125b601f74e9ddb81334a5a14735bc708 from 192.168.1.1
2020-09-10 17:47:43 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301325821696] Connection closed by client
2020-09-10 17:48:00 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 75c685d07ed1864b7810b0d8c180c02125b601f74e9ddb81334a5a14735bc708 from 192.168.1.1
2020-09-10 17:49:01 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301325803584] Connection closed by client
2020-09-10 17:49:43 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301325821792] Connection closed by client
2020-09-10 17:50:52 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301410860816] Connection closed by client
2020-09-10 17:52:08 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301391186240] Connection closed by client
2020-09-10 17:53:43 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301368489824] Connection closed by client
2020-09-10 17:54:21 ERROR (MainThread) [homeassistant.components.hassio.handler] /homeassistant/restart return code 500
2020-09-10 17:54:41 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook b3b734889260643f4161a7a14939aecef1e17546be1eb6d1374bb9b1068d82ed from 192.168.1.1
2020-09-10 17:54:51 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301391185280] Connection closed by client
2020-09-10 17:55:47 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301366833408] Connection closed by client
2020-09-10 17:56:08 ERROR (MainThread) [homeassistant.components.hassio.handler] /homeassistant/restart return code 500
2020-09-10 17:56:38 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301366856240] Connection closed by client
2020-09-10 17:57:09 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140301366820576] Connection closed by client
2020-09-10 17:57:25 WARNING (Thread-5) [homeassistant.components.mqtt] Disconnected from MQTT server core-mosquitto:1883 (1)
[fix-attrs.d] done.
[17:59:53] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
2020-09-10 17:59:57 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 17:59:57 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for samsungtv_smart which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 17:59:58 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=99 from 2020-09-10 15:42:09)
2020-09-10 18:00:01 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for afvalwijzer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 18:00:01 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for omnik which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 18:00:03 INFO (MainThread) [backoff] Backing off call_api(...) for 0.7s (asyncio.exceptions.CancelledError)
2020-09-10 18:06:53 ERROR (MainThread) [homeassistant.components.hassio.handler] /homeassistant/restart return code 500
[fix-attrs.d] done.
[18:08:54] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
2020-09-10 18:08:57 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for samsungtv_smart which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 18:08:57 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 18:09:00 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for afvalwijzer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 18:09:00 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for omnik which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 18:13:19 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook b3b734889260643f4161a7a14939aecef1e17546be1eb6d1374bb9b1068d82ed from 192.168.1.1
2020-09-10 18:14:42 WARNING (Thread-5) [homeassistant.components.mqtt] Disconnected from MQTT server core-mosquitto:1883 (1)
[fix-attrs.d] done.
[18:16:57] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
2020-09-10 18:17:00 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 18:17:00 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for samsungtv_smart which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 18:17:01 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=100 from 2020-09-10 15:59:58)
2020-09-10 18:17:03 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for afvalwijzer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-10 18:17:03 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for omnik which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
Here are my host logs: https://pastebin.com/BvmK2VCb (it’s to long, to post here)
Thanks!
With kind regards,
Dennis
I saw a few lines of error:
[    2.626535] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
[    2.629209] ext4 filesystem being mounted at /mnt/overlay supports timestamps until 2038 (0x7fffffff)
[    2.641726] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    2.703569] EXT4-fs (sda8): mounted filesystem with ordered data mode. Opts: (null)
[    3.433013] Adding 1005272k swap on /dev/zram0.  Priority:-2 extents:1 across:1005272k SS
[    4.436987] EXT4-fs (zram2): mounted filesystem without journal. Opts: nobarrier
[    4.438820] ext4 filesystem being mounted at /tmp supports timestamps until 2038 (0x7fffffff)
[    4.439188] EXT4-fs (zram1): mounted filesystem without journal. Opts: nobarrier
[    4.442626] ext4 filesystem being mounted at /var supports timestamps until 2038 (0x7fffffff)
These look important, how do I fix these?
I have the same issues after a restart with supervisor. thought it was hardware but I ruled that out after some hours of testing everything.
Take a look here as there may be problem with custom integration for afvalwijzer
I thought omnik broke it. But it also may be HACS.
I rebuild again, just added improvements and such. Ima try to add some custom components to see whats happening. I have multiple backups and snapshots (not hass but VM) but those don’t do you any good when the confif was broken lol
