Ok i installed the serial USB driver on the Synology but i still can’t get it working. This is the log in OZW_Log.tx in homeassistant
2019-12-09 14:20:25.348 Always, OpenZwave Version 1.4.3440 Starting Up
2019-12-09 14:20:27.361 Info, Setting Up Provided Network Key for Secure Communications
2019-12-09 14:20:27.361 Info, mgr, Added driver for controller /dev/ttyACM0
2019-12-09 14:20:27.361 Info, Opening controller /dev/ttyACM0
2019-12-09 14:20:27.361 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2019-12-09 14:20:27.361 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2019-12-09 14:20:27.361 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-12-09 14:20:27.361 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-12-09 14:20:27.361 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-12-09 14:20:27.361 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-12-09 14:20:27.361 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-12-09 14:20:27.361 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-12-09 14:20:28.361 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-09 14:20:28.361 Detail, contrlr, Removing current message
2019-12-09 14:20:28.361 Detail, contrlr, Notification: Notification - TimeOut
2019-12-09 14:20:28.361 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-12-09 14:20:29.361 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-09 14:20:29.362 Detail, contrlr, Removing current message
2019-12-09 14:20:29.362 Detail, contrlr, Notification: Notification - TimeOut
2019-12-09 14:20:29.362 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-12-09 14:20:30.362 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-09 14:20:30.362 Detail, contrlr, Removing current message
2019-12-09 14:20:30.362 Detail, contrlr, Notification: Notification - TimeOut
2019-12-09 14:20:30.362 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-12-09 14:20:31.362 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-09 14:20:31.362 Detail, contrlr, Removing current message
2019-12-09 14:20:31.362 Detail, contrlr, Notification: Notification - TimeOut
2019-12-09 14:20:31.362 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-12-09 14:20:32.362 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-09 14:20:32.362 Detail, contrlr, Removing current message
2019-12-09 14:20:32.362 Detail, contrlr, Notification: Notification - TimeOut
