Why not configure pi-hole to allow all lookups from the supervisor…
Thank you, I just added github.com domain to whitelist - not to have the issue again.
Appreciate it.
I should have said I couldn’t get it working (but got deCONZ addon working) and wanted to see if there was anything obvious I needed to do. I’ll have a read through the October thread and see. Thanks @fredrike
Progress… I have it working with ZHA now. I would say that my zigbee2mqtt container must have turned on by accident when I wasn’t looking, causing the device access not to function. Thanks @fredrike
Continuing the discussion from [Hass.io on Synology DSM (native package)](https://community.home-assistant.io/t/hass-io-on-synology-dsm-native-package/125559):
Update from 106.2 to 106.4 failed. hassio_audo container fails to start and causes hassio_supervisor to restart it in a never ending loop. Previously this container was stopped and it did not affect the main program. Can anyone help?
Have the same problem. Can’t run Hassio. Please treat it!
Same problem as who? Please read post #2.
I also have the same problem as Jim Floris and Spiritus
Maybe you’re missing Audio Station? I know that there is a problem with snapcast, without audio station.
Works fine for me:
20-03-03 19:38:10 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-03-03 19:38:10 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/marcelveldt/hassio-addons-repo repository
20-03-03 19:38:10 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-03-03 19:38:15 INFO (MainThread) [supervisor.store] Load add-ons from store: 88 all - 0 new - 0 remove
20-03-03 19:49:48 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.106.4
20-03-03 19:49:48 INFO (SyncWorker_2) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.106.0 to homeassistant/qemux86-64-homeassistant:0.106.4
20-03-03 19:49:48 INFO (SyncWorker_2) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.106.4.
20-03-03 19:51:11 INFO (SyncWorker_2) [supervisor.docker.interface] Stop homeassistant application
20-03-03 19:51:18 INFO (SyncWorker_2) [supervisor.docker.interface] Clean homeassistant application
20-03-03 19:51:39 INFO (SyncWorker_7) [supervisor.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.106.4
20-03-03 19:52:05 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-03-03 19:52:05 INFO (MainThread) [supervisor.homeassistant] Successful run Home Assistant 0.106.4
20-03-03 19:52:05 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['homeassistant/qemux86-64-homeassistant:0.106.0']
Yep, update from 106.2 to 106.4 breaks HomeAssistant
I’ll dig deeper…
I added a folder hass.io/audio/external. This allowed me to start the homeassistant docker manually. The hassio_audio container continues to recycle.
Excerpt from supervisor log:
2020-03-03 17:01:51 stderr e[32m20-03-03 17:01:51 INFO (SyncWorker_0) [supervisor.docker.audio] Start Audio homeassistant/amd64-hassio-audio with version 5 - 172.30.32.4e[0m
2020-03-03 17:01:47 stderr e[32m20-03-03 17:01:47 INFO (SyncWorker_8) [supervisor.docker.dns] Start DNS homeassistant/amd64-hassio-dns with version 1 - 172.30.32.3e[0m
2020-03-03 17:01:38 stderr e[32m20-03-03 17:01:38 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3e[0m
2020-03-03 17:01:38 stderr e[32m20-03-03 17:01:38 INFO (MainThread) [supervisor.dns] Start CoreDNS plugine[0m
2020-03-03 17:01:38 stderr e[32m20-03-03 17:01:38 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_audio applicatione[0m
2020-03-03 17:01:37 stderr e[32m20-03-03 17:01:37 INFO (MainThread) [supervisor.audio] Start Audio plugine[0m
2020-03-03 17:01:37 stderr e[32m20-03-03 17:01:37 INFO (SyncWorker_3) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-dns with version 1e[0m
2020-03-03 17:01:37 stderr e[32m20-03-03 17:01:37 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-audio with version 5e[0m
2020-03-03 17:01:37 stderr e[32m20-03-03 17:01:37 INFO (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on hoste[0m
2020-03-03 17:01:37 stderr e[32m20-03-03 17:01:37 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}e[0m
2020-03-03 17:01:37 stderr e[32m20-03-03 17:01:37 INFO (MainThread) [supervisor.host.sound] Update PulseAudio informatione[0m
2020-03-03 17:01:37 stderr e[33m20-03-03 17:01:37 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.e[0m
2020-03-03 17:01:37 stderr e[33m20-03-03 17:01:37 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.e[0m
2020-03-03 17:01:37 stderr e[33m20-03-03 17:01:37 WARNING (MainThread) [supervisor.dbus.hostname] No hostname support on the host. Hostname functions have been disabled.e[0m
2020-03-03 17:01:37 stderr e[33m20-03-03 17:01:37 WARNING (MainThread) [supervisor.dbus.systemd] No systemd support on the host. Host control has been disabled.e[0m
2020-03-03 17:01:37 stderr e[32m20-03-03 17:01:37 INFO (MainThread) [__main__] Setup Supervisore[0m
2020-03-03 17:01:35 stderr e[32m20-03-03 17:01:35 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connect Supervisor to hassio Networke[0m
2020-03-03 17:01:35 stderr e[32m20-03-03 17:01:35 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 207e[0m
2020-03-03 17:01:35 stderr e[32m20-03-03 17:01:35 INFO (MainThread) [__main__] Initialize Supervisor setupe[0m
2020-03-03 17:01:29 stdout [services.d] done.
2020-03-03 17:01:29 stdout [services.d] starting services
2020-03-03 17:01:29 stdout [cont-init.d] done.
2020-03-03 17:01:29 stdout [cont-init.d] udev.sh: exited 0.
2020-03-03 17:01:28 stderr [17:01:28] INFO: e[32mUpdate udev informationse[0m
2020-03-03 17:01:27 stdout [cont-init.d] udev.sh: executing...
2020-03-03 17:01:27 stdout [cont-init.d] executing container initialization scripts...
2020-03-03 17:01:27 stdout [fix-attrs.d] done.
2020-03-03 17:01:27 stdout [fix-attrs.d] applying ownership & permissions fixes...
2020-03-03 17:01:27 stdout [s6-init] ensuring user provided files have correct perms...exited 0.
2020-03-03 17:01:27 stdout [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
hassio_audio log:
2020-03-03 20:12:37 stdout [s6-finish] sending all processes the KILL signal and exiting.
2020-03-03 20:12:34 stdout [s6-finish] sending all processes the TERM signal.
2020-03-03 20:12:33 stdout [s6-finish] waiting for services.
2020-03-03 20:12:33 stdout [cont-finish.d] done.
2020-03-03 20:12:33 stdout [cont-finish.d] executing container finish scripts...
2020-03-03 20:12:33 stdout [cont-init.d] adjust-audio-group.sh: exited 1.
2020-03-03 20:12:32 stdout [cont-init.d] adjust-audio-group.sh: executing...
2020-03-03 20:12:32 stdout [cont-init.d] executing container initialization scripts...
2020-03-03 20:12:32 stdout [fix-attrs.d] done.
2020-03-03 20:12:32 stdout [fix-attrs.d] persistent-data: exited 0.
2020-03-03 20:12:32 stdout [fix-attrs.d] persistent-data: applying...
2020-03-03 20:12:32 stdout [fix-attrs.d] applying ownership & permissions fixes...
2020-03-03 20:12:32 stdout [s6-init] ensuring user provided files have correct perms...exited 0.
2020-03-03 20:12:31 stdout [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
It is a problem with supervisor 207/hassio_audio version 7.
There is already a fix for this in hassio_audio version 8.
@fredrike it is discussed on discord in the dev_supervisor channel. Please have a look.
Adding a new folder external
in hass.io/audio/ helps to start HA Core manually again.
But hassio_audio keeps “bootlooping”
Very strange, I upgraded from 106.0 -> 106.4 and that worked fine…
The workaround is to create empty folder ‘external’ inside /(hassio_folder)/audio/external
I already had the “external” and “internal” folders hass.io/audio folder. Anything other suggestion to get it working again?
same problem.
Thanks , and wonderful answer
Please note: Running Home Assistant (previously known as Hass.io) on a Synology NAS is not supported by us.
So no idea…
