Home Assistant Supervised (previously known as Hass.io) on Synology DSM as native package (not supported or working atm)
A lot of people have issues like this…
This will not help, but just to confirm - I’m running CORE 2021.2.1 and CORE 2021.2.2 - both with supervisor 2021.02.6 - and all are working OK. My DSM version on both machines is 6.2.3-25426 Update 2.
All addon’s working great, latest releases…
Please don’t tag me if there is no reason for me to react/respond.
i have only one difference, my DSM version is DSM 6.2.3-25426 Update 3,
do you think that’s it? and is it going to make a change/downgrade on update 2 ?
supervisor-2021.02.6
core-2021.2.2
Docker 18.09.8
duckDns & Mosquitto not working anymore
Plus one in the same situation. should just have stay quiet and all was working. Updated and now only problems.
Where do we ask synology to update container?
For a quick and temporary fix yesterday I downgrade supervisor to 2021.01.7. Be aware to create a snapshot first, some of my Add-ons where gone after doing this. After downgrade click on install they where back including the settings.
For downgrade use the Terminal & SSH add-on it’s still installing with the latest supervisor and execute:
ha supervisor update --version 2021.01.7
Unfortunately overnight Home Assistant automatically updates supervisor back to 2021.02.6. So do not rebooting any addons then it keeps working.
Interesting, because I did the same, just went down to 2021.1.5, like described a couple of posts above. Automatic updates are off and downgrading worked fine. Just the error stayed and restarting or rebooting the whole Synology did not change anything. :frowning:
Afterwards I even did one step further and also downgraded core as well, but this didn’t change the result either.
It also worked fine for me until I restarted an addon (DuckDNS by update). Have you tried restarting it? On the other hand, have you installed the addons from HA or by manually deploying docker?
Thanks!
it’s working! Many thanks, simple downgrade with docker > Hassio CLI > terminal
THANKS!
thx, very good “hack” -), is possible to disable the automatic update somewhere ?
I think I found a solution for that. ssh into your Synology.
Run the follow command to find the id for the supervisor container: docker container ls
The go into that folder: docker exec -it *id* bash
Then edit this file with: vi /usr/src/supervisor/supervisor/misc/tasks.py
Delete the lines:
RUN_UPDATE _SUPERVISOR = 29100
self.sys.scheduler.register .....etc...... supervisor
Then reboot the container.
How have you done to reinstall the addons? I just did that with DuckDNS but when starting it tells me that the configuration is missing. Have you stopped the docker from DSM first and then reinstalled? Or as?
you make nothing with docker
1- you must have "last good snapshot "
2- then install addon Terminal & SSH (not SSH & Web Terminal)
3- from Terminal & SSH execute:
4- then you restore only all addons from “last good snapshot”
  • when you not have “last good snapshot” have to make new config
everything should be OK … until:
  • the next supervisor update (based on info from “rdekruyf” happens every night)
  • and subsequent restart of the addon (is depend from you)
Edit: I’m sorry if this is duplicative of @blavak68 post above, but knowing my frustration with this issue I thought it might help someone
I’m back up to full functionality. What worked for me was:
Downgrading to Supervisor 2021.01.7 as described by @rdekruyf
Restoring a snapshot from 5 days ago (2021-02-05, I cannot recommend Hassio Google Drive Backup enough)
Upgrading to Supervisor ver. 2021.02.1 (I had migrated to Zwave JS and needed a 2021.02 version)
I hope this proves useful for those of you also having trouble.
does the addons restart work?or if upgrading to the new version and don`t reboot the addons?
@anschein I am able to restart without the new version of Supervisor being installed, I just have the notification on the Dashboard tab of Supervisor that an update is available.
Edit: @anschein upon further review I don’t think I understand your question
i mean in the supervisor ver.2021.02.1,can you reboot the addons?i have some connection problem with my MQTT broker and need a new version can reboot the addon :frowning:
@anschein yes, my addons are restarted and functioning normally
Thx,and i tried every version SUP i can and found ver 2021.01.8 is work for me and safety reboot the addons…But i didn`t upgrade to the new version of supervisor.
So can i ask which addons reboot fine in 2021.02.1?
like many others I have problems with the new supervisor. The problem did not occur until I restarted my synology.
I noticed that the new supervisor released in February bind the /dev:/dev path into the new containers (only in new ones or in those that the supervisor decides to recreate)
This thing creates problems for me with these addons:
-mosquito
-grafana
-esphome
I tried to delete the bind (dev: dev) but if I modify the container from docker / portainer the supervisor no longer recognizes the addon (the addon starts in this case)
