Hello. I have problems with the installation of Home Assistant Superior 2022.11.2. On my system I have Core 2022.11.1 and Supervisor 2022.11.0 installed. When I install the latest version of HA Supervisor, it stays for hours as if it were installing, but it doesn’t. This happens to me in two installations of Home Assistant. Do you know if there is any solution?
maybe also your issue…
Thank you very much. I’m going to disable the beta and try to install again. I’ll tell you
Will have to wait for them to fix it. It is useless to remove the beta version since it does not allow updating either. Thanks for the info
Waiting won’t help as the issue prevents you from updating. Follow the instructions in the linked post to fix it.
Thanks tom. I’m already trying to fix it. Best regards!
