Update, January 25th 2024 - Staying on Docker 24 is advised
The release of Docker 25.0.1 has resolved the networking issue that prevented Supervisor from starting, but there appears to be another Docker related issue that impacts the InfluxDB integration.
Docker 25.0.x has introduced a change in file system mounting behavior that appears to be impacting python multiprocessing. See these issues core/issues/108810 , moby/issues/47158. The HA InfluxDB integration uses multiprocessing.
It’s possible other HA integrations are impacted by the change in docker file system mounting behavior.
Unless you have a compelling need to use Docker 25 it may be advisable to stay on Docker 24 until more is known about the InfluxDB integration issue.
Update, January 24th 2024 - Issue that prevented Supervisor starting is resolved
The docker networking issue caused by the release of Docker 25.0.0 has now been resolved with the release of Docker 25.0.1.
Those experiencing issues on docker-ce 25.0.0 or those that have downgraded to docker-ce 24.0.7 can issue the commands below to upgrade to docker-ce 25.0.1
- Check if docker-ce 25.0.1 is available in the package repository.
sudo apt update
apt-cache madison docker-ce
- Removed the apt hold of the docker packages, run apt upgrade, and reboot the system.
sudo apt-mark unhold \
docker-ce \
docker-ce-cli \
docker-buildx-plugin \
docker-compose-plugin \
docker-ce-rootless-extras
sudo apt update
sudo apt upgrade
sudo reboot
Supervisor fails to start on docker-ce 25.0.0 - Downgrade to docker-ce 24
For those finding that HA fails to start all services, this may be caused by docker being upgraded from version 24 to 25 on Jan 19th 2024.
There appears to be a compatibility issue between Supervisor and docker version 25. Supervisor fails to start after the docker upgrade.
This post indicates that the issue is with docker and that a fix will arrive in a docker 25.0.1 backport and docker 26.0.0.
A workaround until this issue is resolved is to downgrade docker back to version 24, place a hold on the docker packages to prevent them upgrading again, and reboot the system.
Below is an example of those steps for debian 12 bookworm.
sudo apt install \
docker-ce=5:24.0.7-1~debian.12~bookworm \
docker-ce-cli=5:24.0.7-1~debian.12~bookworm \
docker-buildx-plugin=0.11.2-1~debian.12~bookworm \
docker-compose-plugin=2.21.0-1~debian.12~bookworm \
docker-ce-rootless-extras=5:24.0.7-1~debian.12~bookworm
sudo apt-mark hold \
docker-ce \
docker-ce-cli \
sudo reboot
You can check for the specific docker versions to downgrade to in the apt history log.
cat /var/log/apt/history.log
This command will list the set of upgraded docker packages from the apt history log file in a more readable format.
grep -e '^Upgrade:.*docker-ce.*25.0.0' /var/log/apt/history.log | sed -e 's/Upgrade://' -e 's/),/)\n/g' | sort
You can check for the versions of docker available in the package repository with,
sudo apt update
apt-cache madison \
docker-ce \
docker-ce-cli \
Once the issue is resolved, presumably when docker 25.0.1 or 26.0.0 are released, the docker package version hold can be removed with,
docker-ce \
docker-ce-cli \
