Home Assistant upgrade since 2021.4.3 (including latest 2021.5) breaks ZHA Integrations
Today Home Assistant upgraded to 2021.4.3 - unfortunately this broke ConbeeII which I had running for the past six months, slowly building up my Zigbee devices and have now start to use automation, which so far worked well! I am running Home Assistant in a docker container on Synology NAS 920+ (OS is up to date).
However an automatic upgrade from 2021.4.2 to 2021.4.3 today broke ConbeeII by stating that it could not find the device i.e. “FileNotFoundError: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2260014-if00’
2021-04-12 11:34:56 stdout self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)”
I tried to troubleshoot, but given that I had not made any changes, and permission are all correct, plus Synology can see the USB ConbeeII, I had to revert back to 2102.4.2 in a new container.
Could someone please investigate this, but I allow further update to home assistant?
Since I posted this nearly a month ago, I have decided to change the title, and provide further info from the logs.
I have also attempted to upgrade Home Assistant to the latest (2021.5), but are still having the same problem where ZHA fails to start owing to failing to ‘find’ conbee II usb device. However whn I downgrade home assistant back to 2021.4.2 it works fine. So I am unable to progress to latest upgrade but stuck on 2021.4.2 build. I could take ZHA integration out and put it back in, but I will lose all the zigbee devices, and have to rebuild it back in - and that’s if ZHA works. If I need to do this, it will be my last options, problem is am I going to expect this in future upgrades?
I use home assistant in Docker container on a Synology DS920+ where it has run fine for the past 6 months with ZHA integration and are using Conbee II USB device. Synology are still able to ‘see’ Conbee II following the upgrade, but log throws up several errors.
Here are the details of the log:-
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:157
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 15:44:25 (4 occurrences)
Last logged: 15:45:03
Couldn’t start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
File “/usr/local/lib/python3.8/site-packages/serial/serialposix.py”, line 322, in open
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 157, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.8/site-packages/zigpy/application.py”, line 69, in new
await app.startup(auto_form)
File “/usr/local/lib/python3.8/site-packages/zigpy_deconz/zigbee/application.py”, line 65, in startup
await self._api.connect()
File “/usr/local/lib/python3.8/site-packages/zigpy_deconz/api.py”, line 245, in connect
self._uart = await zigpy_deconz.uart.connect(self._config, self)
File “/usr/local/lib/python3.8/site-packages/zigpy_deconz/uart.py”, line 142, in connect
_, protocol = await serial_asyncio.create_serial_connection(
File “/usr/local/lib/python3.8/site-packages/serial_asyncio/init.py”, line 445, in create_serial_connection
serial_instance = serial.serial_for_url(*args, **kwargs)
File “/usr/local/lib/python3.8/site-packages/serial/init.py”, line 90, in serial_for_url
instance.open()
File “/usr/local/lib/python3.8/site-packages/serial/serialposix.py”, line 325, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2260014-if00: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2260014-if00’
Logger: zigpy.application
Source: /usr/local/lib/python3.8/site-packages/zigpy/application.py:73
Couldn’t start application
Logger: homeassistant.config_entries
Source: config_entries.py:300
First occurred: 15:44:25 (1 occurrences)
Last logged: 15:44:25
Config entry ‘ConBee II, s/n: DE2260014 - dresden elektronik ingenieurtechnik GmbH’ for zha integration not ready yet: [Errno 2] could not open port /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2260014-if00: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2260014-if00’; Retrying in background
Any advice/help would be appreciated.
Chances are, the Conbee does not appear as /dev/serial/by-id/… anymore, but as /dev/tty… .
Check out this post:
