Hey everyone.
I am quite new to home assistant and have a problem with my setup and deconz that I’m not able to solve.
I installed supervised & dockerised home assistant on my Linux server using this method: https://www.youtube.com/watch?v=pUlpfx0jaYA
I installed the deconz addon for my conbee 2 and everything was runnig fine until I restarted my server and home assistant couldn’t be reached anymore. The home docker log say the following:
ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 0.0.0.0
WARNING (MainThread) [homeassistant.config_entries] Config entry '00212E054A8E' for deconz integration not ready yet. Retrying in 80 seconds
As I was not able to reach the HA frontend anymore, i deleted the deconz docker container manually, which also did not solve the problem.
I did not know what else to do so I deleted home assistant and started from scratch using the same installation method again. However I get the same issue with HA frontend not starting and the same logs as mentioned above.
How can i fix this?
