Just got my new yellow and wanted to run Z2M instead of ZHA. So I uninstalled ZHA, But I keep getting issues.
Any ideas?
[01:46:52] INFO: Preparing to start…
[01:46:53] INFO: Socat not enabled
[01:46:56] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2023-08-03 01:47:02: Logging to console and directory: ‘/config/zigbee2mqtt/log/2023-08-03.01-47-02’ filename: log.txt
Zigbee2MQTT:info 2023-08-03 01:47:02: Starting Zigbee2MQTT version 1.32.2 (commit #unknown)
Zigbee2MQTT:info 2023-08-03 01:47:02: Starting zigbee-herdsman (0.17.2)
Zigbee2MQTT:error 2023-08-03 01:47:22: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-08-03 01:47:22: Failed to start zigbee
Zigbee2MQTT:error 2023-08-03 01:47:22: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2023-08-03 01:47:22: Exiting…
Zigbee2MQTT:error 2023-08-03 01:47:23: Error: Connection not initialized
at Ezsp.execCommand (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:551:19)
at Ezsp.version (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:349:35)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:141:25)
at EZSPAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:165:16)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:59:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:107:5)
Yaml file:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
mqtt:
base_topic: zigbee2mqtt
serial:
port: /dev/ttyAMA1
baudrate: 115200
rtscts: false
adapter: ezsp
