Home Panel v2.4.3
This release adds functionality to control the app via the API. More on this to come
Changes
- 5183035 Update dependency typescript to v3.6.4 (#648)
- 9b786b1 API Controller (#649)
yeah, it is working on my front end in HA. I have 2 nest thermostats. Not sure if that is causing an issue.
My AC works 100% in frontend and also automations and appdaemon app as well.bit turning it off from Homepanel won’t work.it stays the same operation mode set before.if I turn off climate from frontend or other clients it shows off as well in Homepanel widget …strange I know
Sounds like this will prepare the way to state and event (re) actions in Homepanel?
How is RSS feed supposed to work? I have such a link : https://xxx.xxxxxx.info/rss.php?cat=3,54,50,52,8&dllink=1
Possible to get this somehow working in homepanel?
Apparently there’s a problem with CORS in RSS feed reader…
Access to fetch at 'https://ttv2.myamity.info/rss.php?cat=3,54,50,52,8&dllink=1' from origin 'http://home-assistant:8234' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
Is there a way to fi this myself or is it in the code?
I am unable to get SSL working for home-panel. Tried it on the same server as HA and same custom domain, no luck. Running HA with SSL behind nginx reverse proxy. Tired it with docker compose and docker. Tried with and without reverse proxy running.
Tried running home-panel on a different machine and domain, still no luck. Will only answer to http. Brought up a default nginx service and verified certs were good and I was able to make a secure connection. Attached to the docker container and was able to see my certs were mapped appropriately into the container.
Out of ideas…
I still face the issue that after for example put transparent for background in a widget… The color wheel freezes
Did you ever figure this out?
i have been keeping up with all the patches but still get a blank screen on latest hassio with any browser on my macOS
I’m facing an really annoying issuewith my color bulb (Tuya Based with 6.6 sonof firmware)
The issue happend after an upgrade from version 2.2 (not Sure exactly)
I can toggle on and off but if do it with the last bulb still on i got the color wheel at the wrong place
From the first light to the last one everything is properly working
anyone can help ?
Fixes for docker ssl, new sidebar/drawer types, device class support, subscribe to config updates, error fixes and updates
Just pulled latest image but it seems no chnages have been pushed? There’s no drawer_types nor state from device_class
Can someone help with card configuration. I have sensative strips and for open and closed then have a state of either 22 or 23 and I would like the card in Home Panel to show Open or Closed. I can do that in HA with the following configuration.
sensors:
front_door_sensative_strips_access:
friendly_name: "Front Door"
device_class: door
value_template: "{{ states('sensor.front_door_sensative_strips_access') | float <= 22 }}"
But can’t figure it out for Home panel!
Device_class has been added to latest release but I am also facing that this is actually not there. Seems like last build failed
When you see a new release, check it’s badges. My ones for example should always include the release pipeline and as you can see, it is still running:
hmm according to the HA addons screen I am using 1.4.3! how am I so many version behind when I only installed it a few days go.
Yes @timmo001 and last badge state was failed. so I guess I did not pull latest release right? I am using native docker
