Were you able to figure this one out?
Iām having trouble accessing Home Panel outside of my hass.io add-on. Below are my logs; doesnāt seem to be any errors. I have re-logged in, restarted hass.io. Suggestions?
Iām attempting to access panel @ https://192.168.1.198:8234
Hass.io virtual machine
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Home Panel
A web frontend for controlling the home
Add-on version: 1.4.6
You are running the latest version of this add-on.
System: HassOS 2.12 (amd64 / qemux86-64)
Home Assistant version: 0.100.2
Supervisor version: 192
Is it possible to show a live feed of my ring flood light? I noticed a github python ring project, though donāt know a) if that will work with my VM-based hassio, b) if I can get a live url feed from it.
Edit: If not live, how about the last image capture url?
Hey guys, is there a way to get a ādirect URLā ?
I want to load the dashboard I did on HomePanel on my WallPanel Tablet.
The only URL I found is http://myha.url:8126/a0d7b954_home-panel but this load the āFrameā of homeassistant.
As my goal is just to have the dashboard on my tablet I do not want this.
thanks,
Change the port manually in the add-on
Hi
Just started looking at this add-on and one thing i cant find out is how to know what to write in the icon field.
If i write switch or lightbulb i get the icon. āGet from HAā does nothing. Is there a list of what icons are available ?
Ok, thanks that helped
Have a couple of questions as Iām getting this set up.
Is it possible to access the config file to edit manually when using the Add-on in Hassio.
The /addons folder is empty and Iāv seem to have put some bad number in color so the picker is not working.
Created a new page, but where do I rename/delete the page ? Canāt find that in the UI.
*Does the Font size setting work for anyone? Looks like there are some early posts about it but canāt see if its been fixed.Ignore this, didnāt get that i had to type "px"
When connecting to homeassistant the first time is there no possibility to not use https? I publish externally with ssl via a proxy but it would be nice to just point it to the internal non https hassio.local:8123. If I remove the s inte https i get a red text saying i have to use ssl and the submit button is greyd out.
How did you rename the pages ? I just get Page as name and canāt see anyware to rename them ?
Long press on the page icon in configuration mode
Ah, thanks a lot.
Hi all, first request about Home Panel
installed the add-on, configured login, logged to HA, designed my dashboardā¦ so far, so good.
Iām accessing home panel via the MQTT alarm control panel app (https://play.google.com/store/apps/details?id=com.thanksmister.iot.mqtt.alarmpanel&hl=en) from my fire 7".
After some hours I have to login to home panel (and itās quite annoying since my tabled is on the wall and the on screen keyboard stays over the login fields) but the real issue is that I have to login again to HA.
Trying to do so, pushing on the button in the drawer, has no effect at all.
My fire has a fixed ipā¦
Is there anything obvious Iām missing? is there anything I can check to avoid this issue?
TIA
Hi
I have a sensor that calculates it entity picture dynamically depending on wind direction.
Is it possible to use a sensor value as url for and image card ? or as background so i can display wind speed as numeric and a compass behind to show direction would be even nicer.
answering to myself: newermind, it seems something related to the app.
sorry for the noise
I have the same issue with the last available add-on release on a 7" 2015 5th gen. Amazon Fire; did you find a way to solve it?
I donāt have persistent scrollbars in 2.4.9 using the config below, though they do show up when I interact with the system and the bottom (page?) bar pops up.
Thank you, will try later
Just started using Home Panel, really like this interface. Iām having an issue when the page is idle, the bottom drawer goes away and if I try to select an entity to turn it on or off, I have to tap anywhere on the screen first (which makes the bottom drawer display) and then I can select the entities. Is this expected behavior?
how can i change the language ? HomePanel is showing the values of my entityās in english in stead of the preferred dutch language.
