Home Panel - A web frontend for controlling the home
I am running to the exact same issue hete.
Really like the panel. Only i also first need to tap somewhere on te screen And then Can press a button.
How Can you manage that the footer with pages keeps in front?
Because mine keeps hiding And i need to press somewhere on te screen before i Can press a button
sorry ā€¦ same issue hereā€¦ but i think itā€™s made intentionally. If you mind, please open an issue on github :slight_smile:
Whoo thatā€™s exactly what i want to say about this great addon.
Iā€™m not using it because of this behavior. The display is changing when you click/press a button.
Is it possible to mask the bottom and up bar ?
I submitted an issue on GitHub, fingers crossed we get a solution for it!
General questionā€¦it seems this project is a bit on ice? long time no new release ā€¦ could the dev give a short feedback ?
thanks, fingers crossed!
Look like they just released a new version yesterday: https://github.com/timmo001/home-panel/releases
this is not the same repo than hassio
Version in hassio is 1.4.8
I donā€™t really understand
EDIT: Sorry, Addon versioning is not the same :slight_smile:
I will almost always add the Home Panel version and link to release notes on the Hass.io add-on release notes. Please check there
Home Panel v2.5.0 :tada:
GitLab CI
https://github.com/timmo001/home-panel/releases/tag/v2.5.0
A couple of fixes and tweaks in this one :hammer_and_wrench:
The Docker Alpine image has also been upgraded :arrow_up:
Changes
  • dc483e2 :arrow_up: Update Node.js to v12.14.0 (#842) @renovate[bot]
  • 2d88a94 :arrow_up: Update dependency typescript to v3.7.4 (#848) @renovate[bot]
  • 061c473 :arrow_up: Update dependency superagent to v5.1.3 (#847) @renovate[bot]
  • 2f2a528 :arrow_up: Update dependency @types/react to v16.9.17 (#846) @renovate[bot]
  • 19894f9 :arrow_up: Update dependency @types/jest to v24.0.24 (#844) @renovate[bot]
  • 573f328 :arrow_up: Update dependency snyk to v1.265.0 (#843) @renovate[bot]
  • 4b05df0 :arrow_up: Update dependency @types/node to v12.12.21 (#845) @renovate[bot]
  • af5be35 :arrow_up: Update dependency @types/node to v12.12.22 (#849) @renovate[bot]
  • ebe230f :arrow_up: Update dependency @types/recharts to v1.8.4 (#850) @renovate[bot]
  • 3634521 :arrow_up: Update dependency @material-ui/core to v4.8.1 (#851) @renovate[bot]
  • 46bc956 :arrow_up: Update dependency snyk to v1.266.0 (#852) @renovate[bot]
  • 2098789 :arrow_up: Bump handlebars from 4.1.2 to 4.5.3 (#854) @dependabot[bot]
  • 4fac291 :arrow_up: Update dependency @types/jest to v24.0.25 (#853) @renovate[bot]
  • 7519292 :arrow_up: Bump handlebars from 4.1.2 to 4.5.3 in /api (#855) @dependabot[bot]
  • df46af0 :wrench: Add autohide navigation
  • ba5957d :blonde_man:Add person support
  • baeb726 :arrow_up: Update openssl to 1.1.1d-r2
  • c1898cb :arrow_up: Update dependency snyk to v1.267.0 (#856) @renovate[bot]
  • e5caf96 :arrow_up: Upgrade alpine to 3.11.2
  • 372b430 :hammer_and_wrench: Fix scrolling on persistent icons drawer
  • 4805609 :wrench: Tweak edit icons
  • 5418180 :arrow_up: Update renovate to actual emojis
Full Changelog
Can someone point me how to control an AC with home panel?
Set the entity as climate.whatever
I tried that before and got a useless square with no controls.
Make it bigger, try 4x2
Does anyone have a list of the possible usable icons in Home Panel?
@Reilly911 https://materialdesignicons.com/
hey mate,
howā€™d you get torrent count in relation to active downloads/uploads etc?
Thatā€™s just the sensors from transmission component.but I had to remove it as my transmission doesnā€™t work anymore ā€¦Iā€™ll use deluge and hadashboard as Homepanel brings my Intel nuc to fall and becomes unresponsive
yeh iā€™m using Deluge as well but it only has 3 sensors that iā€™m aware of and 1 switch to ā€œpause allā€ or ā€œresume allā€
Let me know how you go.
