A few weeks ago I set up Duck DNS, SSL, and an API password. When i was getting it set up, I didn’t use the most secure password, so yesterday I used a password generator to create a random 20 character password.
The web interface still allows me to log in with my new password, however in my home-assistant.log I now continually get:
2017-11-18 14:14:56 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.1
2017-11-18 14:15:01 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.1
2017-11-18 14:15:06 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.1
I’ve now changed my password back to the not so secure password, and attempted other passwords with and without special characters. I’ve used the secrets.yaml file to store the password, and also just left the password in the configuration.yaml.
I’ve cleared cookies and cache from my chrome web browser and from my mobile, which are the two platforms I typically use to access the dashboard.
I don’t believe this error showed when I originally set up the SSL and password, but it seems any combination of settings I’m getting is now showing this continuous error.
For now I removed the error by white listing my router’s IP address, although I’m still not sure whats causing the error to present in the first place.
Did you ever track this down by chance? I went from a normal (8-10 character) password to a super secret 16-20 character while trying to setup google assistant component, and was able to log in via duckdns with the new password - but continually getting the same “Login attempt or request with invalid authentication from 192.168.1.1” message… what gives?!
I haven’t messed with it again much. If I remove this from my config, the error comes back. I’m not sure if this is the best solution (or most secure?) but that is the only way I’ve found so far.
I’m on 0.59.2 and started seeing this issue after changing my password. I’ve updated all of my devices that are configured with the password to the new password but I still continue to get the error message flooding my log file.
The only difference in my setup is that I have letsencrypt and duckdns configured and the invalid IP in my logs is shown as my Public IP address.
My best guess is that some component of HA has configured itself with the initial password and keeps trying to connect - but I temporarily changed my password back to the original value and it didn’t eliminate the problem - so that kind of rules out this theory.
Is there a log message we can enable that will give us more information about the connect which gets rejected? For example, the entire URL that was requested with the ‘bad password’ or more detail about the requester themselves? Showing me that it originated with my router is not really all that useful.
At a minimum, it seems like there should be a pointer on the Home Assistant security page(s), and maybe a mention in the hass.io add-on’s “options” template to give people some bread crumbs.
No final „fix“ for this? My main smartphone running HA Companion app triggers those messages quite frequently. Couldn’t track down why/when because of which reason but… it’s annoying especially cause I block devices after few failed login attempts.
