Homeassistant with homeseer
The same process applies, it’s just easier with the Z-Net since you don’t have to physically move anything.
Check out this post for some insight. Obviously yours will be serial instead of TCP. The important bit is obtaining the keys from HS and configuring them in ZWaveJS. You can run an instance for your existing 7 stick and run a second one for the 5 stick
