Can anyone running 2021.11.X let me know if clearing their browser cache does anything to resolve this issue?
mike1627
(Mike1627)
November 16, 2021, 9:43pm
43
Nothing to do with browser cache, I tried two entirely different web browsers and the issue persists.
Thanks. I let the dev know in the Github issue.
bdraco
(J. Nick Koston)
November 16, 2021, 10:35pm
45
Thanks for opening the issue. If anyone has replication steps, please post them to the issue.
Eagerly awaiting a fix for this.
jjross
November 18, 2021, 8:48pm
47
Also having this issue. Going to try deleting my HK integration and adding it again.
The fix has already been tested and posted on GitHub. No need deleting everything when an update is right around the corner ツ.
Hey guys! Release 2021.11.5 is out with the fix.
Not tested yet.
I updated to 2021.11.5 and still have this issue. The interesting thing is, I have two bridges, one with all switches and binary status, and a second that only has a door lock. There is only one entity in the second bridge. Despite me not excluding anything from the second bridge I still get the error of “User input malformed”.
Note: I have not deleted and recreated the Bridge as was told it should not be necessary from an above comment.
ando1
(Andy)
November 20, 2021, 11:31am
52
I just updated and it fixed the issue for me. Thanks!
mike1627
(Mike1627)
November 20, 2021, 12:07pm
53
Odd, 2021.11.5 update isn’t even showing as available to me yet.
ando1
(Andy)
November 20, 2021, 12:22pm
54
@mike1627 I am running in a venv so when I ran the update it automatically pulled the new version.
zadigre
November 20, 2021, 12:34pm
55
@mike1627 same for me.
I’m running Home Assistant OS on my Raspberry PI4… and no update is available.
You can update HA core to a specific version via SSH
Just confirming that the update worked for me
bdraco
(J. Nick Koston)
November 20, 2021, 11:08pm
58
I opened a PR to improve the error message so we can try to track down the cause
home-assistant:dev ← bdraco:show_why_input_malformed
opened 11:07PM - 20 Nov 21 UTC
## Proposed change
Describe the big picture of your changes here to com… municate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Show how user input is malformed in the UI on error (see https://community.home-assistant.io/t/homekit-error-user-input-malformed/353390/58?u=bdraco)
`User input malformed` wasn't very helpful to figure out what was going wrong.
The security aspect of revealing this information should be considered. It seems like the benefit out-weighs the risk, but someone else should think about that.
<img width="588" alt="Screen Shot 2021-11-20 at 17 04 19" src="https://user-images.githubusercontent.com/663432/142743356-34bbf69a-58d3-4389-8992-912ccae80cb2.png">
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [x] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
Looks like we need to adjust the exclude path as well:
home-assistant:dev ← bdraco:strip_deleted_entities_homekit_config_flow_exclude_path
opened 11:28PM - 20 Nov 21 UTC
## Proposed change
- #59844 stripped the deleted entities from the include path
this change strips them from the exclude path
## Type of change
- [x] Bugfix (non-breaking change which fixes an issue)
- [ ] Code quality improvements to existing code or addition of tests
## Checklist
- [ ] The code change is tested and works locally.
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
been reviewed.
+1 confirmed the fix work on 11.5
lpaso
(Loïc)
November 22, 2021, 11:53pm
60
Just updated to 2021.11.5 and the bug’s still there.
epl2005
(EPL)
November 23, 2021, 10:07am
61
The same for me. In 2021-11-5 the bug is still present
